Old Mar 06, 2008, 09:25 PM
chlee is offline
Find More Posts by chlee
chlee's Avatar
Atlanta, GA
Joined May 2000
bolt-on wing modification for Oly II/IIS?
Hi everyone,
I was thinking about buying an Oly IIS from Skybench and modifying it for bolt-on wing attachment. It looks pretty easy, but I was wondering if any of you have tried this and have any pointers or recommendations....
- Chung
chlee is offline Find More Posts by chlee
Old Mar 06, 2008, 11:56 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
I had an Oly 650 that was converted to bolt on. The guy who built it added a bulkhead and dowel setup at the front and a single bolt at the rear. However, I broke that bulkhead many times when I was learning to fly. So that's something to keep in mind.
I once had a glider with a two piece wing with a very short little center bit less than an inch wide. At least if I remember correctly. The back of the center section had a pin that slid backwards into the fuse. The front had a pin that was parallel and slightly above a similar pin in the fuse. You could wrap a rubber band between the two pins. I'm not quite sure what the deal with the canopy was. But I think it was able to get out of the way.
Another trick is to use a pair of holes with fore and aft dowels in them just in front of and behind the wing. You would stretch rubber bands over the wings between the two dowels. Less draggy than the setup the Oly has, but you'd have to have something wrapping over the joint between the wing halves to keep the bands from falling in between the wing halves.
I suppose if you were patient you could use bolts at the l.e. and t.e. of each wing half. #10 or 5mm nylon would probably be plenty, especially if you changed them occasionally.
lincoln is offline Find More Posts by lincoln
Old Mar 07, 2008, 09:07 AM
rogerflies is offline
Find More Posts by rogerflies
rogerflies's Avatar
Thomasville, GA 31792
Joined Apr 2002
I built some Cumic Plus variartions with bolt-on wings. I attached a block for the bolt to the front of the wing spar. There was a reinforced area in the TE for the alignment pin. The bulkhead in the fuse also served as the attachment point for the towhook, so the launch load was transferred directly to the spar.
The bulkhead was angled slightly to put the towhook in the right spot. I made one so the towhook could be moved by putting shims between it and the bulkhead, but the others had the towhook mounted solid.
Roger
rogerflies is offline Find More Posts by rogerflies
Discussion Bolt-on wings for Oly II - How would you do it? Mike K Thermal 6 Jan 31, 2006 11:05 AM
Bolt on wing for Seniorita John Z The Builders Workshop 9 Dec 09, 2005 09:16 PM
WTB Fiberglass Fuse for bolt on wing why2cay Aircraft - Sailplanes (FS/W) 4 Oct 05, 2004 09:57 PM
Bolt-On Wing for DAW Warbird? DoonRaker Slope 6 Jan 08, 2003 12:47 PM
Bolt on tip plates for Wing-E BEC Parkflyers 3 Jul 22, 2002 12:29 AM
