Weakened props and wobblies need lots of care and attention. I've seen lots of scary close calls over the years. Attaching a prop with an 'O' ring, no matter what the material is it's made from, is not really safe to begin with. Keep it to 70 watts max, do lots of inspections and use surgical tubing 'O' rings if possibe. Neoprene 'O' rings are meant to be compressed, not stretched and rubber bands arn't made from rubber.
I've had all three materials fail from old age and the props drop off on models just hanging from my shop ceiling. I no longer leave props on my models in storage mode just to make sure when the get do used they get a fresh attachment. |
Thanks GOLDGUY for the cg info. Now I have to come up with some kind of landing gear set up. Im torn between trying to enlarge the original one that my 17 inch had or come up with something new. I was tossing around the idea of something close to the bugs landing gear from light flite. Any one try something other then mounting to the motor mount plywood.
Canada, QC, Montreal
Joined Nov 2008
Hi Rich,
this is what im using for my 3rd NB. I designed my NB so it looks like a fat p51d mustang now. The landing gear really makes it look like one. I guess it's a bit heavy for NB standard, but it's really strong. |
I've used Dave Reap's two-wheel LG described in pictures 1 and 2 here on my Nutballs.
Built with one continuous piece of .032 music wire (for small size NBs, e.g. 17" dia) and with the wheels at front as shown, it can spring back like the Bug's landing gear does on heavy landings. It's easy to make and uses no carbon fiber. Mine's held on with a piece of skewer at the apex. If you decide you want the wheels further back for better ground handling and/or if you want to stiffen up the LG a bit, simply mount it with the wheels at the back instead of at the front. Works just as well that way. BTW, I found the tripled foam at the front of the NB's spine is strong enough, without adding the plywood reinforcement shown, particularly if you go over the tripled foam area with some packing tape. I don't have a very good picture handy, but you might get the idea from this one borrowed from another of my posts: link |
Where this particular LG design is concerned, flimsier is better in terms of springing back from the apex attachment point. 1/8" might be too stiff, I don't know. Go with TLAR method.
"It don't mean a thing if it ain't got that spring" ![]() P.S. Rich, for bigger Nutballs like you're building, I would go with the plywood reinforcements as originally described by Dave R. Sorry, I didn't see what size you were building before I posted about omitting those. |
Absolutely, smaller always flys faster, no matter the design. A 34" span is 6.3 sq. ft. and even if you built it at two pounds RTF, the wing loading is only 5 oz. per sq. ft. and that's nothing for a wing that size. If you check out Dave's big ones, he get that size down to under 3 oz. per sq. ft., then you've really got something.
A word of caution here, pick the right servo for the right job at hand. I'm using GWS 19g Park servos on my 17 ounce 26" because the 9 grams Naros were not powerful enough or have strong enough gears. I realized that after three failures, once stripped gears and twice I ran out of control movement because the servos lacked the power. |
| Thread Tools | |
| Question What is THE best free plan foamy? | 3Dude | 3D Flying | 27 | Oct 13, 2009 10:48 PM |
| Best R/C Day yet! | R/C~Mev | Electric Sailplanes | 3 | Nov 22, 2004 10:35 PM |
| Best Simulator for Foamy 3D Flying ? | knut | 3D Flying | 10 | Nov 02, 2004 12:51 PM |
| Best AXI for Foamy Factory 44" Extra? | dcronkhite | 3D Flying | 10 | Mar 16, 2004 11:11 AM |
| Q: Best covering for foamy scale warbird? | dimple | Foamies (Kits) | 4 | Feb 05, 2003 06:14 AM |
