Hey Danford1,
I have the same vision of flying this plane in my living room… but for that I think I need to get it in the 40gram range. Do you have any up-down-right thrust built into it? The motor is mounted directly under the wing with no built in thrust angle. I correct for any drift by simply trimming it out. Is that just $Tree foam board without paper? Yes, the paper is peeled off and I re-laminating the foam with gift wrap covering also found at the dollar tree with the brand name Voila. The covering is added on both sides and makes the foam very stiff. In the next version, I plan on cutting out a DTF foam skeleton with covering on both sides to knock off 10 grams off the frame. |
Can you take a few pictures of the under side and lay a ruler on it for dimension references? Can you explain more about the Voila covering and how you attached it? Are those circles holes you cut in the foam or are they decorations drawn on it? Did you measure the foam weight and compare the Voila weight for the same size specimen? Thanks. Danford1 PS I'll probably have more questions later... |
I use 3M-77 adhesive but it will melt the foam if applied directly. So first I lightly spray 3M-77 on the covering and let it sit. After a few minutes the glue is dry but still tacky. I stick the covering on to the foam by stretching it across. Finally I use a covering iron to reactivate the adhesive and shrink the covering. Just be careful with the iron as too much heat will causing warping. Are those circles holes you cut in the foam or are they decorations drawn on it? The circles are suppose to be lightening holes. I wish I had created more of them to add lightness to the entire frame. Did you measure the foam weight and compare the Voila weight for the same size specimen? I didn't compare the weight of the covering vs. that of the foam itself. But it is significantly lighter. Note that the covering also adds strength and stiffness to the frame. |
I must say it has put a smile on my face to see you reproducing my Underball (thought flat) concept, you're going to love it .
I was amazed to see how well you've followed the lines ![]() Work permitting I'll soon finish a Mark II version and do more videos with my existing one. As you said..low and slow is what it does best, and ..for me.. not having to worry about damaging anything on it on crashes is a BIG bonus, this thing just bounces and keeps going, motor-prop always safe back there ![]() One of the last videos with my son at the TX
soon as I saw the underball, I knew I wanted one. It's was just a matter of where it sits on the build queue. I bet there are at least 5 others that have built one and not posted on this thread.
I flew it again this morning. I got a 6 minutes flight on my 2 X 180 mah 1S batteries. It was around 60 degrees at 7 am and totally calm in the field that I fly at on my way to work. It's so wonderful to watch it glide across the baseball field at such a slow pace about 5 feet off the ground. It was just me, the underball and a few geese watching. The geese and I were both smiling. I tried flying it in the evening last night in some mild winds but didn't have much fun. |
| Thread Tools | |
| Question What is THE best free plan foamy? | 3Dude | 3D Flying | 27 | Oct 13, 2009 10:48 PM |
| Best R/C Day yet! | R/C~Mev | Electric Sailplanes | 3 | Nov 22, 2004 10:35 PM |
| Best Simulator for Foamy 3D Flying ? | knut | 3D Flying | 10 | Nov 02, 2004 12:51 PM |
| Best AXI for Foamy Factory 44" Extra? | dcronkhite | 3D Flying | 10 | Mar 16, 2004 11:11 AM |
| Q: Best covering for foamy scale warbird? | dimple | Foamies (Kits) | 4 | Feb 05, 2003 06:14 AM |
