Old Mar 21, 2008, 11:47 AM
old sunday flyer is offline
Find More Posts by old sunday flyer
Topeka Kansas
Joined Nov 2005
balance connector pin spacing
Has anyone made a chart of pin spacing on LiPoly packs balance connectors? For instance some use 2.5 mm pitch and some use 2.00 mm pitch.
old sunday flyer is offline Find More Posts by old sunday flyer
Old Mar 21, 2008, 11:52 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Kind of but not exactly
http://www.rcaccessory.com/pdf/Batte...on%20Guide.pdf
Most use 2.5 mm spacing , Thunder Power and FMA use 2 mm spacing however the housing are different.
Charles
Old Mar 21, 2008, 12:40 PM
Topeka Kansas
Joined Nov 2005
Thank you very much, that is exactly what I wanted. Everyday flyer, you are a vast treasure of 1/2/3 knowledge. Question, I am building up a 1/2/3 pack for a friend of mine that will use 8-1/2/3 cells paralled for 4600 ma at 28.8 v. What would your preferred charging method?
Old Mar 21, 2008, 01:13 PM
Southern Pride
Well if 120AC is available then a Mastech . If no AC then a Hyperion and I forget the model number. , or a hyperion DUO. This is if charging time / speed matters. An AF 109 A model would be the least expensive but only about 7 amps. or so on 8S . thunder Power 1010C about the same more feacytures but more money than the AF109. Many are going to new Cell Pro 10 but it has not impressed me charge rate / speed wise.
Charles
Old Mar 21, 2008, 01:22 PM
Topeka Kansas
Joined Nov 2005
1/2/3 charging method
At present, am leaning toward putting new 1/2/3 chip in 109. Perhaps we would be better off charging each pack seperately. What is your thought?
Old Mar 21, 2008, 01:27 PM
Topeka Kansas
Joined Nov 2005
1/2/3
I forgot to mention, I have a Lipadapter that I am using on present packs so it may be another option charging 18v packs with a healthy nicad dumb charger.
Old Mar 21, 2008, 01:29 PM
Southern Pride
Charge rate will be maxed out 1P or 2P.2P would be a litle faster as you only have stage 1 and 3 to deal with once.
Note the 7A figure is off the top of my head and may be high. I rarely use my A109 as i have a TP1010, Ballance Pro HD and Cell Pro 10 all of which are a bit faster. Well CP10 may not really be faster but my 109 is loaned out to my son at present.
Charles
TP balance connector e-heli Batteries and Chargers 114 Jul 08, 2008 03:07 PM
Question How to use a multimeter to determine balance connector pin out JoeR Batteries and Chargers 3 Mar 29, 2006 03:19 PM
Li-battery balance connector ilufa DIY Electronics 7 Dec 18, 2005 08:59 AM
Thunder Power TP-205 Pack Balancer "With Balance Connector" boolat Batteries and Chargers 6 Nov 15, 2005 03:21 AM
TP balance connector e-heli Aircraft - Electric - Helis (FS/W) 7 Apr 07, 2005 06:39 PM
