Old Apr 12, 2008, 04:16 PM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
Removing the canards is going to change the lift profile of the plane and this is not a good idea , this will change the area forward and require a shift of the cg rearwards....think of it this way if you INCREASED the size of the canards to double = more area forward , the cg would have to be moved forward other wise it would be a tail heavy situation with that extra lift from the extra forward area...I wont go into the center of pressure travel for different airfoils and plan view shapes
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Apr 12, 2008, 04:52 PM
doppler1 is offline
Find More Posts by doppler1
Joined Mar 2008
In theory.
In reality, those canards will have a negligible effect, at best, on lift. They will have an effect on trim, though.
They are tiny in relation to the wings.
doppler1 is offline Find More Posts by doppler1
Old Apr 12, 2008, 05:16 PM
Joined Nov 2002
Wrong... the canards have around 24 square inches area , you wouldnt take that much area OFF the front of the wing would you....even the fuse, forward of the cg creates some lift
However its your plane..............................
Old Apr 12, 2008, 06:04 PM
doppler1 is offline
Joined Mar 2008
Sure you could.
Like I said, I doubt if they have anything but the most neligible effect on lift, and that's not why they are there. I have had delta models with canards, and took the canards right off, with negligible trim effect.
Anyway...if the guy decides to try it, we will see.
Old Apr 12, 2008, 06:32 PM
Joined Nov 2002
like I said......its your model
Old Apr 12, 2008, 09:25 PM
Richard Evans is offline
Find More Posts by Richard Evans
Richard Evans's Avatar
USA, TX, Canyon Lake
Joined Jul 2006
Well, it was way to windy today to try anything. Tommorrow it is supposed to be as well, but I am going to the flying field anyway to mow, so maybe I will try.
It isn't going to be practical to remove the canards anyway, they are installed in a permanent way.
I appreciate all the suggestions, but my inclination is to move the cg furthur forward a little at a time. and perhaps disable the mix to the canards and bring them to the nuetral position as indicated my the molding on the fuselage. However, If it won't rotate I will have to crank back in some mix.
Just to clarify how I am mixing, the canards are locked together, only one servo is moving them. I am not mixing elevon, I am mixing "elevator stick"
they simply act as an elevator, and the control surfaces on the wings are acting as elevons.
If I can fly it tommorow i will post the results.
Richard Evans is offline Find More Posts by Richard Evans
Old Apr 12, 2008, 10:04 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Richard has the right idea.
Mixing Canards to Elevons really isnt such an oddball mix at all. To put it into a more 'conventional' perspective, it's practically the same concept as mixing Flaps to Elevator. The canards are coupled to the elevons, however they only move when a pitch command is given.
Removing the canards wouldn't be wise at all...
As mentioned earlier, they provide a significant amount of area and are located at a pretty good arm/moment from the CG. Removing the canards all together would change the aircraft's actual CG placement, kill alot of the lift the canard is producing, and you'd have to go back to finding the right CG.
Disabling the canard mix is a good way to go however... Im almost through building a J10 using elevons only, no canards at all, and it should do just fine.
Question for those of you flying this plane EDF:
Are you guys using any sort of intake ducting? Or just gluing the halves together?
Happy Flying,
Victor
AceMigKiller is online now Find More Posts by AceMigKiller
Old Apr 13, 2008, 04:40 AM
Joined Nov 2002
way to go Richard.....
Old Apr 13, 2008, 07:16 PM
Joined Jul 2006
I did get a chance to fly it today, but it was insanely windy. With the headwind, it wasn't hard to rotate even though I have moved the CG a little bit forward. I'm still using the mix with the canards so far. With the wind the way it was I couldn't really draw any conclusions other than the CG change didn't hurt any.
On landing one of the little plastic "hub caps" that keep the wheels on came off and the wheel left the gear. No damage, but I couldn't find the hub cap. probably a good idea to glue then on.
I'll have to improvise to fix it, but It eliminated the chance for any additional flights today.
Richard
Old Apr 13, 2008, 07:55 PM
Joined Jul 2004
Whoops, I hate it when that happens!
Richard, does your J10 have any sort of intake ducting?
Or did you just glue the halves together?
Vic
Old Apr 14, 2008, 11:00 AM
Scott Cuppello is offline
Find More Posts by Scott Cuppello
Commercial UAV Pilot
United Kingdom, England, Carlisle
Joined Mar 2007
I have discovered that canard trim on the GWS J-10 is quite critical, if it's too "down" it flies like the C of G is way forward, but if you actually watch it in flight, the elevators are working fine, you are just struggling like nuts to keep the nose up.
Scott Cuppello is offline Find More Posts by Scott Cuppello
Old Apr 14, 2008, 12:31 PM
Joined Jul 2006
No, I just put the two halves together, couldn't find any way to duct it.
I know, it defies all laws of good edf design, long torturous intake air path, but maybe it is because the fan is so good that it works!.
I understand that the GWS J10 has a cheater hole. I thought about trying that, but It doesn't seem to need it.
Richard
Vic
Old Apr 14, 2008, 01:33 PM
Joined Jul 2004
Cool thanks,
I was kind of skeptical at first about just gluing the halves together, however they do pretty much form the sort of intake ducting im looking for... A little dirty, but not bad.
Still, im Taping wires the side and lining the inside with clear packing tape to keep things nice and as smooth as possible.
Regards,
Vic
Old Apr 14, 2008, 01:48 PM
tail-heavy is offline
Find More Posts by tail-heavy
Permanently Banned
Joined Feb 2008
Originally Posted by doppler1
In theory.
The Canard is essentially an inverse-elevator mounted
near the nose. If you want the nose to go up (pitch up), tilt
your canards to a higher angle of attack, and they generate
lift and push the nose up. They can also be tilted down to
pull the nose down. Many modern canard airplanes can tilt
one canard up and one canard down, for roll (more lift on one side,
less lift on the other).
Some planes have non-moving canards just to generate lift
near the front, or for more lift during landing. These canards
are not used in maneuvering the plane, they just provide
more lift at high angles of attack, and better balance.
tail-heavy is offline Find More Posts by tail-heavy
Old Apr 14, 2008, 06:40 PM
Joined Jul 2006
I was afraid of tape coming off and getting sucked into the fan. I just used a hot glue gun to glue the wires to the side of the duct.
Cool thanks,
Regards,
Vic
Cool Chinese J-10(Depron foam) picture & video aero-dreamworks Parkflyers 12 Aug 02, 2008 07:48 AM
Discussion Chinese J-10 aero-dreamworks Pusher Prop Jet Models 17 Jan 03, 2008 06:07 AM
Discussion Gws Caf J-10 GWS4CEO GWS (Grand Wing Servo) 11 Oct 27, 2007 06:25 PM
Gallery My 1st giant!! Junkers J-10 ScaleBrad Giant Scale Airplanes 46 Dec 03, 2005 04:48 AM
J-10 Proto comming together RCWorks Foamies (Kits) 0 Apr 03, 2005 07:58 PM
