This thread is privately moderated by rockom, who may elect to delete unwanted replies.
Old Mar 15, 2008, 09:22 PM
rockom is offline
Find More Posts by rockom
rockom's Avatar
United States, IL, Genoa
Joined Jan 2004
Elipstick 260 Build: Part III
I spent some more time on the Elipstik. These steps were slow but well worth it.
This one required lot's of pins becuase of the bent wood. Some pieces were soaked in warm water for a few minutes to get the correct shape without breaking. Lots of pins held the shape until the wood and glue dried. I used Titebond wood glue for the 'wet' joints. Also, I admitedly used pins in a few places where it was not necessary. Sooooo, I felt it was necessary to fill some pin holes. It looks much nicer now.
I mentioned in the previouse build post that I was not happy with the trailing edge and was considering an 1/8" square strip of bass wood added to the TE for strength. I got favorable results with CA soaked balsa end grain gussets where the airfoil caps meet the TE. Much lighter and probably more effective. I tried other gain orientations and this seemed to work out the best.
I shaped the the leading edge as well.
Next is sanding the ailerons and battery box installation.
-Rocko
rockom is offline Find More Posts by rockom
Old Mar 16, 2008, 11:07 AM
sgtdirt is offline
Find More Posts by sgtdirt
Mentor, OH
Joined Dec 2004
looks good!
i glued some carbon fiber tape under the T.E. of mine. stiffed it right up.
what do you have planed for motor?
sgtdirt is offline Find More Posts by sgtdirt
Reply With Quote  (Disabled)
Old Mar 16, 2008, 01:57 PM
tenja is offline
Find More Posts by tenja
Joined Apr 2006
I have an elipstick, given to me, glued together, I don't have the plans where would the CG be? Thanks.
Tenja
tenja is offline Find More Posts by tenja
Old Mar 16, 2008, 06:39 PM
rockom is offline
rockom's Avatar
Joined Jan 2004
CG is just behind the center spar.
Old Mar 16, 2008, 06:41 PM
rockom is offline
rockom's Avatar
Joined Jan 2004
Originally Posted by sgtdirt
looks good!
Thanks.
I think it's a 280 brushed. 280 or 380. Whatever is came with. At least that what's going on it for now. I think the owner of the model intends to put a brushless on it later.
-Rocko
Old Mar 16, 2008, 09:11 PM
tenja is offline
Joined Apr 2006
Thanks a lot Nightz, I had this one out Friday, tried to fly but forgot I didn't balance
it, and of course it wouldn't fly right, crashed two times but didn't do much damange.
I will try again the first nice day I get, and let you know how I did. Thanks again.
tenja
jet day part III 3dddflyer Electric Ducted Fan Jet Talk 3 Dec 06, 2002 03:59 AM
Looking for Elipstick 260 plans... LawDog101 Aircraft - Electric - Airplanes (FS/W) 2 Feb 21, 2002 09:03 PM
Flight of the Toad - Part III Dave Lindsey Parkflyers 2 Feb 07, 2002 04:33 PM
