Old Feb 13, 2012, 08:07 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Originally Posted by bunkai View Post
this is probably a noob question but I was wondering how exact to the plan does the shape of the LE have to be for performance? I have it darn close but since I was in there sanding for hours to get it right was wondering how important it is to have it done exactly as shown.
The leading edge within the first 5% or so from the very front point is not critical.
The air splits quite a bit ahead of the leading edge due to compression at the very edge.
You have no reason to be concerned as long as you have a reasonable approximation and it looks good.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Feb 13, 2012, 08:28 PM
bunkai is offline
Find More Posts by bunkai
Canada, MB, Winnipeg
Joined Dec 2011
great answer - thanks Zor!
bunkai is offline Find More Posts by bunkai
Old Feb 13, 2012, 08:30 PM
bunkai is offline
Joined Dec 2011
RCwings quote
How does it mate up with the fuse "wing saddle"? You may need to work it a little too.
good point I hadn't thought that far ahead.
Old Feb 13, 2012, 08:54 PM
rcwings is offline
Find More Posts by rcwings
North Simcoe Flyers
rcwings's Avatar
Midland, Ontario, Canada
Joined May 2007
RCwings quote
Oh never mind yet...you probably do not have the fuse started. But something to keep in mind when the time comes. Be careful not to alter the wing incidence if you need to do any shaping on the saddle.
rcwings is offline Find More Posts by rcwings
Old Feb 19, 2012, 01:33 PM
bunkai is offline
Joined Dec 2011
Ok here is where I'm at. Have the dihedral brace and doubler in all epoxyed and curing.
Rob
sux that the clamps left very small dents on the LE...
did I mention I'm starting to dislike the sanding part of this?
Old Feb 20, 2012, 12:37 PM
bunkai is offline
Joined Dec 2011
I'm starting the fuse and grab the 1st parts the FFS sides and they are both C'd. I've wet them and put weight on them. Hopefully they straighten out. So much for making progress today.
Old Feb 20, 2012, 12:39 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
You are using some good gluing techinques to hold the parts in place - first time build? Hummmmm....
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Old Feb 20, 2012, 12:42 PM
bunkai is offline
Joined Dec 2011
clarify huummm
Yes it is my 1st time build. I've not glued these parts or done anything other than wet them, lay them flat with weight to get them straight before I start. As for technique, I've relied on this and other forums and sites for advice and examples etc.
Old Feb 20, 2012, 12:45 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
You are holding the two wing halves together AND keeping the bracing of the wing joiner securely all at the same time. This is the weakest point where a wing will (or if it will) fail and it appears yours won't!
Old Feb 20, 2012, 12:48 PM
bunkai is offline
Joined Dec 2011
Would that mean you agree with the technique I used there? I looked at other builds for examples of how they did it and went out got clamps that would fit etc.I also spent alot of time prefitting to make sure the dihedral brace fit nice before pulling out the epoxy. It was the first time I have used epoxy.
Old Feb 20, 2012, 12:54 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
yes, you are using the correct technique!
Old Feb 20, 2012, 12:56 PM
bunkai is offline
Joined Dec 2011
wheew .... thanks
you had me worried
Old Feb 22, 2012, 04:37 AM
pablojaime is offline
Find More Posts by pablojaime
pablojaime's Avatar
Israel, Ashdod
Joined Dec 2009
It was 30 Min. Epoxy?
Pablo.
pablojaime is offline Find More Posts by pablojaime
Old Feb 22, 2012, 08:03 AM
bunkai is offline
Joined Dec 2011
Pablo.
Yes it was Pablo. Nice progress btw.
Wanted Wanted:Great Planes RV-4 40 kit Warby Aircraft - Fuel - Airplanes (FS/W) 1 Nov 27, 2005 05:04 PM
FS- Great Planes RV-4 Ready to ... wolfast Aircraft - Fuel - Airplanes (FS/W) 2 May 01, 2004 05:56 PM
Ebay - Magnum XL-61 4-stroke and Great Planes RV-4 kit <24 hrs to go neilo Aircraft - Fuel - Airplanes (FS/W) 0 Feb 23, 2004 12:37 AM
Great Planes RV-4 kit pepflyer Electric Plane Talk 2 Jan 10, 2003 04:09 PM
Great Planes RV-4 conversion anyone? All__talk Sport Planes 7 Apr 01, 2002 02:53 PM
