Old Jan 06, 2003, 01:25 PM
rays89 is offline
Find More Posts by rays89
Tree Trimmer
rays89's Avatar
Warren TWP NJ
Joined May 2001
Doculam Painting question
Well I finally got myself motivated to do some building. Im in the process of constructing a Herr Airboss, With the Cutek lighting system, and onboard Blackwidow Video equipment (night video) Powered by an Astroflight 010 direct drive.
The Air Boss needs washout and I found out Solite tends to strech in time losing washout.
Ive decided to use Doculam for the wings. Im wondering what would be a good paint to use. and how do you paint it? From the inside I assume. I plan on using Doculam for more projects considering the amount I have. Ive read that the pactra paints used on lexan car bodies is a good paint to use but it is rather expensive, and comes in small cans. Is there a cheaper paint I can use that I can purchase in a hardware store in larger cans?
rays89 is offline Find More Posts by rays89
Old Jan 06, 2003, 02:34 PM
CoClimber is offline
Find More Posts by CoClimber
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
I've used Krylon paint with fairly good results. I paint the outside of the Doculam. The Pactra is better though and I suspect it's a lot lighter but I haven't measured that.
Doug
CoClimber is offline Find More Posts by CoClimber
Doculam Covering Question or Two. nr5a Parkflyers 2 Mar 22, 2003 05:37 PM
Doculam Painting? mtfbwymb20 Parkflyers 0 Dec 17, 2002 08:43 AM
Twin Star Motor & painting question semmyroundel Foamies (Kits) 8 Feb 25, 2002 06:27 PM
