Old Mar 20, 2008, 06:51 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Plans... Next up!
Gene Bond is offline Find More Posts by Gene Bond
Old Mar 20, 2008, 06:57 AM
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
What a blast, TNX
chaosMurphy is offline Find More Posts by chaosMurphy
Old Mar 20, 2008, 07:02 AM
gpw
“There’s no place like Foam”
gpw's Avatar
Joined Jul 2002
We tried this concept some time ago ..Works GREAT, even with the old (heavy) brushed motors and Nimh batts.. With the new (lighter,more powerful)stuff ,it should be TERIFFIC!!! I'm building a NutBall .. you bet !!! Thanks Gold!!!!!!!!!!!!
Ps. we found the taller the rudder the more it acted like ailerons...
gpw is offline Find More Posts by gpw
Old Mar 20, 2008, 07:25 AM
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Very nice Frank, exquisitely simple.
Tony
Tony65x55 is offline Find More Posts by Tony65x55
Old Mar 20, 2008, 08:07 AM
Joined Feb 2007
Thanks Frank. The only thing I might add from my experiments and what I learned from Gene yesterday is the motor mount placement. I believe it needs to be at or above the wingline. Do you agree? I think that is what I have been doing wrong with my squirts or I would be touting them as the perfect plane. I am glad you finally got up a thread. I also believe your rudder and your amount of dihedral will be improvements. The 17" size is great to throw on your front seat.
tymbrewolf is offline Find More Posts by tymbrewolf
Old Mar 20, 2008, 08:31 AM
ProBro #2797
Mchone, Jake's Avatar
Behind my Tx!
Joined Dec 2003
So its just rudder and elevator!
Cool!
thogh, I might add elevons later...
Mchone, Jake is offline Find More Posts by Mchone, Jake
Old Mar 20, 2008, 08:37 AM
metro Detroit, MI
Joined Jan 2007
Looks great! Looking forward to seeing some vids of it flying.
Thanks!
arniep is offline Find More Posts by arniep
Old Mar 20, 2008, 08:43 AM
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Tym. I have never had any trouble with the thrust line on Darts or my R1
TL on the Dart is about 3/4" below the wing.....R1 is centered.
The main thing I have found with Darts and similar is to have 3 to 5 degrees down thrust
dekan is offline Find More Posts by dekan
Old Mar 20, 2008, 10:32 AM
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Originally Posted by wrugen
Kinda a newby to Darting, Just finished # 6! So I need a little help. I "discovered "Hobby City and am now Platimum. Cant beat em. The 3.7 servos they sell are EM.
In your list you used EU 3.7 servos. Are these the same or did you find a better source than HC?
Thanks for the help. Just got a batch of .9 hot cut EPP. Time to build a round one.
It was late, yup, they're EMs.
goldguy is offline Find More Posts by goldguy
Old Mar 20, 2008, 10:41 AM
flyin' fool
goldguy's Avatar
Joined Jul 2003
Originally Posted by Flywellnz
I have my EPP ready to cut!
How are you doing the control horns? (close up pic would be great)
I use those el cheapo single pin ones from HC. I first cut a slit into the EPP, glue in a piece of CF flat, then poke a hole right next to it, so when the hindge is pushed in, the shoulder rests on the CF....all done with hot melt glue and a Monokote trim iron.
Before I just soaked thin ply with CA and cut them out with sissors, making the wide enough where they are glued to add stiffness to the flying surface.
Old Mar 20, 2008, 10:46 AM
flyin' fool
goldguy's Avatar
Joined Jul 2003
Originally Posted by FirstShirt
Frank, I love the Dart and I thought the R1 was even better. Can't wait to try your NB. I love your innovation on the fuse bracing and the v-grove construction technique. The latter sounds like something I'll want to practice before giving it a try on a larger piece of epp. Thanks! Pat
Pat: I posted some pixs of how it's done in the 'EPP tricks n' tips'. It's works like a charm and takes only seconds to do all the grovin'. You get the hindges and the dihedral joint perfect eveytime.
Frank
Old Mar 20, 2008, 11:00 AM
flyin' fool
goldguy's Avatar
Joined Jul 2003
Gene: How many beers do I owe you now? Thanks again.
Old Mar 20, 2008, 11:09 AM
flyin' fool
goldguy's Avatar
Joined Jul 2003
Cool!
That's easy, to make an elevon flattie fly aerobatics, they're supposed to do that. When the other guys see your NutBall fly, they wouldn't believe you can do all that with just rudder and elevator. That's what make a Dart or NutBall unique and special.
Old Mar 20, 2008, 11:15 AM
Alberta, Canada
Where's the video?
dean_85 is offline Find More Posts by dean_85
Old Mar 20, 2008, 11:16 AM
Joined Feb 2006
Hey, I know late.
Thanks for helping the new guy!! As soon as I get my Purple Bill Lowe Ghost done Ill be using Genos plans!
Thanks again for the help and the thread.
wrugen is offline Find More Posts by wrugen
Question What is THE best free plan foamy? 3Dude 3D Flying 27 Oct 13, 2009 10:48 PM
Best R/C Day yet! R/C~Mev Electric Sailplanes 3 Nov 22, 2004 10:35 PM
Best Simulator for Foamy 3D Flying ? knut 3D Flying 10 Nov 02, 2004 12:51 PM
Best AXI for Foamy Factory 44" Extra? dcronkhite 3D Flying 10 Mar 16, 2004 11:11 AM
Q: Best covering for foamy scale warbird? dimple Foamies (Kits) 4 Feb 05, 2003 06:14 AM
