Old Apr 05, 2012, 09:29 PM
jetada is offline
Find More Posts by jetada
United States, WA, Pasco
Joined Aug 2011
Originally Posted by goldguy View Post
That's the one big problem with foamies, they breed like rabbits.
LOL! So true!
I'm just getting into scratchbuilts and I've already got a litter of foamies!
The 20" Nutball is my next build!
jetada is offline Find More Posts by jetada
Old Apr 06, 2012, 06:15 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
last one
Originally Posted by FlyingW View Post
Saw this for sale here in Ezone. Wow.
I got last one ever made. Worked with his son thats's his brother in pic. Ther dad was the pioneer in hot wire foam cuting. Oh we in detroit' One was in movie any one know of it let me know
space 1 is offline Find More Posts by space 1
Old Apr 06, 2012, 09:06 AM
joseico90 is online now
Find More Posts by joseico90
Lets break some props :D
joseico90's Avatar
United Kingdom, Liverpool
Joined Jun 2008
@danford1
@danford1
here you can see the air intake, battery slot, new prop etc.
As I held it in my hands I noticed the motor mount is a bit loose and needs attention.
Next week Lord willing I'll make a start on my next NB.
-Will probably have..
-17" diameter
-1x Blue wonder, 10" prop and 2 cell 350's
-Depron box fuselage, all gear inside as usual.
-Twin rudders
-Bottom side..small rear fins for added directional stability.(maybe)
joseico90 is online now Find More Posts by joseico90
Old Apr 06, 2012, 10:19 AM
danford1 is offline
Find More Posts by danford1
Innovator
danford1's Avatar
United States, MI, White Lake
Joined May 2011
"-1x Blue wonder, 10" prop and 2 cell 350's "
What kv is that BW?
What pitch on the 10" prop ?
Seems hard to believe that tiny motor can swing a 10" prop and not burn up.
I have a BW 1300. I'm still experimenting with 2s -3s, 8" - 9" props.
Thanks for the pictures. I really like the clean look with servos , ESC and wires hidden.
Danford1
danford1 is offline Find More Posts by danford1
Old Apr 06, 2012, 12:50 PM
joseico90's Avatar
Joined Jun 2008
What kv is that BW?
Danford1
-It's a 1300kv (Max Load: 7.5A)
-GWS EP Propeller 10x4.7
-Like you I've also used 8-9" props till now..but..
- On this prop I believe it should be pulling a max of 6.5 Amps, giving 11.5 ounces of thrust on two cells. 3 cells would be too much on this prop.
-This 22" is such a light floater that the battery lasts ages, in the end I land the thing out of boredness, most the time I only use one or two of my four 350's batteries when I go flying
-Yep, me too, I dislike all those bits and cables hanging out of our foamies, hence my fuselages lately.
I forgot to mention that my next Depron NB will incorporate interlocking tabs on the fuselage panels, rudder/s etc
I think it will be quicker and easier than making the fus out of pink foam and having to hollow it etc. Even the battery will be inside , with a hatch for access.
Old Apr 06, 2012, 10:59 PM
OTTOFLYS is offline
Find More Posts by OTTOFLYS
Grand Rapids MI.
Joined Feb 2011
I use a 10x4.7 on my epp yak with a similar motor (auw is just under 8 oz)and it works well on 2s but I wouldn't even consider 3s. its garenteed to fail
OTTOFLYS is offline Find More Posts by OTTOFLYS
Old Apr 07, 2012, 03:53 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
using the same motor on 3 cells with an 8x4 prop gives 14oz thrust at around that 6A
davereap is offline Find More Posts by davereap
Old Apr 08, 2012, 11:46 AM
joseico90's Avatar
Joined Jun 2008
Toy Nutball for a 3 year old boy
Just made this one as a toy for our friend's 3 y/o boy. (from packaging found in a parcel, looks like EPP or similar)
He likes it bless him.
Old Apr 08, 2012, 11:52 AM
kman24 is online now
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
How could he not like it, looks great
Kman
kman24 is online now Find More Posts by kman24
Old Apr 08, 2012, 12:16 PM
joseico90's Avatar
Joined Jun 2008
thanx..so far still in one piece..hope it lasts..easy to repair anyway..there is no glue just tape and double side tape to hold the panels.
Old Apr 08, 2012, 07:46 PM
danford1 is offline
Innovator
danford1's Avatar
Joined May 2011
Where is the CG? 25 % back or further back?
Danford1
Old Apr 09, 2012, 04:11 AM
joseico90's Avatar
Joined Jun 2008
Danford1
Usually at 25%, then adjust to suit if required. Some of us like it a bit rearwards for hovering etc.
Old Apr 09, 2012, 11:13 AM
danford1 is offline
Innovator
danford1's Avatar
Joined May 2011
I meant on the hand toss nutball you made for the child.
Danford1
Old Apr 09, 2012, 02:26 PM
joseico90's Avatar
Joined Jun 2008
Danford1
Didn't bother with that yet..he's just happy playing with it.
Old Apr 09, 2012, 03:47 PM
jaron is offline
Find More Posts by jaron
jaron's Avatar
Switzerland
Joined Oct 2007
This is my variant of the NutBall:
- 7mm Depron
- Diameter 500mm (~20")
- AUW 200g (~7oz)
- Vertical stabilizer enlarged by 20%
- TURNIGY 28-22 1400kv motor
- 28mm GWS motor mount for 10x10mm stick
- GWS DD-8040 8x4" EP propeller
- TURNIGY Plush 10A ESC
- 2S1P 750 mAh LiPo
- 2 x HXT900 1.6kg/cm servos
Thanks, @goldguy!
jaron is offline Find More Posts by jaron
Question What is THE best free plan foamy? 3Dude 3D Flying 27 Oct 13, 2009 11:48 PM
Best R/C Day yet! R/C~Mev Electric Sailplanes 3 Nov 22, 2004 11:35 PM
Best Simulator for Foamy 3D Flying ? knut 3D Flying 10 Nov 02, 2004 01:51 PM
Best AXI for Foamy Factory 44" Extra? Doug Cronkhite 3D Flying 10 Mar 16, 2004 12:11 PM
Q: Best covering for foamy scale warbird? dimple Foamies (Kits) 4 Feb 05, 2003 07:14 AM
