Old Mar 16, 2008, 01:11 AM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Motor driven tail rotor spin the same as belt driven tail?
Im trying to rebuild all my micros to fly indoor at an indoor funfly and im not sure if the direction of the tail rotor is spinning the right way.
Its a blade CP pro with a brushless Park 400 main, eflite G90 HH, GWS tail motor and carbon blades and rotor.
Do the motor driven tail rotors spin up into the downwash like the other belt driven tails like on minis?
BowerR64 is offline Find More Posts by BowerR64
Old Mar 16, 2008, 05:39 AM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
If you are running a direct drive tail (you didn't specifically state), with a normal pitch CCW tail prop, it is not possible to have the prop rotate up into the downwash when you have CW rotating main blades.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Mar 16, 2008, 10:16 PM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
oh dang, i forgot to put how i have it setup.
Im using the GWS motor and the stock rotor and gear setup. Its pretty much the same setup as the helimax Axe CP tail. The longer GWS type motor with a pinion on the shaft the same as the little stock motor but alot more power and athority.
Old Mar 17, 2008, 12:51 AM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Geared rotor setup like you have will spin up into the downwash (top moving toward tail). That's how it's set up stock, and you just swapped the motor, from what I understand.
DD with pitch going the same direction as the stock rotor will, as Martyn said, spin reverse, with the top moving toward the nose.
murdnunoc is offline Find More Posts by murdnunoc
Old Mar 18, 2008, 12:53 AM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
I did swap the motor but you cant get them with the little gear on it. The motor and gear is 2 seperate parts.
I think you can get the axe CP motor and it has the gear on it but they want 2X more then if you just build it yourself.
Discussion Why would one want a belt driven tail vs a tail motor? darklyte24 Electric Heli Talk 35 Dec 19, 2006 01:27 PM
Discussion Optic 6: REVO set up for heli motor driven tail rotor Mike abcd Hitec/Multiplex USA 0 Jun 15, 2006 01:19 PM
Driven tail verses motor tail ? JGELS Micro Helis 8 Dec 28, 2004 09:58 AM
Tail rotors - shaft driven versus seperate tail motor driven prop JohnM Micro Helis 2 Jun 10, 2004 01:15 PM
Tail rotor - motor driven vs direct drive JohnM Micro Helis 0 Dec 19, 2003 04:06 PM
