Old Feb 08, 2013, 08:25 PM
Toysareforkids is offline
Find More Posts by Toysareforkids
Tn
Joined Jan 2011
I would not buy another EFlite Park 250. I and some others have had problems with them dying from broken internal wires. I do like the Turnigy much better, and have had no problems with them. besides, the EFlite 250 costs $40.00 and the Turnigy costs only $10.00 from Hobbyking. I use a HK 10 amp ESC on them and have not had a HK ESC fail yet.
Pat
Toysareforkids is offline Find More Posts by Toysareforkids
Old Feb 08, 2013, 09:29 PM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
Any other suggestions other than Hobby King? I currently use a GWS 50 but am looking for a brushless............
John
Rubbernecker is offline Find More Posts by Rubbernecker
Old Feb 09, 2013, 12:11 PM
Rczorro is offline
Find More Posts by Rczorro
Joined Dec 2012
How can I get a propeller
With a engine of a easy trainner 800
And a 10 amp speed controller
Rczorro is offline Find More Posts by Rczorro
Old Feb 09, 2013, 12:18 PM
Rczorro is offline
Joined Dec 2012
can i use a 3x2 propeller or a 2x3 and make a bigger hole and slide it in it would work perfect
or 4x2.5 propeller or that same proppeler from the
Easy trainner 800
If i buy a 4x2.5 propeller it's easier to fly
Old Feb 14, 2013, 04:57 AM
Rczorro is offline
Joined Dec 2012
I got a new engine for my plane its not heavy its only 10 grams with a 6amp speed controller.
Old Aug 07, 2013, 09:16 AM
Rczorro is offline
Joined Dec 2012
Hello can anybody tell me if spanfolie can be used in a lastick for covering if it is like ultracote or if it wil work on the plane the plane.
Old Aug 09, 2013, 02:51 AM
Rczorro is offline
Joined Dec 2012
It an be used but if you use it you have to cover the compleate plane.
And if you cover it with tissue it will have many problems.
I build a plane covered with tissue an my first flight it got many holes in it
I put bespanfolie and it works perfect.
So if you ever want to cover a plane with tissue I wod recomend a glider
Or a free flight plane like a bleriot or a kitty hawk.
Old Aug 10, 2013, 02:33 PM
~SnApRoLl is offline
Find More Posts by ~SnApRoLl
Team Fearless
~SnApRoLl's Avatar
United States, MD, Piney Point
Joined Mar 2005
I don't know what "spanfolie" is, but I recommend Ultracote Lite which is what I covered mine in. It's simple to use and it works great for hinges too. If you look at the horizontal stab and elevator, you can see I used the covering as a hinge which makes it clean with no hinge gap. I did the same with the rudder as well.
Shawn
~SnApRoLl is offline Find More Posts by ~SnApRoLl
Old Aug 14, 2013, 08:39 AM
Rczorro is offline
Joined Dec 2012
I build a electric la stick and it flew nice an the weigth of the plane was 4oz and it flew much nicer than a 5oz
Old Aug 14, 2013, 08:44 AM
Rczorro is offline
Joined Dec 2012
Wood it fly nice with 5oz electric
Old Aug 14, 2013, 08:50 AM
Rczorro is offline
Joined Dec 2012
It wood fly with 5oz with a 280engine like your set but i would fly it with a 4oz the ligther is easier but if you find it heavy get small servos and a big prop
Old Aug 14, 2013, 09:01 AM
Rczorro is offline
Joined Dec 2012
How heavy shoud a electric plane la stick be
Old Aug 24, 2013, 03:36 PM
Team Fearless
~SnApRoLl's Avatar
Joined Mar 2005
Hi, it doesn't matter if it's electric or fuel powered. The LaStik has a recommended weight of 5.5 oz. Mine came out at 5 oz. and it's perfect. Also the the LaStick plans don't mention the CG location but it is at the wing spar.
Here are the plans for the LaStick.
Shawn
Old Sep 11, 2013, 09:19 AM
MikeCr is offline
Find More Posts by MikeCr
United States, WI, Slinger
Joined Mar 2006
I was watching an Ace Littlest Stick kit on ebay and it went for almost $50. I could probably build 10 of them for that!
I'm thinking of taking the Park 250 off of mine and using one of my .020's, either my Pee Wee or TD. I initially tried it with both but didn't like not having a throttle. But I'm kinda getting the urge to build some Cox powered models.
I just tiled together a bunch of plans including a Goldberg Jr Skylark, Ace Mach None, and a Pilot Baby. The Baby is of interest because back in the early 80's, before I joined a club and learned to fly, I had one. Only got 2 or 3 very wild, half controlled flights out of it before I stuck it straight into the ground! Not long after that I realized I needed to join the local club and learn properly!
MikeCr is offline Find More Posts by MikeCr
Old Sep 11, 2013, 11:10 AM
RV Winkle is offline
Find More Posts by RV Winkle
United States, KY, Bowling Green
Joined Aug 2013
I was in that ebay gang bidding on littlest stick but it got too rich for my blood. Glad to see this thread.
RV Winkle is offline Find More Posts by RV Winkle
Where do I get the Stick? zed Parkflyers 5 Oct 05, 2004 05:59 PM
Where Do I Get Slow Stick Floats? pbodyline Parkflyers 2 Jun 14, 2004 01:26 PM
Where can i get an aluminum fuselage ( 9mm x 4.5mm x 24") for my PICO STICK? L.I.A. Parkflyers 11 May 29, 2003 08:13 AM
Where do you get foam? macross Power Systems 9 Jul 16, 2001 01:08 PM
Where do you get brushes for an AP29? sbarrow Electric Ducted Fan Jet Talk 1 Jun 18, 2001 11:32 PM
