Old Nov 12, 2012, 07:57 AM
hoverc is offline
Find More Posts by hoverc
Aerodrenaline junkie
hoverc's Avatar
United Kingdom, Wokingham
Joined May 2012
should the fin be made out of same thickness as the rest (in my case, 6mm) ?
hoverc is offline Find More Posts by hoverc
Old Nov 12, 2012, 09:50 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
that will be fine , but the n/b doesn't care, just give it enough fin and rudder area.
chas650r is offline Find More Posts by chas650r
Old Nov 13, 2012, 04:53 AM
hoverc is offline
hoverc's Avatar
Joined May 2012
Sure, have you seen the new mini vapor? could use its innards for a 6" NB!
Old Nov 14, 2012, 04:22 AM
hoverc is offline
hoverc's Avatar
Joined May 2012
which blue wonder motor should I use for a 17 incher?
Old Nov 14, 2012, 05:42 AM
joseico90 is offline
Find More Posts by joseico90
Lets break some props :D
joseico90's Avatar
United Kingdom, Liverpool
Joined Jun 2008
Any of them, it all depends on cell count and prop you gonna use,
-For example the 1300kv works well on two cells and biggish props like the GWS 10x3.8 or 10x4.7
-On 3 cells use 8 inch props
10Amps will be about maximum these motors will take on this winding
-There are other windings, hotter and softer but haven't tried them.
These are the latest ones I've used form HK http://www.hobbyking.com/hobbyking/s...idProduct=2069
joseico90 is offline Find More Posts by joseico90
Old Nov 14, 2012, 05:50 AM
hoverc is offline
hoverc's Avatar
Joined May 2012
I'm thinking about using a 7x4 or 8x3.8 prop on 2s, what do those blue wonders weigh though?
Old Nov 14, 2012, 07:02 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
They're 24g. For that size prop on 2S I'd use the 1700Kv version. I generally run the 1500Kv on 2S and 9 x 4.7 props, or 3S and 8 x 4 props.
Azarr
Azarr is offline Find More Posts by Azarr
Old Nov 14, 2012, 08:42 AM
goldguy is offline
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Why not build a 20 incher? It's a better match for that motor.
goldguy is offline Find More Posts by goldguy
Old Nov 14, 2012, 09:01 AM
hoverc is offline
hoverc's Avatar
Joined May 2012
i meant to but somehow it ended up at 17". Might make my 2nd one a 20"er.... The motor does seem a bit heavy. Any other/smaller motor suggestions?
Old Nov 14, 2012, 03:40 PM
Jefte is offline
Find More Posts by Jefte
Fly Low Fly Fast
Jefte's Avatar
United States, FL, Melbourne
Joined Sep 2010
The same thing happened to me, hahahaha! My 17" is powered by a HK 18-11 2000kv on 7" or 6" props, and a 2s 350 pack. It's a 10g motor but has good power. Not as effective in wind as a blue wonder sized motor though.
Jefte is offline Find More Posts by Jefte
Old Nov 14, 2012, 04:14 PM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
Get any model too heavy then it has to fly too fast. My first 17 incher was powered by the 2211, that's the 16 gram motor. I prefer the AX 1806 now, it can take more of a beating at indoor, is an easy fix or rewind and no broken wire problems.
Old Nov 15, 2012, 02:15 AM
hoverc is offline
hoverc's Avatar
Joined May 2012
jefte, are you peter in the hobbyking discussion thingie for that motor? already had a look at that
but I like a bit of power to hand if needed. I've also seen a axi 2204/54 copy/lookalike that's 19g. would that work?
Old Nov 15, 2012, 07:29 AM
hoverc is offline
hoverc's Avatar
Joined May 2012
no sorry I think that was wessone.
Old Nov 15, 2012, 08:38 AM
ruddym is online now
Find More Posts by ruddym
repeat foam bender
ruddym's Avatar
Canada, ON, Ottawa
Joined Mar 2008
Hoverc, you're in the right neighbourhood with a 10g to 19g motor. An 1811 (10g) scoots along my son's 17-1/2" nicely but not very aerobatically, the 2204 clone (19g) mates with an 8043 prop for gobs of excess power. The 2211 (16g) sits between the two as you would expect -- I use it a lot but I do prefer it rewound. I haven't tried the AX1806 myself but I am sure you can trust goldguy's recommendation, and the circuit board for the leads is nice if you're hard on motors.
It's your choice, any will work.
ruddym is online now Find More Posts by ruddym
Old Nov 15, 2012, 08:55 AM
repeat foam bender
ruddym's Avatar
Canada, ON, Ottawa
Joined Mar 2008
As for making a 20" circle of foam, it's a matter of grabbing a wooden paint stir stick, measuring 10" from the flat end and hammering in a finishing nail. Now jab the nail into the foam and pivot the stir stick while holding an xacto blade against the flat end.
Question What is THE best free plan foamy? 3Dude 3D Flying 28 Feb 18, 2016 09:57 PM
Best R/C Day yet! R/C~Mev Electric Sailplanes 3 Nov 22, 2004 10:35 PM
Best Simulator for Foamy 3D Flying ? knut 3D Flying 10 Nov 02, 2004 12:51 PM
Best AXI for Foamy Factory 44" Extra? Doug Cronkhite 3D Flying 10 Mar 16, 2004 11:11 AM
Q: Best covering for foamy scale warbird? dimple Foamies (Kits) 4 Feb 05, 2003 06:14 AM
