Old Jan 06, 2003, 02:42 AM
Tom Johnson
Tom Johnson
Guest
n/a Posts
Planes for Radial Engines?
While looking at the standard engine manufacturers, like Saito and
O.S., catalogs I notice that they make spiffy radial engines, but I
never see models specifically designed for them. Do any exist? Do
these actually work well, or do they just gobble fuel and weigh more
than a model engine should? I have seen an 8 year old Saito 3-Cylinder
on a test stand, but the guy still has not built a plane for it in all
this time.
Tom
To reply directly, remove "not".
IFly
IFly
Guest
n/a Posts
Re: Planes for Radial Engines?
I've seen a 3 cyl Saito in a Piper Cub and it flew nice with oodles of
power. I saw a Siedel, 7 Cyl I think, on a flying boat... quite impressive!
From what I've seen they work very well.
Andrew Donatelli
http://www.donatelli.net
http://www.blackflight.com
"Tom Johnson" <taj45not@attbi.com> wrote in message
news:07aS9.460578$GR5.167733@rwcrnsc51.ops.asp.att .net...
> this time.
> Tom
Old Jan 06, 2003, 02:52 AM
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
There are plenty of planes that can use the radial engines. I saw a Byrons
Wildcat with a Saito 5 cylinder in it. Looked grear, sounded great and flew
great. You can check out Ziroli, Vailly and Brian Taylor plans for some
ideas.
> this time.
> Tom
Old Jan 06, 2003, 04:02 AM
A.T.
A.T.
Guest
n/a Posts
Club member has a 7 cylinder Seidel in a Proctor "Neuport" which he took to
USA in 97 or 98 and came home with several prizes from the scale
competition.- A tad out of scale in the horse power developed as model takes
off and flies under 1/3 throttle, whereas the pilot of the full sized
aircraft was always seeking more throttle..
Several twins in almost daily use.
regards
Alan T.
Alan's Hobby Web Links
http://homepages.ihug.co.nz/~atong/
> this time.
> Tom
Old Jan 06, 2003, 06:12 AM
Nick B
Nick B
Guest
n/a Posts
I am building an Avro 504K 1/3 scale
to house my Magnum 5Cyl 65cc 4 H.P marvel!!!!
"A.T." <atong@ihug.co.nz> wrote in message
news:avbfs4$maj$1@lust.ihug.co.nz...
to
takes
> regards
> Alan T.
> > this time.
> > Tom
Old Jan 06, 2003, 07:12 AM
Yabba Dabba
Yabba Dabba
Guest
n/a Posts
I would like to find a good excuse to buy one of RCS's 5-cylinder,
four-stroke, gas/oil engines.
Maybe a Gee Bee? All it would need is an electric starter.
Ed Cregger
"Paul McIntosh" <paul@mcintoshcentral.com> wrote in message
news:avbbm0$dm8$1@knossos.btinternet.com...
Byrons
flew
> ideas.
> > this time.
> > Tom
Old Jan 06, 2003, 07:52 AM
Mathew Kirsch
Mathew Kirsch
Guest
n/a Posts
"Tom Johnson" <taj45not@attbi.com> wrote in message news:<07aS9.460578$GR5.167733@rwcrnsc51.ops.asp.at t.net>...
> this time.
Anything whose full-scale counterpart was designed with a radial
engine would make a good candidate for one of those radial engines.
Planes generally aren't designed with a specific engine in mind. Even
if they are, the individual modeler can use whatever engine is
appropriate for the airframe (or even some that aren't . In other
words, anything with a round cowl.
Radial-engined scale subjects with their short noses normally need a
bunch of ballast at the front to balance, so it's a win-win situation.
You get the sound of a radial, and useful weight instead of a bunch of
lead.
With the hefty price tags on these engines, it's pretty easy to see
why you don't see them or appropriate airframes prominently advertised
much. Only people with serious money to burn actually buy them; most
of the rest of us just drool on them and kick the tires. Do you know
how hard it is to get drool out of the cooling fins on an engine?
