Old Mar 08, 2008, 02:22 PM
Mr.Me is offline
Find More Posts by Mr.Me
quick, stretch into a monster!
Mr.Me's Avatar
Everett, WA
Joined Apr 2007
Where do i get an LA stick?
I've been seeing these threads on the LA stick, and man do i want one now!is it a complete scratchbuild or is it a kit? where do i get a kit/plans?
Nick.
Mr.Me is offline Find More Posts by Mr.Me
Old Mar 08, 2008, 02:23 PM
Jupeli is offline
Find More Posts by Jupeli
Pirkkala, Finland
Joined Jan 2005
I downloaded the plans from a thread in RCGroups.
I'll post a link
Edit: http://www.rcgroups.com/forums/showp...48&postcount=3
Very nice plans, I shall say. Only 5 pages and simple construction. As soon as I buy a 010 TeeDee or 020 PeeWee, I'm going to build one.
Jupeli is offline Find More Posts by Jupeli
Old Mar 08, 2008, 02:26 PM
Mr.Me is offline
Mr.Me's Avatar
Everett, WA
Joined Apr 2007
that was the fastest reply i have ever seen... thanks!
Old Mar 08, 2008, 02:35 PM
ncflyer is offline
Find More Posts by ncflyer
Hickory, NC
Joined Dec 2006
I just finished mine and plan to maiden it tomorrow if the wind calms down. I went electric and landing gear so mine is heavier than most but it is over powered so I am not too concerned with a little extra weight. It is a really fun scratch build and very easy. Good Luck.
Kris
ncflyer is offline Find More Posts by ncflyer
Old Mar 08, 2008, 08:01 PM
Tee Bee is offline
Find More Posts by Tee Bee
Those are the plans I used to build mine.
Tee Bee is offline Find More Posts by Tee Bee
Old Jan 26, 2013, 06:28 AM
Rczorro is offline
Find More Posts by Rczorro
Joined Dec 2012
Is that plane easy to fly
Rczorro is offline Find More Posts by Rczorro
Old Jan 26, 2013, 06:30 AM
Rczorro is offline
Joined Dec 2012
Is very easy to fly and very strong and stable and is good for ruf fields because is trong and
It can land very short distans
Old Jan 26, 2013, 10:23 AM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
HK has been selling a laser cut kit of it for awhile:
http://www.hobbyking.com/hobbyking/s...80mm_KIT_.html
coriolan is online now Find More Posts by coriolan
Old Jan 26, 2013, 01:44 PM
Rczorro is offline
Joined Dec 2012
What prop can i use for a electric convertion.i have avalable speed 400 motor
Thank's
Old Jan 26, 2013, 02:02 PM
Rczorro is offline
Joined Dec 2012
You can make a propeller with a 1/8 ply wood
Old Jan 26, 2013, 02:18 PM
coriolan's Avatar
Canada
Joined Sep 2006
Thank's
A Graupner Speed-400 run fine on a 5X5 prop direct drive but might be too much for a LaStick which is really intended for .020 glow power. I flew mine with a Cannon G-Mark .030 initially but it now fly with a 10 grams outrunner from HK+5X3 prop(plenty of power)mine is 4 channels with no dihedral
Old Jan 26, 2013, 02:33 PM
Rczorro is offline
Joined Dec 2012
What does 5x5 mean in proppelers
Old Jan 26, 2013, 03:35 PM
coriolan's Avatar
Canada
Joined Sep 2006
5"X5" = 125mm Dia.X125mm pitch, will load a speed-400 at about 10A at 7.2<8.4Volts, they used to be run with 6/7 cells Nicad before brushless and Lipos made it obsolete. There is very few brushed esc still being made, ditto for Nicad and brushed motors!
Old Jan 26, 2013, 06:04 PM
Rczorro is offline
Joined Dec 2012
What speed is a 6a speed controller with a 7.2v battery
Can I fly the la stick with a 6a speed controller and a 7.2v battery
Old Jan 26, 2013, 06:32 PM
coriolan's Avatar
Canada
Joined Sep 2006
A 6 Amps esc might be Ok with a Speed-280, but a Speed-400 or Speed-300 requires a 10 Amps esc minimum. GWS might still have some brushed esc in that range,or BlueArrow from HK or BP-Hobbies:
http://www.bphobbies.com/view.asp?id=V533528
http://www.bphobbies.com/view.asp?id=V573706
http://www.caliberhobby.com/speed_controllers.html
http://www.hobbyking.com/hobbyking/s...USHED_ESC.html
Might be less hassle and cheaper to just go brushless with Lipo!
Where do I get the Stick? zed Parkflyers 5 Oct 05, 2004 05:59 PM
Where Do I Get Slow Stick Floats? pbodyline Parkflyers 2 Jun 14, 2004 01:26 PM
Where can i get an aluminum fuselage ( 9mm x 4.5mm x 24") for my PICO STICK? L.I.A. Parkflyers 11 May 29, 2003 08:13 AM
Where do you get foam? macross Power Systems 9 Jul 16, 2001 01:08 PM
Where do you get brushes for an AP29? sbarrow Electric Ducted Fan Jet Talk 1 Jun 18, 2001 11:32 PM
