Old Mar 10, 2008, 01:33 PM
Matt Halton is offline
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
How do you remove the rotor from an assembled Shubi DS-51 3PH please?
I need to remove the rotor from an assembled unit.
I can't remember how it's done, but I need the rotor for another fan shroud..please help!
Matt Halton is offline Find More Posts by Matt Halton
Old Mar 10, 2008, 01:55 PM
Doug Bateman is offline
Find More Posts by Doug Bateman
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
There should be a hole in the shroud that lines up with a hole in the inner motor casing. An allen wrench is inserted into the holes and the rotor most be turned untill the set screw (grub screw) is lined up and you can insert the wrench and loosen. There are two screws 180 degrees apart. i don't remember the size, maybe someone can chime in or go on mfg. site for dwgs. Doug
Doug Bateman is offline Find More Posts by Doug Bateman
Old Mar 10, 2008, 02:01 PM
Joined Dec 2004
Matt, i just noticed yours is the older version, the directions i gave above are for the DS51-DIA. What happens when you remove the spinner? I'm guessing theres a collet under there that you would loosen with a spanner. I have seen drawings of these somewhere.
Old Mar 10, 2008, 02:43 PM
Wannabe B-26 pilot!
Joined Nov 2002
Hi Doug, thanks for helping. Yes,it is the older one,it has a shaft adapter,and there is a small hole between the stators on the main body.
I tried inserting a small allen key, but nothing is engaging when I rotate the shaft.
This is driving me nuts!
Any ideas?
Thanks again,
Matt
Old Mar 11, 2008, 03:22 AM
Wannabe B-26 pilot!
Joined Nov 2002
No matter, I found a way to install the unit in my Hawk now.
Help! How do you remove the fan from a GWS EDF 55 bolarobric Electric Plane Talk 9 Jun 15, 2007 12:05 PM
Help! How do you remove the flywheel from a K & B 3.5 outboard???? FERRARI Racing Boats - Internal Combustion 1 Oct 17, 2006 01:17 AM
Help! How do you remove black print from fan fold foam flashprash65 Foamies (Scratchbuilt) 8 Sep 01, 2006 04:53 PM
Discussion How do you remove main bearings on an SE renerc Mini Helis 0 Jun 22, 2006 04:40 PM
How do you remove the can from an outrunner? xray328 Electric Plane Talk 10 Sep 18, 2005 11:02 AM
