Old Jun 21, 2001, 11:21 PM
dano is offline
Find More Posts by dano
South San Francisco
Joined Jun 2001
How do I fix a broken motor mount on my E-Boomerang?
I finally found myself a fairly large field with an oh so slight wind. Perfect, I thought. I'll just set the trim real quick and have some fun. Thing takes off faster than any Zagi400 I've ever seen. Oops, rookie at the stick, too much left, no, too much up, BAM!
The RTF E-Boomerang's motor looks like it was hot glued on the top side of the wing and the bond came undone. Of course I didn't notice this tiny little detail until after the plane went down up down up CRASH on the second launch, hehehe. Oops.
I'm thinking of drilling two holes, one on each side of the motor and using a zip tie to hold the front of the motor down.
Any suggestions?
dano is offline Find More Posts by dano
Old Jun 22, 2001, 12:48 AM
funflyer is offline
Find More Posts by funflyer
Fun Flyin
Escondido, CA, USA
Joined Mar 2001
RocketWings.com sells them with their "Rocket Wing"...If you want one, Email them. The price is ten dollars and is more durable than the one you have. Its very strong and you can expoxy it on. Just a thought. And its lighter also.
funflyer is offline Find More Posts by funflyer
Old Jun 22, 2001, 01:41 AM
dano is offline
South San Francisco
Joined Jun 2001
Thanks!
Old Jun 23, 2001, 02:12 AM
dano is offline
South San Francisco
Joined Jun 2001
Any other opinions? I already bent the motor mount bracket as close to 90 degrees as possible and have hot glued the front back into place. Tomorrow I'll drill the holes and fasten the zip tie. If that doesn't work I'll have to look at purchacing another tougher mount.
Old Jun 25, 2001, 12:28 AM
dano is offline
South San Francisco
Joined Jun 2001
Well, I installed a zip-tie and the motor will not come off now unless I hit it directly and the whole thing rips off. We'll see how it flys.
I will order the motor mount from rocketwings if the zip-tie doesn't work. I really don't want to tear off the beautiful work that Weston put on my plane.
[This message has been edited by dano (edited 06-25-2001).]
Old Jun 26, 2001, 09:43 PM
dano is offline
South San Francisco
Joined Jun 2001
I can't believe a whistle post got more replys than mine. Maybe I should post something about putting clear tail light lenses and a large wing on my plane, or maybe a big traf muffler on it, then I may get more than one response.
[This message has been edited by dano (edited 06-26-2001).]
Discussion Broken motor mount on MM C-180. How do I repair? pac ace Parkflyers 3 Nov 21, 2006 03:52 PM
Question How do I fix a broken actuator??? El Destructo Scratchbuilt Indoor and Micro Models 7 Sep 14, 2005 06:49 PM
How Do I Remove the Tail Motor Mount From the End of the Boom? wannabe Micro Helis 2 Nov 12, 2003 06:17 PM
Help reinforcing broken motor mount on Tigermoth?? duganderson Foamies (Kits) 1 Feb 03, 2003 10:48 PM
How do I get more negative pitch on my eco 8? jtthebiggafigga Electric Heli Talk 3 Nov 28, 2001 11:35 PM
