Old Mar 19, 2008, 01:21 PM
everglades is offline
Find More Posts by everglades
From Bergen County, NJ
everglades's Avatar
Ridgewood, NJ
Joined Dec 2006
Live Steam Powered Brooklyn Tug
Well thanks to several people on rc groups I was able to find a fiber glass Brooklyn tug by Dumas. I chose this model because it was steam powered, and large enough to accommodate the boiler and steam engine. I also love the round smoke stack and shape of the hull.
The engine will be a Graham TVR1A 2 cylinder engine. I chose this engine because the kit does not need any machining and it has the ability to reverse. The kit was allot of fun to build only requiring polishing and lapping of some critical surfaces. The rest was just screwing it all together carefully... lots of small screws, bushings and levers.
Graham was a pleasure to deal with. During the build I lost a tiny bushing and a replacement was sent right away free of charge.
The Dumas Kit is another story. the quality of the wood in the kit is just like I had been warned... marginal. Its a very tedious kit to build, since the deck and superstructure are made out of wood ribbing that doesnt necessary fit well together. In contrast, the Dumas Jersey City Tug, which has far less wood and more expanded PVC goes together much better.
This is only my 3rd boat. I started with the Tito Neri which is also posted on this board.
Here are some pictures... more to come.
Please be sure to post any suggestions, comments or criticisms. Thanks to all.
Fernando
everglades is offline Find More Posts by everglades
Old Mar 19, 2008, 01:28 PM
everglades's Avatar
Ridgewood, NJ
Joined Dec 2006
Pictures
Here are the pictures of the boat
Old Mar 19, 2008, 01:32 PM
everglades's Avatar
Ridgewood, NJ
Joined Dec 2006
Engine Pircutes
Here are the pictures of the engine.
Old Mar 19, 2008, 02:20 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
United States, MI, West Bloomfield Township
Joined Dec 2004
Looks like you're diving right in and making progress!
patmat2350 is offline Find More Posts by patmat2350
Old Mar 19, 2008, 02:36 PM
vett is offline
Find More Posts by vett
USA, NY, Mahopac
Joined Dec 2002
Looks good Fernando I know you will do it justice.
vett is offline Find More Posts by vett
Old Mar 19, 2008, 07:32 PM
everglades's Avatar
Ridgewood, NJ
Joined Dec 2006
Steam Plant
I have not found a boiler yet that will fit just right. Any suggestions would be appreciated.
Old Mar 19, 2008, 07:54 PM
peconic steam is offline
Find More Posts by peconic steam
peconic steam's Avatar
Long Island, NY
Joined Dec 2007
Fernando. I used a Cheddar Models Puffin horizontal Vll boiler, p/n 10156 with the identical hull - engine setup. Plenty of power, adequate steaming time (20 - 25 min.)The boiler in mine is installed with the stack opening towards the stern, or sight glass forward. It's good to see you're underway with this project...
peconic steam is offline Find More Posts by peconic steam
Old Mar 20, 2008, 05:09 AM
HS93 is offline
Find More Posts by HS93
Rainhill UK
Joined Sep 2007
If possabil go for a horizontal boiler, as there is a lot of weight high up on that tug and if you can keep the weight down it will help stop roll, there was a nice version that sailed at the cheddar club and it sailed and looked the part.
peter
HS93 is offline Find More Posts by HS93
Old Mar 20, 2008, 07:42 AM
steamboatmodel is offline
Find More Posts by steamboatmodel
steamboatmodel's Avatar
Toronto, Canada
Joined Nov 2004
My personal preference would be to build one, failing that one of ACS engineering's boilers.
http://www.acs-engineering.co.uk/index.htm
Regards,
Gerald
steamboatmodel is offline Find More Posts by steamboatmodel
Old Mar 21, 2008, 08:13 AM
everglades's Avatar
Ridgewood, NJ
Joined Dec 2006
How would I go about purchasing an ACS or Cheddar boiler. I cant seem to find them on the net.
Old Mar 21, 2008, 08:20 AM
Toronto, Canada
Joined Nov 2004
ACS used to be be reached through this link http://www.acs-engineering.co.uk/index.htm I will try to find out what is wrong with it. Cheddar went out of business a number of year ago.
Regards,
Gerald
Old Mar 21, 2008, 08:26 AM
vett is offline
USA, NY, Mahopac
Joined Dec 2002
you could try http://www.yesteryeartoys.com
Old Mar 22, 2008, 10:01 PM
Brooks is offline
Find More Posts by Brooks
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
When I last talked to Sandy Campbell of ACS, last spring, he was having trouble shipping his metal bits to the US. If I remember right, homeland security was tearing up his packages, then either dumping them or sending them back to him, at his cost. He was discouraged, needless to say.
If you can get product from him, his work is superb. I have a vertical boiler he made for my Krick Patricia, and it's a beautiful piece of work (plus steams very well).
Brooks is offline Find More Posts by Brooks
Old Mar 23, 2008, 09:53 AM
everglades's Avatar
Ridgewood, NJ
Joined Dec 2006
More progress on hull and superstructure
Here are some more pictures detailing the progress.
Old Mar 23, 2008, 10:35 AM
frankg is online now
Find More Posts by frankg
Joined Dec 2004
EVERGLADES- I have a stupid question after viewing you pictures. Why do you have a right angle bell crank hooked up with will be a drag link to the tiller arm. Could you not just put the tiller a 90 degrees and be done with it ? There would be less chance of slop or any thing coming loose.
frankg is online now Find More Posts by frankg
Discussion Steam plant for Brooklyn Tug peconic steam Steam Boats 16 Jan 07, 2010 03:52 PM
Discussion Steam powered tug: Midwest Liberty stickers11 Scale Boats 3 Mar 01, 2006 04:01 PM
