Well, well, well! This past Sunday (1/5/03) I met the SCF (Seminole Crash Fest) Boys for our Sunday fun fly. I had my P-51 ready to go and what follows is a flight report and notes from the build and setup.
*** SETUP:
I was ready to go, really excited, and nervous. Lucky for me we had two expereinced P-51 flyers there. One of which is Allen, who happens to work at one of the best LHS'es in our area, 'Archies Helis and Hobbies'.
Allen helped me setup the P-51, and work on a problem I was having. It seems that my ESC (GWS 100) was failing on the heavy load placed by 4 servos, one of which is a Naro HP, for the retracts. The Naro was binding on the gear, and causing problems. We disconnected the gear servo, and set the gear to hold down so I could still ROG and fly.
As you will see, without Allen's help, I would have surely packed it...
*** FLIGHT REPORT:
A few taxies and I was ready. Everyone cleared the line, and Chuck (AirwarriorBelgy) reminded me of the $10 bet he had that I would pack her, first flight.
ROG, a little rudder adjustment, up to speed, little elevator, and she was up! I was lost in the moment, and very excited. Allen was there coaching me, and again without his help I surely would have messed it up.
She was screaming along, I was supprised at her speed. First major problem: She had a horrible tendency to go up. I was puching hard down elevator to compensate. Allen was able to trim down for me as I flew.
I throttled back, and worked on turning her back to me. I was too far away and was worried that I might lose her. I was struggling to keep control and away from a stall.
After two laps I had had enough and wanted down. I took my time and was able to bring her in nice and soft on the grass without damage.
I went up a seond time with close to the same results only a rougher landing. I tore off the bottom part of the tail and the control horn, but was able to fix her at the field.
*** FLIGHT REVIEW:
Problems:
o CG. The CG was set as stated by GWS, and I am SURE they are wrong. I will add weight to push the CG forward a bit. I have read others with the same problem and solution.
o Elevator. SUPER touchy. Make sure you have minimal throws set for this part, or you will pack her. I have seen suggestions of exponentional as well, and I plan on using it next time out.
o Gear. I will redo my retracts with new push rods. It seems I used a push rod that was too thin. I will simply redo with a bigger piano wire.
o ESC. The GWS 100 ESC is too small for my setup with a Naro HP for the retracts. I wil be upgrading to a Castle Creations Pixie-20P. The CC P20 will do 20/25A and weighs close to the same as the GWS 100.
o Elevator pushrod. I will reset the elevator pushrod to make sure that the elevator is neutral and slightly down, to allow me from trimming down so much.
*** CONCLUSION:
I love it. All in all, it was a super fun build and I really loved detailing her. I expect a much better flight(s) next time out, and I will be happy to colletc the $10 from Airwarriorbelgy for a successful Maiden.
I will repost here upon my send flight out, and let you know how the modificaitons worked out.
Attached: Photos... I will be adding some more detail this week. I realy did have fun researching the paint schemes, and working on the look. Lots of fun!
See you soon!
Scott
