Old Nov 09, 2012, 10:40 PM
ruddym is offline
Find More Posts by ruddym
repeat foam bender
ruddym's Avatar
Canada, ON, Ottawa
Joined Mar 2008
Nice. After you got 'er trimmed at 2:30, she flew like a Nutball should.
ruddym is offline Find More Posts by ruddym
Old Nov 10, 2012, 07:39 AM
joseico90 is offline
Find More Posts by joseico90
Lets break some props :D
joseico90's Avatar
United Kingdom, Liverpool
Joined Jun 2008
progress on Underball #2, some painting before gear install
joseico90 is offline Find More Posts by joseico90
Old Nov 10, 2012, 09:51 AM
hoverc is offline
Find More Posts by hoverc
Aerodrenaline junkie
hoverc's Avatar
United Kingdom, Wokingham
Joined May 2012
thanks, already cut my 6mm one out. It does'nt have a rudder size on the plan. What size do you think is best?
hoverc is offline Find More Posts by hoverc
Old Nov 10, 2012, 11:01 AM
CaptPJB is offline
Find More Posts by CaptPJB
Cypress Texas
Joined Dec 2007
Motor Position
Have built 4 Nutballs all with motors below leading edge of the wing. I put a little down and a little right on them and all flew well using TLAR.
I notice some people put their motors centered on the leading
edge of the wing and some slightly above. Does this make any difference to the flying chracteristics of the Nutball?
Played with dihedral angle 15-25 and settled on about 15-17 as best for me with as large a throw as I could get.
CaptPJB is offline Find More Posts by CaptPJB
Old Nov 10, 2012, 02:27 PM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
I,ve noticed on my 10" NB that I seem to need the CG at 20% to get acceptable flying characteristics. This seem a lot further forward than the larger models I wonder if there is a scale effect coming into play here.
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Nov 10, 2012, 03:38 PM
AndyGadget is offline
Find More Posts by AndyGadget
What goes up . . . Damn trees!
Cotswolds, UK.
Joined Sep 2010
The importance of dihedral.
I've been having fun with my little 14" Nutball, but have never been able to get those fast rolls that are a feature of its performance. Initially I thought it was too small a rudder, so I enlarged it. Then I suspected the little AR6400 servos weren't giving full deflection under load. They were getting a little ropey anyway so I replaced them with 3.7g ones (and an Orange Rx) - No improvement.
Then I went back to first principles (and the early posts here) where Goldguy explains it how it does the trick. As the rudder yaws the 'ball, the underside of the sloping outer face of the dihedral is presented to the direction of travel, raising the outside wing, dropping the inside wing and causing the roll. So more dihedral angle = more dihedral surface = greater rate of roll . . . Simple!
I measured my dihedral which should be 1.75" in a 17 incher (so a touch under 1.5" on a 14") and found mine was just under an inch.
Sooo . . . I would have been too tricky to break the existing dihedral join, so I sliced the wings a bit further out and re-glued with more angle to make a compound dihedral. Result - It now rolls like a Nutball should
Description: Compound dihedral
AndyGadget is offline Find More Posts by AndyGadget
Old Nov 10, 2012, 03:48 PM
didge is offline
Find More Posts by didge
Foam, foam on the range....
didge's Avatar
Adelaide, Australia
Joined Feb 2009
Dimensions are all listed in Post #1, and are also on the plans in Post #16.
Cheers
didge is offline Find More Posts by didge
Old Nov 10, 2012, 04:15 PM
goldguy is online now
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
"I notice some people put their motors centered on the leading
edge of the wing and some slightly above. Does this make any difference to the flying chracteristics of the Nutball?"
Seems not, as long as it's not too extreme like the SnowBall.
goldguy is online now Find More Posts by goldguy
Old Nov 10, 2012, 04:21 PM
flyin' fool
goldguy's Avatar
Joined Jul 2003
Terry
I don't think 'scale effect' plays a roll here, just differences in building, setup, materials and personal CofG tastes. I'm flying my indoor at almost 40%, but I'm flying it all the time, no gliding going on. Right now I've got three in different sizes, all maidened at 25% and none are anyway near each other in CG location, but all rearward, not forward. That's because I'm interested extreme flying and not interested at all in how it glides.
Old Nov 10, 2012, 04:37 PM
flyin' fool
goldguy's Avatar
Joined Jul 2003
AndyGadget:
Polyhedral. Good fix. Glad you got it performing.
Frank
Old Nov 10, 2012, 04:53 PM
UK, Bedworth
Joined Apr 2004
That's interesting, I normally fly other aircraft with a rearward CG but on this one at 25% it was so twitchy to be almost unflyable. I did some dive tests and found that I had to move the CG forward to 20% to get it to be neutrally stable.
I've also noticed that at low speed it gets into a dutch roll rocking and rolling back and forth. I seem to recall that on a normal model that indicates either too much fin and rudder area for the dihedral or too little I can't remember which.
Mine dives in right turns , I think this may be a gyroscopic effect mad worse by the prop being 1/2 of the span.
Don't get me wrong I'm really enjoying flying this model, it's ideal for the rough and tumble of a crowded indoor session and its great for calm mornings outside our house.
Regards
Terry
Old Nov 10, 2012, 10:20 PM
Kalkan is offline
Find More Posts by Kalkan
United States, OR, Eugene
Joined Sep 2009
AndyGadget:
Frank
Definitely polyhedral. (No, you can't drag me back into that one, Frank )
Although Gadget's post, and the subsequent reminder of our little 'hedral debate last spring has got me thinking about a curved wing nutball.
Hmmm... Infinite-hedral. I wonder how various mathematical curves would perform: ellipse, arc, etc....
Don
Kalkan is offline Find More Posts by Kalkan
Old Nov 11, 2012, 12:15 AM
PyroMan is offline
Find More Posts by PyroMan
PyroMan's Avatar
United States, KY, Paducah
Joined Mar 2011
A curved wing, now that would be pretty interesting. You should build one, I'd really like to know how that would work out.
PyroMan is offline Find More Posts by PyroMan
Old Nov 11, 2012, 07:34 AM
Cotswolds, UK.
Joined Sep 2010
Don
I missed that, but thinking more about my Nutball, I'd now be tempted to call it more of a bidihedral.
Andy.
(Trouble is, cutting foam is addictive. I don't build often, but I'll be building soon.)
Old Nov 11, 2012, 05:48 PM
RTHawk is offline
Find More Posts by RTHawk
RTHawk's Avatar
United States, OK, Edmond
Joined Aug 2005
Goldguy: What thickness did you use on the fifteen incher and hotglue or foam safe. Started a fifteen inch out of FFF and the complete fuse foam weighs 32g with no landing gear. Love this design have built several larger ones over the years but trying to get this one to fly in a small gym, standard basketball court with no bleachers on sides. I agree that light is might for close quarters.
RT
RTHawk is offline Find More Posts by RTHawk
Question What is THE best free plan foamy? 3Dude 3D Flying 29 Jul 24, 2016 12:40 AM
Best R/C Day yet! R/C~Mev Electric Sailplanes 3 Nov 22, 2004 10:35 PM
Best Simulator for Foamy 3D Flying ? knut 3D Flying 10 Nov 02, 2004 12:51 PM
Best AXI for Foamy Factory 44" Extra? Doug Cronkhite 3D Flying 10 Mar 16, 2004 11:11 AM
Q: Best covering for foamy scale warbird? dimple Foamies (Kits) 4 Feb 05, 2003 06:14 AM
