Old Jan 07, 2003, 01:22 AM
stegre is offline
Find More Posts by stegre
CaliforniaSailplanes.com
stegre's Avatar
So California
Joined Dec 2002
EPP Foam sheets Wholesale
Where in California ( or anywhere else) can I buy EPP at a "reasonable" price?
Steve
stegre is offline Find More Posts by stegre
Old Jan 07, 2003, 01:42 AM
ke6guj is offline
Find More Posts by ke6guj
ke6guj's Avatar
Rialto, CA
Joined Jun 2002
Steve, how much foam are you talking about?
If you want a lot, go to the source. $400 minimum I heard.
EPE Packaging Inc., Southern California
Orange, CA 92865, USA
Phone: (714)279-1622
http://www.epepack.com/
Marko Foam in Corona sells EPP with a $100 minimum the last time I talked to them. a 1.3# block 4"x3'x4' was around $30. 1.9# available at additional cost.
Phone: 1-800-8marko1 or 909-272-4700
If that is still more foam than you need, then contact Flyingfoam.com or Daves Aircraft Works. Both can hook you up with smaller quantites.
Jack
ke6guj is offline Find More Posts by ke6guj
Old Jan 07, 2003, 02:32 AM
McGrrr is offline
Find More Posts by McGrrr
McGrrr's Avatar
Cedar Park, Texas, United States
Joined Jul 2002
http://www.rpvi.com/
http://www.jspi.com/
McGrrr is offline Find More Posts by McGrrr
Old Jan 07, 2003, 10:43 AM
Vinnya42 is offline
Find More Posts by Vinnya42
Lifes 2 short, go sloping
colorado @ 5500feet
Joined Sep 2001
I have used foam fly, it is cheap by mail.
http://www.flyingfoam.com/foamsheet.html
Vinnya42 is offline Find More Posts by Vinnya42
Old Jan 07, 2003, 12:25 PM
SchiessCo is offline
Find More Posts by SchiessCo
SchiessCo's Avatar
North Hills
Joined Nov 1999
Check with the folks at Superior Balsa.
Pete
SchiessCo is offline Find More Posts by SchiessCo
Old Jan 07, 2003, 12:32 PM
McGrrr is offline
McGrrr's Avatar
Joined Jul 2002
I forgot about Flyingfoam.com. They do have great prices.
Old Jan 07, 2003, 12:42 PM
ke6guj is offline
ke6guj's Avatar
Rialto, CA
Joined Jun 2002
Yup, Bob at Flyingfoam.com has some good pricing. I have had him cut me a couple sets of EPP cores, and have purchased some blocks of 1.9# EPP for scratch fuses.
Jack
Old Nov 14, 2006, 05:38 AM
saucerguy is online now
Find More Posts by saucerguy
saucerguy's Avatar
United States, WA, Battle Ground
Joined Dec 2005
shows promise
http://www.jspi.com/ is showing as the best resource from the www standpoint, I'll give them a call and see what they are requiring volume wise to get the costs down, looking at foamfly.com, it's just nowhere near the ballpark to cost effectively build with the stuff at all so would hold off unless money isn't an issue, I'm also comparing it cost wise to eps or the epp arf's and replacement parts currently on the market, will take the 25.00 striker replacement body for example at the lhs, along the eps, the fact you can cheaply replace it without having to pay for shipping since it's off the shelf, cannot see epp taking over what I build with in foam creations until the costs go way down.
saucerguy is online now Find More Posts by saucerguy
EPP foam sheets eastbail Foamies (Kits) 2 Apr 24, 2005 09:20 PM
Are all thick epp foam sheets laminated from thinner stuff? The Other Dave Foamies (Kits) 2 Jan 29, 2005 11:03 AM
What size EPP foam sheets for Shocky type planes? Ryan Nau 3D Flying 1 Jan 23, 2005 09:12 PM
??? EPP Foam Sheets ??? WTB ElectOne Foamies (Kits) 2 Oct 23, 2004 11:17 PM
3mm and 4mm EPP foam sheets? Martin Hunter Foamies (Kits) 4 Nov 12, 2003 12:54 AM
