Espritmodel.com Heli Air
Old Jan 05, 2003, 03:52 AM
gromitvt10's Avatar
Pax River, MD
Joined Feb 2002
Combat Models A-10 Fans??
Hi, i just bought a CBM A-10 and i want to put 2 EDF's in it. i was wondering what fans/motors would work best? i plan on putting in retracts, flaps and i want ROG capability. Also how much do these fans/motor combos cost, where can i get them and what esc will i need? What kind of battery would be required? i've got a 10 cell 3000mah NiMH pack and a 8 cell 1700mah NiCAD pack, would i be abe to use either of those? For any of those who have it what kind of retracts are you using? any advice would be greatly appreciated. thanx
Kyle
gromitvt10 is online now Find More Posts by gromitvt10
Old Jan 05, 2003, 08:28 AM
Designer/Scratch Builder
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Wemotec's Midi fan unit is a perfect fit. The one I had used 540 can motors and the older Eco Fans with a total cell count of 14-16, I think. Robert, of EJF, used the Ultra 930-10 brushed motors and 20 cells.
Robert had flaps, rudders, and retracts, plus ailerons, throttle retracts. I had retracts, ailerons throttle and elevator. If I were to do it again I would use a brushless combination of 10-12 CP1700 cells per motor for about 500watts per fan. The CBM, if built per instruction, is pretty heavy. I like the way a lighter A-10 flys, more nimble but not fast, scale. Just my opinion.
As for motor selection go to Ezone and look for old EDF column articles by Chris True. He is my fan andmotor guru ...
BTW, where did you find a CBM A-10?
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jan 05, 2003, 01:31 PM
gromitvt10's Avatar
Pax River, MD
Joined Feb 2002
thanx for the reply, i actually got my CBM A-10 right here on EZONE i went to an old forsale thread and thought i'd take shot at it. so i emailed the guy and apparently the deal had fallen through with the person who was suppose to buy it. So i jumped on it, now i have the A-10 so i guess i just go lucky.
Kyle
Old Jan 05, 2003, 01:50 PM
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
use midi fans for sure !
I'm working on a scratch built a-10 a little bigger (55" WS) than the CBM. I plan on using the mega brushless 22/30/4 on 28 2400's or 3300nihi.
this set up should give me over 4 minute flights and over 130W per pound +/-
you can also go with the mega 22/30/3 and 22 2400's for similar power but 3 minute flights with throttle management.
good luck
hoser is online now Find More Posts by hoser
Sold Combat Models A-10 w/ Midi fans bruff Aircraft - Electric - Airplanes (FS/W) 4 Sep 06, 2005 01:41 PM
FS: Combat Models A-10 Warthog gromitvt10 Aircraft - Electric - Airplanes (FS/W) 3 Dec 29, 2003 08:24 PM
FS: Combat Models A-10 Warthog on EBAY gromitvt10 Aircraft - Electric - Airplanes (FS/W) 0 Dec 12, 2003 01:29 PM
Combat models A-10 power solutions Impreza Electric Ducted Fan Jet Talk 2 Jun 26, 2003 07:42 PM
Combat Models A-10 Reco Electric Ducted Fan Jet Talk 3 Mar 15, 2002 01:25 PM
