Old Mar 21, 2008, 09:39 AM
buzzbait00 is offline
Find More Posts by buzzbait00
buzzbait00's Avatar
USA, AL, New Hope
Build tip!
I use a poster bord templet and a soldering iron with a pointed tip to cut out all my foam(works great!).For this build,since it's a circle I skipped making a templet........
Take a yardstick cut off about a 12in piece.Drill a hole in one end for a nail and a hole in the other end (at the disired radius)for the tip of the iron.Lay your foam doun on your workbench(not your significant other's kitchen table )then the yardstick.Drive the nail through the foam into WORKBENCH insert hot iron in other end and do a circle Whip's em out in no time.I bet you could do a couple at a time!Drill several iron holes for different sizes.
buzzbait00 is offline Find More Posts by buzzbait00
Old Mar 21, 2008, 10:35 AM
goldguy is offline
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
dekan:
The picture of the LE with the CF flat is of the D-A-L, not the NB. Trust me on this one, the CF flat around the LE is not worth all the work. It took three trys to get it right and I discovered the only way you can accomplish the task is to put a bead of hot melt around the LE, then slide the tip of a Monokote trim iron between the foam and the CF flat as you slowly stick it down. You can't go near CF under tension with heat.
I slice the foam with my blade, push in a flat and then hot melt it into place, smoothing the glue with the iron. I then poke a hole next to the CF and hot melt in one of those single pin horns so the shoulder rests on the CF. (The horns are those cheapo one from HC and for 16 cents each, why bother making my own.) This way the load is tranfered along the CF and not in one spot which would probably fail.
Note.....if I use thicker CF flats, I may have to run the tip of the iron through the slice to make it wider or you'll end up with a bend in the foam.
goldguy is offline Find More Posts by goldguy
Old Mar 21, 2008, 02:33 PM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Thanks Gold.. do You use a variac or dimmer on your hinge cutting soldering iron..... I find mine once fully warmed up is way too hot.
dekan is offline Find More Posts by dekan
Old Mar 21, 2008, 02:39 PM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
I thought I would split a bamboo skewer and hot glue to the leading edge for support. Worked great on the darts. Gives the hint of a tapered LE as well and serves the purpose of protecting that foam from tears since I alway slather some hot glue on the entire LE anyway.
tymbrewolf is offline Find More Posts by tymbrewolf
Old Mar 21, 2008, 04:38 PM
Kokopeli is offline
Find More Posts by Kokopeli
Curiouser and curiouser
Kokopeli's Avatar
Rochester, NY, USA
Joined Oct 2005
I look at my rectangular sheets of foam and the round pattern and think:
Why can't this thing at least be hexagonal, eh?
Walt
Kokopeli is offline Find More Posts by Kokopeli
Old Mar 21, 2008, 05:53 PM
goldguy is offline
flyin' fool
goldguy's Avatar
Joined Jul 2003
dekan: My 20W iron is exactly perfect in the tempature department.....got lucky.
wolf: To stop the rippin' and tearin', I cut a shallow slit in the edges and force a piece of cotton string into it, pull tight and hot melt glue.
walt: If you go over to the Sq2 thread, you'll see lots of different shapes of this idea. The NB is just a super simple version and it worked better than better right from the get go, no changes needed. You'll see that the other shapes are having problems, but this circle works perfectly.
Superior aeronautical engineering or just plain luck? I'm anxious to see if other's will back up my findings or excommunicate me from this form.
GB seems to think it's the highly tappered LE and TE, just like the Smart Dart, that makes it work so well.
Old Mar 21, 2008, 07:55 PM
DavidWent is offline
Find More Posts by DavidWent
Nashua NH
Joined Jan 2007
Hi People,
I took full advantage of my "sickday". I cut and glued a 20" 6mm black epp, and a 17" 9mm white epp. Got as far as control surfaces, horns,rods and servos. No electronics yet. Noticing my supply of Sloper Steves "Plane in a Box" 9mm epp is just about depleted. I placed an order with rcfoam....6 sheets, 12x36, 25 bucks..11 bucks shipping. Here's my delema. I'm a noob, I love working and flying epp for the obvious reasons...I've never worked with fff. Nano seconds after hitting the "Buynow" button, my FPB club insticts hit. How can I justify buying epp when for less money you get so much more with fff?
