Pablo. |
Canada, MB, Winnipeg
Joined Dec 2011
Back on track, I guess I don't know how to choose the right balsa. Got some more sheets and the 1st one I tried worked like a dream. With a few days off I should be able to make a bit of progress now.
Pablo - have you done your maiden yet? |
![]() http://www3.towerhobbies.com/cgi-bin...?&I=LXE217&P=0 http://www3.towerhobbies.com/cgi-bin...?&I=LXTHR9&P=0 If you decide to go for those items, i can explain you later how to use it... ![]() Quote:
Pablo. |
Joined Dec 2011
Not sure what you mean Pablo, How do get it to go flat on the floor. If you do it right side up the wings keep it from laying flat and upside down the round top of the decking prevents it from laying flat? The joint is good in some spots and where there is a gap it's small but there. |
Rob, Tiny gaps I would not be too concerned about...provided the wing is square with the fuse, and you have not affected the wing incidence, and the wing will not twist or move when bolted on. You want to ensure the wing sits neatly and evenly on the fuse wing saddle. If all is correct, then after covering you could fix the odd tiny gap with a bead of silicone. If you need to square up the wing, and get the incidence right and remove gaps, what I find works well is to take some sandpaper (say 1" x 5"), place the fuse on the wing, and slip in the sandpaper (sanding surface against the fuse wing saddle) and work out the high spots until you get a perfect fit. You do not want the wing to twist when it gets bolted down due to gaps, or be able to move. Hope that makes sense. Marko |
) sitting in the cockpit floor on a small box or anything like that, with the wing bolted in place, and them you can measure the distance from the wing tips to the floor.. ![]() Pablo. |
| Thread Tools | |
| Wanted Wanted:Great Planes RV-4 40 kit | Warby | Aircraft - Fuel - Airplanes (FS/W) | 1 | Nov 27, 2005 05:04 PM |
| FS- Great Planes RV-4 Ready to ... | wolfast | Aircraft - Fuel - Airplanes (FS/W) | 2 | May 01, 2004 05:56 PM |
| Ebay - Magnum XL-61 4-stroke and Great Planes RV-4 kit <24 hrs to go | neilo | Aircraft - Fuel - Airplanes (FS/W) | 0 | Feb 23, 2004 12:37 AM |
| Great Planes RV-4 kit | pepflyer | Electric Plane Talk | 2 | Jan 10, 2003 04:09 PM |
| Great Planes RV-4 conversion anyone? | All__talk | Sport Planes | 7 | Apr 01, 2002 02:53 PM |
