Old Mar 23, 2008, 11:11 AM
LaurenceGough is offline
Find More Posts by LaurenceGough
LaurenceGough's Avatar
Reading, UK
Joined Sep 2007
Installing a clutch, am I doing it right so far? Is there something wrong? Pictures!
Hey guys, sorry for all the car questions just got a lot to sort out..
Please take a look at the attached images, I think I might have installed the clutch spring wrong into the shoe?
Also the nut seems to have it's indent at a different height than the springs.
Also what is the other smaller hole in the flywheel?
And I'm missing a part called the "Tapered Coret" any idea if I need this, if so where can I get it? Is it car specific?
Thank you guys!
LaurenceGough is offline Find More Posts by LaurenceGough
Old Mar 23, 2008, 11:15 PM
jjlaxdog is offline
Find More Posts by jjlaxdog
My Rhino
jjlaxdog's Avatar
Southern California
Joined Oct 2007
I wouldnt really be the one to tell you but it looks good to me
jjlaxdog is offline Find More Posts by jjlaxdog
Old Mar 23, 2008, 11:53 PM
stfuotm is offline
Find More Posts by stfuotm
Joined Feb 2008
springs are on wrong. they shold hold the shoe in not out. flip the spring so that the arch on the inside in the pic is wrapped aound the arch of the shoe, there should be a tail hanging out that goes in the groove on the nut. the extra hole is for a two shoe clutch. you do need a tapered collet, not engine specific but flywheel specific, you should have one in your old flywheel, look closely at the back of the old flywheel. it might work
stfuotm is offline Find More Posts by stfuotm
Old Mar 24, 2008, 06:31 AM
Reading, UK
Joined Sep 2007
Thanks stfuotm! Really, really helpful! I was looking at some videos, although there really hard to see I noticed that the short bit of the spring was sticking in towards the pilot shaft.
It's actually a new second hand car () but it came without some clutch parts.
I'll have to look to see if I can find a collet (Is this the correct name then, not what it says in the manual "Coret"?)
So the little spring bit that is now facing the pilot shaft, has to somehow wrap around the centre nut?
Old Mar 24, 2008, 09:53 AM
stfuotm is offline
Joined Feb 2008
the little bit of spring will hold the shoe in and slide down the outside of the nut when you install the shoes, make sure you install then in the right direction. the leading edge,pointed end opposite the hole, goestoward the rotation of the motor. if you drew an arrow on the fly wheel in the rotation of the motor,should be counter clock wise from the front, the point opposite the hole would be toward the arrow point. the split cone is called a collet not coret. good luck
Old Mar 24, 2008, 10:34 AM
Reading, UK
Joined Sep 2007
I got you, what do you think about the clutch nut I have? It looks like it's the wrong one...
The inside springs (from the clutch shoe) do they have to be in-line with the clutch nut smooth groove?
Thank you for your help stfuotm!
Mommy.. is there something wrong with me ? beefa Slope 21 Dec 03, 2003 10:04 PM
Question Is there something wrong with my Astro deluxe? EP heli freak! Batteries and Chargers 9 Nov 28, 2003 03:21 PM
Is there something wrong with My Kokams 402 charger? Fredrik W Batteries and Chargers 5 Feb 19, 2003 01:03 AM
Nicad cycling-Am I doing it right? tinsink Parkflyers 1 Feb 06, 2002 02:04 PM
Is there something wrong with my RX? Steve Fehr Electric Plane Talk 6 Sep 27, 2001 09:41 PM