Old Jan 06, 2003, 08:22 AM
Mike Slaughter
Mike Slaughter
Guest
n/a Posts
A club member put a Seidel radial on a 1/4 scale "Spirit of St. Louis." He
said it had lots of power, but was so weighty that it raised the wing
loading to undersirable levels. Lots of power does not mean it is the right
engine for any plane. You must match the engine to the airplane so the
power, wing loading and flight characteristics are correct for the airframe.
A heavy radial may be best with a plane with lots of wing are that flies in
a scale manner. You can't put on on a Balsa USA Nieuport 11 and expect it
to fly like a 3D aerobatic plane. Matching engine to airframe is not easy.
If doem correctly, it will enhance your experience with the airplane.
Good luck,
> this time.
> Tom
Old Jan 06, 2003, 09:02 AM
Sam Houlder
Sam Houlder
Guest
n/a Posts
Something like this ?
http://www.lomcevak.net/modellfly/gb/
Sam
"Yabba Dabba" <blc2@hotmail.com> wrote in message
news:2ceS9.15623$134.1739033@newsread1.prod.itd.ea rthlink.net...
> Ed Cregger
> Byrons
> flew
> > ideas.
> > > this time.
> > > Tom
Old Jan 06, 2003, 09:22 AM
Nick B
Nick B
Guest
n/a Posts
Totally agree, My 5 cyl weighs in at 6.5 lbs and at 4hp thats a lot to carry
on the front for the given power. An experienced scale modeller advised on
the Avro 504 cos it has lots of wing area and will fly in a sacale manner
with my particular motor. No 1/3 scale Sukhoi SU26's cos although the motor
would fit, the weight of the balanced model would be to much for the motor
to perform the aeros required. Shame though! When some one does a light
weight radial I want one!! A large DH Beaver would be nice!
"Mike Slaughter" <mikeslaughter@cinci.rr.com> wrote in message
news:ypfS9.61795$%3.17196035@twister.neo.rr.com...
He
right
airframe.
in
easy.
> Good luck,
> Mike
> > this time.
> > Tom
Old Jan 06, 2003, 11:42 AM
Yabba Dabba
Yabba Dabba
Guest
n/a Posts
Preeeecisely! <G>
Ed Cregger
"Sam Houlder" <sam@lomcevak.net> wrote in message
news:1041860527.430454@a217-118-32-43.bluecom.no...
> Sam
> > Ed Cregger
> > Byrons
and
> > flew
some
> > > ideas.
3-Cylinder
all
> > > > this time.
> > > > Tom
Old Jan 06, 2003, 04:02 PM
James D Jones
James D Jones
Guest
n/a Posts
>>this time.
> lead.
One of the best scale modellers in the country uses radials in most of
his planes. Charlie Nelson first buys the engine, and then he designs
a plane to fit. His Wacos are something to see. His latest uses a
Siedel engine. Hearing it run is itself an experience.
Jim - AMA 501383
Old Jan 06, 2003, 09:12 PM
Thomas Buehrer
Thomas Buehrer
Guest
n/a Posts
Saw one in a large scale corsair hanging in the hobby shop for sale couple
year's back.
CRIED FOR A WEEK
Tom B
Old Jan 06, 2003, 10:52 PM
Bill Sheppard
Bill Sheppard
Guest
n/a Posts
How much of a problem do glow radials have with cylinders flaming out?
Bill (oc)
any 1/2 a 3D Planes for the norvel engines? Rev Maximillion 1/2A Planes 6 Sep 18, 2004 10:58 PM
2 PSS planes for sale: Sailndude Aircraft - Electric - Airplanes (FS/W) 3 Nov 18, 2001 09:24 PM
Which Planes for Streamer Combat? rrowley Sport Planes 1 Nov 13, 2001 09:32 AM
Foamie Planes for the New Guy to the Expert thelocust Foamies (Kits) 7 Oct 10, 2001 09:52 PM
planes for FMS LuckyArmpit Beginner Training Area (Aircraft-Electric) 1 Jul 03, 2001 06:27 PM
