Old Mar 18, 2008, 12:01 PM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Setting up a 2 aileron 2 flap F5B on 6channels w/ Futaba 9C
I consider myself the local expert but can't see a way to program a 4 servo wing with crow and variable flaps using only a 6 channel reciever and the Futaba 9C.
Want to plug in like this;
1- Aileron 1
2- Elevator
3- Motor
4- Aileron 2 or Flap 2 (no rudder on this plane)
5- Aileron 2 or Flap 2
6- Flap 1
Easy to do using a 8 channel receiver but what about a 6?
Evan D is offline Find More Posts by Evan D
Old Mar 18, 2008, 02:01 PM
Heather is offline
Find More Posts by Heather
Hastings, Hawkes Bay, New Zealand (Aotearoa)
Joined Feb 2000
Your problem will be with channel 4 which is rudder by default. You will need to create a mix that nulls this channel out (Make 4 both master & slave). Then you can mix the correct control back to this channel.
I've done a similar thing in the past but its not easy
Heather
Heather is offline Find More Posts by Heather
Old Mar 18, 2008, 02:48 PM
flying evader is offline
Find More Posts by flying evader
Back in the game
flying evader's Avatar
United States, TX, Frisco
Joined May 2006
This might help. As Heather points out, you will need to use the channel 4 as one of the flaps channel (instead of ch7 as described in the below link). Setup ch4 to have ZERO travel (so the movement of rudder stick won't affect it) and then mix it as you would mix in ch7... But you have to adjust travel so its zero (this doesn't affect movement for mixes)
http://www.futaba-rc.com/faq/faq-9c-q787.html
flying evader is offline Find More Posts by flying evader
Old Mar 18, 2008, 04:01 PM
Evan D is offline
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
I did mix rudder to itself to cancel the rudder stick movement but when I mix flaps from channel 7 to channel 4 it doesn't move the channel, I can get it to do this for the other channels but it's like 4 is a master channel and it won't let me mix to it.
I am able to mix the whole thing so I have flaps and speedbrakes on switch C using the Acro programing but doing it this way my crow is not on a slider or throttle stick and variable.
I'd like to use the Glider-C programing and mix 7 to 4 so I can have crow variable and then put two position flaps on swith C.
Thanks!
Old Mar 19, 2008, 08:19 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Just use a Berg 7..
Why make life more difficult?
..a
Old Mar 19, 2008, 09:08 PM
Evan D is offline
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Because I have a Hitec 6 channel new going ito it... I could pull a 8 channel out of something else and put the 6 in what ever I take it out of...
I'd like to use the 6 if I can though.
Old Mar 20, 2008, 06:07 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
It was fooling with this kind of stuff that made me give up Futaba and switch to the EVO..
..a
Old Mar 20, 2008, 11:49 AM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Thanks!
Can you mix 7 to 4 if you don't cancel out the rudder as you have done?
If you can mix 7 to 4 with rudder enabled, try to cancel out the rudder stick movement with rudder travel adjust.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Mar 20, 2008, 12:05 PM
Evan D is offline
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
After too much beeping I got it all done. I have the flap and crow activated with switch C.
Up is nothing.
Middle is flaps on with elevator mixed in, adjustable by the left slider.
Down is crow. Ailerons, flaps, and elevator are at fixed points.
Throttle stayed on the throttle stick.
Old Mar 20, 2008, 02:18 PM
Back in the game
Joined May 2006
I don't like using the 3 point switch with the 9C.. It is on the same side as the ele and aile. Don't want my right hand off the stick when landing..
I have flaps on one switch on the left hand and crow on the other.. Rarely i use crow, usually 90 degrees flaps will do the trick..
FWIW
Old Mar 20, 2008, 03:19 PM
Evan D is offline
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
I don't have an issue using the switches with my right hand as I am used to doing so with the modes on my helos...
Discussion Setting up a Futaba T7C 2.4 for DLG martin kopplow Hand Launch 6 Jun 12, 2008 08:49 AM
Question Setting up Honey Bee King 2 with EK2-0704A servo? grahamwhiteman Micro Helis 1 Jan 02, 2008 10:20 AM
Alert Help Needed Setting Up My First CP Heli! Also, Questions On Hitec Eclipse 7...! Minimole Micro Helis 55 Aug 25, 2005 08:19 PM
Yippee! Setting Up 9 Hour 100 ma Slow Charge on AF 109 hall woo Batteries and Chargers 116 Jan 26, 2005 12:01 PM
Aileron and Flap Mods on the Mini Telemaster. boomerace Parkflyers 17 Jan 27, 2004 09:25 PM
