CX2 Scale Jet Ranger with HH gyro..How I set it up
Ive been toying with the idea for some time of installing a HH gyro on my Cx2 for scale flight, and after seeing a few others who succesfully did this, I decided to share how I managed to get mine to work. I want to thank rbinc for all of his "behind the scenes" help with this.
The only reason I did this was because I fly with a DX7. Most bind the DX7 in the airplane mode for simplicity but this doesnt allow you to access certain throttle curves and throttle hold modes available in the Heli mode. There are issues sometimes with the stock CX2 gyro in the heli mode on the DX7 that causes the tail to wag uncontrollaby on the CX2 and I was having these issues. Unless you just want the experience of doing this, I cant think of any reason to install a HH gryo on this heli because the stock one works very well. Fuselage mods: I used the E-Flight Jet Ranger body which is a nice one piece unit. BladeCx2Runner descibed issues in another thread of the rear of the canopy coming into contact with Xtreme blades. Mine was very close, so I drilled new body pin mounting holes about 2-3mm diagonal of the originals to pull the rear of the body down just a bit to give a little more clearance. Stock blades should be fine. Also the body pins slide out over time so small peices of small size fuel tubing hold them in place I also installed a scale lighting set from here:http://flightlights.net/RcHeli.htm They are expensive but are the smallest and brightest I have seen and they are plug and play on the reciever. One light strobes and the others remain on, so the scale apperance is really cool. I secured them into the body using several CX2 canopy grommets so I could remove them later if needed. I also did not like the open window canopy style so I created windows on my own and covered them with dark blue self adhesive monokote from the LHS airplane section, and trimmed the front with silver auto pinstripe tape. Gyro install: The Gyro I used is an E Sky EK2-0704A HH gyro that is about $38.00. Its very small and weighs about 8 grams in the case. This gyro has no "reverse" function but if you install is in the position shown, it will be working in the correct direction. Simply unplug the rudder plug from the 3&1 to the reciever and plug it into the gyro. Then plug the gyro into the rudder port on the reciever and plug the single wire gain plug from the gyro into the "gear" 5th channel port on the reciever. You must plug the gain plug in or the gyro will have to be adjusted manually using the gain pot on the gyro and will only work in rate mode no matter what the setting!!! I wanted to use the gear port to run my lights instead of gain, but doing this would cancel out the whole purpose of getting the HH gyro, so Im running the lights on the 6th channel "Aux" port on the reciever (thanks Sirion!) The lights turn on when I raise the throttle. Your gyro gain will then be controlled by the 5th channel knob on your radio. You must initialize the gyro in HH mode (gain over 50%) and make sure your rudder trim is centered so the gyro know where neutral is. Make sure that you turn both the gain and proportional pots on the 3&1 all the way off (full left) to allow the new gyro to have control. I was very dissapointed at first because I could not get the gain above 80% and this was not enough to hold the nose and any higher gain made the heli crazy. I discovered that I had a few broken gear teeth and this was causing a high frequency vibration that was interfering with the gyro in high gain. I replaced the gears and now I am running at 95-98% gain and she holds very well. There is a very slight nose drift to the right after the gyro heats up, but one click of left rudder trims stops the issue. Its important to remember that the gyro will initialize immediately when the battery is plugged in before the 3&1 will, so you must have the heli sitting on the ground and not moving at all when you plug in the batt. The heli now flys perfect with my DX7 in Heli mode and now I have access to all my smooth throttle curves that keep the heli from being so throttle sensitive and twichy up and down when hovering. I still have all the bling hidden inside the body now but the increased weight seems to really make her feel more scale. She now weighs in at a hefty 8.6 oz but still gets 8-9 mins of scale flight from a DN 900 Mah pack and leaves 3.6 volts per cell after the fact.Thanks again for all the tips and help picked up from everyone in the forum. |
They are about the same price everywhere though |
HS-55 Servos
They are a little heavier and slower but more torque and they do not have the frail leads of the S60. Was disgusted to get my Bell together and lose ANOTHER S60 because the ground lead broke. In all fairness to E-Flite, it's only when you unplug/plug the S60 in a few times that the "hair-gauge" leads fail.
The HS-55 will fit: Remove the rib and shoulder on the rear of the shaft housing. Use a CX (not CX2) upper servo/canopy mount. Space the ail servo 2 mm from the servo/canopy mount on top with 2 mm plastic. Bottom tab of servo is removed like the S60/S75 Space the bottom of the ele servo with 3 mm. Tab is notched like the original S60/S75. Rock solid great servos that will never cost me another near miss because of lead failure. S60 is ligther and faster than the HS-55 but the Hitec has more torque (none of which is an issue here in the CX). But the leads are durable and it is usually cheaper than the S75 (same dimensions used in the original CX and Blade CP/CP Pro) Regards |
Now if I could only get the tiny crap Walkera electronics in my 4#3 repaired and working!!!
I just installed a Telebee GR201 HH gyro on the tail boom mounting plate (behind the servos). The prop/gain on the 3-1 are turned fully ccw. When I turn up the gain on the Tx 5th channel the tail shakes violently at times, then smooths out. Is this a mechanical feedback problem?
Its normal for the gyro to "search" when the gain is too high. It will also do this if the gyro picks up a lot of vibration on the heli. Most people raise the gain until the heli starts to do this searching and then just back the gain down just a bit until it stops. This gives you the highest gain setting without going over the line with it. Im not familiar with the gyro you have but the rules are pretty much the same for all of them. Your gain should be at least above 50% at all time to be in the HH mode. |
That's another important criteria Xrayted; if the helicopter shakes at all, solve this before installing the HH gyro. Vibration confuses the piezo and it will never perform well. Good point. |
What are your experiences with this HH gyro? does it hold solid once you get the gain down and the tail wag stopped? Do you see any better than you had before? In HH mode the rudder will feel much slower and smoother which is perfect for scale flying. The stock rate gyro works very well on the CX2, so I would imagine your HH is just slightly better than what you had unless your flying scale |
I have barely had time to get airborne for testing and am going out of town this weekend. I will try to post results early next week.
The rudder trim is centered. Not sure if there is any drift. Using the stock gyro I started at nearly full left trim and it would drift to somewhat right trimmed over a 10 min flight. |
| Thread Tools | |
| Discussion my first glider need help with tips on how to set it up | newtohelis | Electric Sailplanes | 2 | Dec 15, 2007 02:06 AM |
| DragonFly with HH GYRO--How? | gigawatt | Micro Helis | 2 | Feb 24, 2005 09:57 AM |
| 2 NEWS Kyosho EP Concept helis with RARE scale Jet Ranger and Highes 500 fuses! | Jason M | Aircraft - Electric - Helis (FS/W) | 2 | Sep 22, 2004 06:38 PM |
| Problem With Pico Pack-how do I hook up? | mrebman | Parkflyers | 5 | Jul 06, 2001 11:06 AM |
