Old Mar 22, 2008, 12:07 PM
KFC is offline
KFC
Find More Posts by KFC
KFC
Blue Foam Master!!!
KFC's Avatar
United States, KY, Hanson
Joined May 2007
Build Log
YF-23 EDF Build
I am beginning my build of my Depron YF-23 from Maybz's plans. I'm hoping to have this all done in about a week, two at most. Setup is as follows:
2 Great Planes Hyperflow Ducted Fans driven by a pair of 370BB brushed motors.
MPI-9145 Brushed Speed Control
Thunder Power 3s 1320 mAh
Berg 4 channel Receiver
2 Hitec HS-45 servos
I went ahead and made my templates and started cutting parts yesterday.
KFC is offline Find More Posts by KFC
Old Mar 22, 2008, 05:53 PM
cyberbipe is offline
Find More Posts by cyberbipe
cyberbipe's Avatar
United States, AK, Fairbanks
Joined Sep 2003
77% Mistake
When I tiled the file to print on my computer I got the size wrong. I decided to cut it out and use it to get the sanding down. It came out so good that I decide to install the follong.
GSW EDF 40 w/ feigao motors
cc 10 amp speed controllers
Blue Arrow micro servos
Hyperion 800mAh 20c 3s1p
It all went toghter pretty easy. I had to cut an access hatch in the bottom as th battery would not fit through the canopy.
cyberbipe is offline Find More Posts by cyberbipe
Old Mar 22, 2008, 07:49 PM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
you know you can run hyperflow brushed motors on 4s bust only
space 1 is offline Find More Posts by space 1
Old Mar 22, 2008, 08:36 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
WOW! whats it gonig to take to get the file for the parts!!!! :O id love to build a bigger one for 70mm fans!
corsair nut is offline Find More Posts by corsair nut
Old Mar 22, 2008, 09:26 PM
smkn951 is offline
Find More Posts by smkn951
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
pdf file? if you're looking for it,it's on the scratchbuilt forum.
smkn951 is offline Find More Posts by smkn951
Old Mar 23, 2008, 08:01 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Sweet. I would like to do this with twin 5800 hyperions in 40s. gotta get the plans......
Joe 1320 is offline Find More Posts by Joe 1320
Old Mar 23, 2008, 08:48 AM
smkn951 is offline
smkn951's Avatar
Joined Jan 2007
http://www.rcgroups.com/forums/showthread.php?t=782198
this where it all started. Maybz is the man
Old Mar 23, 2008, 11:00 AM
KFC is offline
KFC
KFC
Blue Foam Master!!!
KFC's Avatar
Joined May 2007
True, but I can run them on the 3 cell battery I have without damaging them. Neither the motors nor the ESC on my plane will support 4 cell LiPo packs.
Old Mar 23, 2008, 02:13 PM
space 1 is offline
USA
Joined Apr 2007
i was ref two the hyperflow brushed motors not the feigao brushless motors . just trying to help you can use 2s in series for 4s light&cheap brushed motors $10.00
Old Mar 23, 2008, 05:18 PM
KFC is offline
KFC
KFC
Blue Foam Master!!!
KFC's Avatar
Joined May 2007
I'm using the stock brushed motors, not the brushless ones.
Old Mar 23, 2008, 07:20 PM
space 1 is offline
USA
Joined Apr 2007
sorry speed controllers made me think brushless motors any way good luck good job
Old Mar 25, 2008, 11:28 PM
cyberbipe's Avatar
Joined Sep 2003
WOW
I like the channel cutter. What type of bit are you useing. I sanded mine by hand and it took a while.
Michael
Old Mar 26, 2008, 12:43 AM
KFC is offline
KFC
KFC
Blue Foam Master!!!
KFC's Avatar
Joined May 2007
I don't remember the number of the cutter, but you can see for yourself what it looks like.
Not too much further to go. With a little luck, I'll have it finished Wednesday afternoon. Maiden planned for Saturday if the weather cooperates.
Old Mar 26, 2008, 04:14 PM
KFC is offline
KFC
KFC
Blue Foam Master!!!
KFC's Avatar
Joined May 2007
YF-23 Fan Test.
All I have left to do at this point is the linkages and putting the top parts on. I'll have it finished later this evening. In the meantime, here is some video of me testing the fans.
YF-23 Fan Test
Discussion First Edf.... Yf-23 CRASH DUMMIE Foamy EDFs 7 Apr 14, 2008 05:04 PM
Help! FIRST YF-23 edf CRASH DUMMIE Electric Ducted Fan Jet Talk 4 Mar 20, 2008 09:13 AM
Discussion First Edf.... Yf-23 CRASH DUMMIE Foamies (Scratchbuilt) 0 Mar 19, 2008 07:29 PM
Video New Edf Yf-23 Vid corsair nut Electric Plane Talk 0 Sep 27, 2006 12:11 AM
YF-23 for twin EDF-50? ssyed Electric Ducted Fan Jet Talk 5 Jul 09, 2004 09:58 PM
