Jan 07, 2003, 09:37 PM
Eden NY
Joined Sep 2001
I have an ECO 8 (stock swashplate) set up with the Eclipse. Here is how I have mine set up:
Swash 120 deg
PMX1 (ON) Mas Ch2 --> Slv Ch6 value set at +50%
Ch1 is REV, Ch2 is NOR, Ch6 is REV
Setting the mix from Ch 2 to Ch 6 of 50% exactly cancels the mixing that would go on with 120 deg CCPM (120 deg-90 deg=30 deg ==> sine(30) = 0.5 which is equal and opposite in sign from the input that Ch1 and Ch6 would get from the normal 120 deg swashplate mixing).
This seems to work:
-Moving the elevator stick fore/aft causes only the elevator servo (Ch2) to tilt the swashplate fore/aft with no movement of the Ch 1 and 6 servos and no swashplate tilt in roll and it pivots fore/aft around the roll (Ch1 and 6) swashplate ball links
-Moving the aileron stick left/right causes only the (Ch 1 and 6) swashplate to tilt in roll and no fore/aft movement
-Moving Collective up/down causes all servos (Ch1, Ch2 and Ch6) to move up and down identically, with no elevator or roll movement of the swashplate
I think this seems to do the trick. Let me know if you have any problems.
-Eric
