Espritmodel.com Heli Air
Old May 19, 2008, 10:35 AM
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Humm???? Dueling deltas..........
One thing about deltas is, they laugh at the wind. They can't be beat for windy day flying when everything else is grounded.
goldguy is offline Find More Posts by goldguy
Old May 19, 2008, 11:37 AM
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Gold I agree about windy weather flyers none better.....heres the tally so far Superfy,Hyperflea,Superflea,Mini Arrow and a tractor delta.
Does a Gpw Vector X count as a delta ? Cos I got one.
I will post a group photo as soon as the wind drops and the light improves.....
dekan is offline Find More Posts by dekan
Old May 19, 2008, 11:54 AM
ProBro #2797
Mchone, Jake's Avatar
Behind my Tx!
Joined Dec 2003
What wing span for a rimfire 370 outrunner setup and what span for an E-Flight 250 OR setup?
Mchone, Jake is offline Find More Posts by Mchone, Jake
Old May 19, 2008, 12:14 PM
MacBeth, SC
Joined Aug 2007
Hi Folks,
I want to place my first order with Lazertoyz today. My current 30" Nutballs with the
GWS 300 C w/D gearing are still flying great. But almost all of my motors are suffering
from chipped plastic gear drives. I'd like to drop down to a 20" or so nutball. Smaller
pieces/parts to assemble/decorate and less weight when I do pile one in.*G* What
motor/battery/prop combo will work well? I've heard good reports from the 24g blue
motors. Their combo comes with an option of 10 or 15 amp esc. Any suggestions
would be most appreciated. Warm regards, Jim
(Lazertoys) http://www.ncweb.com/biz/dan/
Jim Hatch is offline Find More Posts by Jim Hatch
Old May 19, 2008, 12:21 PM
dekan's Avatar
London, UK
Joined Nov 2006
A Blue Wonder will work fine in a 20" NB.
You don't need max power so you might as well get the 1300Kv wind and use a 8 x 4 GWS DD prop, 500mA battery 2 or 3s, 10A or 15A Esc your choice. AUW 6-7oz
Old May 19, 2008, 02:16 PM
MacBeth, SC
Joined Aug 2007
Thanks Dekan,
Advice much appreciated! I'm going to get my order off right away.
Can't wait to play with the new toys.*G* Warm regards, Jim
Old May 19, 2008, 02:44 PM
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
VectorX, OH Yes!
And forgot about gpw’s StealthSport, that counts too.
Express . . . amusement in the wind . . . but not in the hands of a novice.
chaosMurphy is offline Find More Posts by chaosMurphy
Old May 19, 2008, 03:35 PM
dekan's Avatar
London, UK
Joined Nov 2006
Imo the Steath Sport counts....
Plenty of power with 1300Kv BW Jim... no need for the Higher Kv versions which are happier on 7" or smaller props....
You will get better Hi Alpha flight and hovering with the 8" prop and you always have the option of using a 9" prop ..It's all about thrust.
Old May 19, 2008, 04:01 PM
Joined Feb 2007
Dekan, what delta is your picture. I need to finish my hyperflea Just gluing the stabs and canopy and installing the gear is all that is left. Been that way since December. Hand launching just isn't the same for me, but wind keeps me from flying alot.
Dekan, I was thinking for that with some landing gear and a working rudder, that tractor delta might be something to try for ROG as either a rudder or turning LG makes for more fun.
For me, the BW on the 20" was not the same as a 16g motor on the 17". Plenty of power, just not as zippy.
tymbrewolf is offline Find More Posts by tymbrewolf
Old May 19, 2008, 04:31 PM
praymond's Avatar
New Hampshire-seacoast area
Joined Jun 2005
Jim Hatch,
I'm using the BW from lazertoyz, and their 10A esc, also their red covered 900 2S battery on my 20" NB. Spinning either the 9050 DD or 9047 SF prop. Plenty of power at only 6.7Amps or so on the 2S.
If it's really windy I put on their 900 3S w/9050 prop and it's insane!
Paul
praymond is offline Find More Posts by praymond
Old May 19, 2008, 05:03 PM
dekan's Avatar
London, UK
Joined Nov 2006
Tymbe.Your 17" is probably quite nippy but so is my 17" R1 with its Hacker A10-15s
But as Jim requested some advice on a 20" NB... the 16g motor would not be my choice for a 20"
I have several BW1300Kv...my experience with them is pretty much the same as Paul's
The delta and several other versions of the same idea came from http://www.wattflyer.com/forums/showthread.php?t=16298 and several other similar threads on this site...But my dimensions are based on Tlar
Old May 19, 2008, 05:33 PM
MacBeth, SC
Joined Aug 2007
Thanks all for the information. Very much appreciated. I have three of the blue
wonders on the way with some 500 mah lipo's. Already have some 650 and 900's.
Got a couple of esc's and some spare motor shafts. Also a bunch of props and
misc hardware. Should be in pretty good shape soon. As long as I can keep a
Nutball in the air and enough hardware to work on a few more scratch builds, I'll
be a happy camper. Thanks again! *G* Warm regards, Jim
Old May 19, 2008, 05:42 PM
Joined Feb 2007
Wasn't knocking the BW, its a very good motor on 2s but haven't done on 3s as no 3s batteries because I haven't invested in a balancing charger so I took the BW off for something that is a little more powerful without much weight trying to stay 2s.
I have only done the 1200Kv on BW 2S, so I wonder how the 1700Kv would compare to its little cousing the 15-17g models as they turn around 1700Kv.
Sometime this summer I need to invest in a balancer and some 3S so I can try "insane".
Old May 19, 2008, 05:51 PM
Joined Dec 2006
dekan,
Please share dims on your ‘tlar KOSH’
TNX
Old May 19, 2008, 08:37 PM
flyin' fool
goldguy's Avatar
Joined Jul 2003
I don't have either, but consider the largest diameter, lowest pitch prop they will turn on 2S or 3S, which ever you have.
A 17" 5-6 ounce NutBall likes a 7 to 8 inch prop and a 20" 7-8 ounce NutBall likes a 9 to 10 inch prop. If you keep the weight low and the thrust high, you'll have pure joy.
Question What is THE best free plan foamy? 3Dude 3D Flying 27 Oct 13, 2009 10:48 PM
Best R/C Day yet! R/C~Mev Electric Sailplanes 3 Nov 22, 2004 10:35 PM
Best Simulator for Foamy 3D Flying ? knut 3D Flying 10 Nov 02, 2004 12:51 PM
Best AXI for Foamy Factory 44" Extra? dcronkhite 3D Flying 10 Mar 16, 2004 11:11 AM
Q: Best covering for foamy scale warbird? dimple Foamies (Kits) 4 Feb 05, 2003 06:14 AM