David
DavidWent is offline Find More Posts by DavidWent
Old Mar 21, 2008, 09:22 PM
Joined Feb 2007
That is why I just go to the dollar store and buy a couple sheets of readiboard. I have no place to store and $1 will make at least one of these little fun things. It does crumple a little since it is similar to depron. I figure I will get some EPP when I have one that I want to paint nice and keep for a while.
Old Mar 21, 2008, 11:11 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Originally Posted by DavidWent
... How can I justify buying epp when for less money you get so much more with fff?
To me whether EPP is worth it or not depends.
If you spend a lot of time on the same model (where building a new copy of a totaled model counts as the same model)
and you tend to spend a lot of time repairing
(crash often, slow at repairs, and/or need to do extensive repairs, including complete rebuilds),
then EPP may save you time (need less time to do repairs) and money
(less broken parts to replace).
I am one of these people.
If on the other hand, you want to try different models quickly
(so will be building soon even if nothing gets broken)
and you don't spend a lot of time repairing (don't crash often, can make repairs quickly, and/or tend to only have minor damage on a crash),
then EPP may not be worth it.
flying-llama is offline Find More Posts by flying-llama
Old Mar 22, 2008, 01:03 AM
teched88 is offline
Find More Posts by teched88
teched88
SW PA
Joined Feb 2007
EPP is always worth it.
fixes are almost non noticable.
Still have all my planes after a year of crashes and they still look good
I should post pics of some of my planes after low to ground air manuvers, dorks, oopsies, trees, lamp posts, combat strikes........
fly them like you stole them cause the fear of carnage is gone.
teched88 is offline Find More Posts by teched88
Old Mar 22, 2008, 01:18 AM
Boxhead is offline
Find More Posts by Boxhead
Look outside the Square
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Hi David, as quoted here EPP is extremely durable. The hip pocket is always the key on how you do things. Value wise EPP I feel is great value. To make the EPP go a bit further you can always build a composite. If a flate plate PBF type, the wing can be made from( EPP ) and fin and elevator Depron etc. Profile foamy like GB's FFF P-51, Fuse ( EPP ) and wings Depron etc. It stretches the EPP out a little bit more while using cheaper foam for your surfaces. Good Luck with it all.
B x
Boxhead is offline Find More Posts by Boxhead
Old Mar 22, 2008, 06:02 AM
jkarnacki is offline
Find More Posts by jkarnacki
USA, CA, San Carlos
Joined Nov 2007
My EPP came from rcfoam today and I can't wait to try this stuff. I got some 9 mm sheets and it's so damn rubbery! Couldn't believe my eyes/hands. Sure is a change from Depron. If I have time I will start my NutBall tomorrow
- Jeff
jkarnacki is offline Find More Posts by jkarnacki
Old Mar 22, 2008, 08:27 AM
arniep is offline
Find More Posts by arniep
metro Detroit, MI
Joined Jan 2007
Has anyone posted any videos yet of the NB in action?
arniep is offline Find More Posts by arniep
Old Mar 22, 2008, 08:33 AM
Nashua NH
Joined Jan 2007
All good points. Thanks guys!
Jeff, how long did your order take? I placed my order yeserday
Thanks again
David
Old Mar 22, 2008, 09:13 AM
Sixter is offline
Find More Posts by Sixter
Flying Models for 52 Years!
Sixter's Avatar
Georgia, United States
Joined Oct 2002
Today I am going to the LHS to pick up a motor, esc and two battery packs for my 20" NB. Getting a E-Flight Park 300 Outrunner, E-Flight 10 amo ESC, and I have the choice of either a 730 mah Thunder Power or a 800 mah E-Flight Lipo 2 cell packs. Question, what prop would you guys recommend, the Park 300 prop saver is said to favor the APC props. And which battery pack would yall favor!
Bobby
Sixter is offline Find More Posts by Sixter
Question What is THE best free plan foamy? 3Dude 3D Flying 29 Jul 24, 2016 12:40 AM
Best R/C Day yet! R/C~Mev Electric Sailplanes 3 Nov 22, 2004 10:35 PM
Best Simulator for Foamy 3D Flying ? knut 3D Flying 10 Nov 02, 2004 12:51 PM
Best AXI for Foamy Factory 44" Extra? Doug Cronkhite 3D Flying 10 Mar 16, 2004 11:11 AM
Q: Best covering for foamy scale warbird? dimple Foamies (Kits) 4 Feb 05, 2003 06:14 AM
