Old Jan 26, 2013, 06:52 PM
Rczorro is offline
Find More Posts by Rczorro
Joined Dec 2012
With a 7.4v 350mah and a 10 amp speed controller wood it fly wheel
Rczorro is offline Find More Posts by Rczorro
Old Jan 26, 2013, 06:54 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
If well build yes!
coriolan is offline Find More Posts by coriolan
Old Jan 26, 2013, 07:20 PM
Rczorro is offline
Joined Dec 2012
La stick is it a easy plane to build and fly
Old Jan 31, 2013, 07:55 AM
Jaspur_x is offline
Find More Posts by Jaspur_x
Somerset Pa
Joined Dec 2009
can be easy to fly
Originally Posted by Rczorro View Post
Is very easy to fly and very strong and stable and is good for ruf fields because is trong and
It can land very short distans
Try a throttled o10 or 020 to tame it down to your tastesso you don`t do this: http://www.youtube.com/watch?feature...&v=5UwE5eQYNWc
My son and I are going to build our la stick short kits together after my LHS gets my balsa order in
Jaspur_x is offline Find More Posts by Jaspur_x
Old Jan 31, 2013, 07:59 AM
Jaspur_x is offline
Somerset Pa
Joined Dec 2009
Gmark .03 r/c
Originally Posted by coriolan View Post
A Graupner Speed-400 run fine on a 5X5 prop direct drive but might be too much for a LaStick which is really intended for .020 glow power. I flew mine with a Cannon G-Mark .030 initially but it now fly with a 10 grams outrunner from HK+5X3 prop(plenty of power)mine is 4 channels with no dihedral
Fairly sweet litle engines aren`tthey? I doubt I will manage to wear out my spare G-mark .03r/c engines in my lifetime but just in case I have a couple that are patiently waiting their turn lol
Old Jan 31, 2013, 08:32 AM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
The Cannon G-Mark is indeed a sweet little engine which throttle well and relatively quiet, the weak point is the piston/conrod ball joint that needs resetting like its Cox counterpart!
Old Jan 31, 2013, 01:15 PM
Rczorro is offline
Joined Dec 2012
Is it hard to scratch build it
Old Jan 31, 2013, 06:07 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
No if not a first build.
Old Feb 01, 2013, 06:05 AM
Rczorro is offline
Joined Dec 2012
Is it easy to fly with a speed 400
And may it fly with tissue paper covered on the wing
Old Feb 03, 2013, 07:49 PM
Jaspur_x is offline
Somerset Pa
Joined Dec 2009
They aren`t hard to build from a kit,even a short kit, but I havnt tried to scratch build one yet;my knife skills aren`t that great lol
Old Feb 04, 2013, 05:00 PM
Rczorro is offline
Joined Dec 2012
I'm trying to make a nice flying plane that may fly wheel
So pict the la stick with a speed 400
Old Feb 05, 2013, 09:56 PM
Jaspur_x is offline
Somerset Pa
Joined Dec 2009
Thats a catch 22, I can picture the la stick,but not the speed 400,I havn`t gotten into messing around with the electrics yet;but the la stick is a good way to go
Old Feb 06, 2013, 12:22 AM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
Speed-400 is a brushed motor which can swing a 6"X3" prop at about 10000 rpm on 7.2V,a bit less power than a .049 babe-bee. A bit too heavy for a LaStick!
http://www.graupner.de/en/products/8...4/product.aspx
Old Feb 06, 2013, 05:54 AM
Toysareforkids is offline
Find More Posts by Toysareforkids
Tn
Joined Jan 2011
Here's picture of both my LaStik's. The red one started out as electric, with dihedral and a EFlite Park 250 motor. I switched it to a Cox .020. It flew good with the .020, but after having throttle, and alot longer flite time, and no cleanup, it wasn't as fun for me. Not saying it wasn't fun to fly, I just preferred the electric version.
The purple one is without dihedral and a Turnigy 2211 The wife made me remove the crosses and put the teddy bears on it for her!
I would not try to use the 400 way to big and heavy, the Turnigy is more than enough power with a 2s 7.4V 320Ma 25c battery.
Pat
Edit: The motor was a Eflite Park 250, not 280.
Toysareforkids is offline Find More Posts by Toysareforkids
Old Feb 08, 2013, 07:01 PM
Jaspur_x is offline
Somerset Pa
Joined Dec 2009
Well my my my, now I know what to go to my LHS abd order if my son wants a lekky version, thank you very much!!
Where do I get the Stick? zed Parkflyers 5 Oct 05, 2004 05:59 PM
Where Do I Get Slow Stick Floats? pbodyline Parkflyers 2 Jun 14, 2004 01:26 PM
Where can i get an aluminum fuselage ( 9mm x 4.5mm x 24") for my PICO STICK? L.I.A. Parkflyers 11 May 29, 2003 08:13 AM
Where do you get foam? macross Power Systems 9 Jul 16, 2001 01:08 PM
Where do you get brushes for an AP29? sbarrow Electric Ducted Fan Jet Talk 1 Jun 18, 2001 11:32 PM
