Old Jun 22, 2001, 01:13 AM
funflyer is offline
Find More Posts by funflyer
Fun Flyin
Escondido, CA, USA
Joined Mar 2001
Has anybody used this battery for a ZAGI.
Has anybody used this battery for a zagi. Do you think it will work good? Think it give longer flight times?
Its a 1900SCR sanyo 9.6 volt MaH battery pack.
funflyer is offline Find More Posts by funflyer
Old Jun 22, 2001, 01:45 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
It would work but would likely be heavy enough to offset any performance increase you might see not to mention make the ship fly like a brick. Lighter is better. The new CR1300s look quite promising. I personally am leaning towards the 8x1400 AE packs.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jun 22, 2001, 02:36 AM
DEATHspiral is offline
Find More Posts by DEATHspiral
San Diego, CA, USA
Joined May 2001
It'll definitely work. I have flown my zagi with that pack, it will fly, but very sloppy, kinda like flying without the winglets. I've even flown with a 7.2volt rc car battery too. You'll definitely get longer flight time, won't climb as well, but is entertaining and a cheap way of getting long flights. Try it, you'll like it, but don't count on doing any rolls.
DEATHspiral is offline Find More Posts by DEATHspiral
Old Jun 22, 2001, 11:50 AM
DaJudge is offline
Find More Posts by DaJudge
Fish & Fly
DaJudge's Avatar
Tyler, TX USA
Joined Jul 2000
Too heavy.
DaJudge is offline Find More Posts by DaJudge
Old Jun 22, 2001, 01:03 PM
Greg Covey is offline
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
Yeah, I use it.
But it was in this...
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Jun 22, 2001, 06:58 PM
DaJudge is offline
Fish & Fly
DaJudge's Avatar
Tyler, TX USA
Joined Jul 2000
Those packs are great for something like a TwinJet.
About the biggest pack I like for the Zagi is the 8x800AR which a very good pack for higher amp draws.
Old Jun 24, 2001, 02:20 AM
papichulo is offline
Find More Posts by papichulo
El Centro, CA
Joined Jun 2001
Where do you get these 8x800AR's I keep seeing posted here? Are they expensive?
My 400x flies much cleaner with 8x600's than the heavy 1700 that comes with the 400x
papichulo is offline Find More Posts by papichulo
Old Jun 24, 2001, 06:33 AM
AndrewK is offline
Find More Posts by AndrewK
Ready for a Vacation!
AndrewK's Avatar
Atlanta, GA
Joined Dec 2000
New Creations RC (www.newcreations-rc.com) - you can get the 8x800AR's. They are fast-charge cells and work well with the Multiplex 450 Turbo motor, also available from NCRC. Call them and they can tell you what you need to know.
Andrew
AndrewK is offline Find More Posts by AndrewK
Old Jun 24, 2001, 10:12 PM
177ichael is offline
Find More Posts by 177ichael
California
Joined May 2001
Aren't the 8x800 ARs the same weight as the 1700AU cells that come with the Zagi 400x? I think these two packs use the same size cells (A size). The AR packs just have lower internal resistance, thus motors such as the 450 turbo are able to utilize the greater amp draw from these packs, however, duration is cut down, in part, due to this higher amp draw.
177ichael is offline Find More Posts by 177ichael
Has anybody used cell phone batteries for their plane! funflyer Power Systems 17 Oct 15, 2010 10:55 PM
Has anybody seen this motor, and is it good for e-flight? Barrett Electric Plane Talk 8 Jul 16, 2010 02:47 PM
Has anyone used this camera for AP AeroNut45 Aerial Photography 0 Dec 06, 2005 05:02 PM
Has anyone used this receiver for AP birds? randall1959 Aerial Photography 18 Sep 30, 2005 11:43 AM
Has anybody used cell phone batteries for their plane! funflyer Foamies (Kits) 2 Apr 24, 2001 08:36 PM
