This thread is privately moderated by Odysis, who may elect to delete unwanted replies.
Old Mar 21, 2008, 07:11 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Berkut progress
Friday 21 Mar:
Glassed and mounted fan rails
Balanced fans (lost spinner screw )
Ran fans up, drew up power/current curves. Expect ~750w per fan on 6s, 1100 on 7
Mounted RHS main gear
Pics attached.
Tomorrow, panel gear/fan section. Cut out fan housing, mount fan properly. Panel intake section.
Think about intake plugs, wings.
Odysis is offline Find More Posts by Odysis
Old Mar 21, 2008, 08:01 AM
EDFjet is offline
Find More Posts by EDFjet
Closed Account
Joined Feb 2008
Looking good brother. Will you continue to post the build in this thread, or make a new thread for each stage?
EDFjet is offline Find More Posts by EDFjet
Old Mar 21, 2008, 08:06 AM
Odysis is offline
Joined May 2007
Nah, this is just a scratch pad.
when I start building the other side, I'll thread that one properly.
Old Mar 21, 2008, 08:07 AM
Odysis is offline
Joined May 2007
Note to self:
Mount gear so spring and axle oppose each other; moves gear mount outboard so duct will fit.
Change RHS?
Old Mar 22, 2008, 12:05 AM
Odysis is offline
Joined May 2007
What I wanted to do: Panel gear/fan section. Cut out fan housing, mount fan properly. Panel intake section.
What I did: Paneled gear/fan section, needs trimming. Moved RHS gear, cut out gear slot. cut out RHS lower wing
Missed out on:
Cut fan out (due gear obstruction)
Panel intake section (due time constraints from glue drying on gear)
Mount fan (due fan housing not being cut out)
That'll do for today. Tomorrow: Do what I should have done today.
Note: When installing intake section panel, have gear lowered. Dremel away.
