Old Mar 06, 2008, 09:57 AM
methos is offline
Find More Posts by methos
methos's Avatar
Canada
Joined Jun 2006
Help!
Power system for a Super Sportster 40 MkII
This could have been posted in the Glow to Electric Conversions forum, but I thought I'd post it here as it pertains to the power system mainly.
I'm going to be doing a Great Planes Super Sportster 40 MkII conversion to electric, and I need some help with the power system.
I'm a power freak. Just about everything I fly is overpowered... and that's the way I like it.
I also love speed. If it's not capable of 100mph, then it really doesn't thrill me much. The exception is of course indoor planes and highly aerobatic planes.
I want to know if it is realistic to want an electric power system for this plane that will push it close to or even beyond 100mph and still have good vertical performance without costing some rediculas ammount of money?
If possible I'd like to stick with Scorpion outrunners because I believe that by far they are the "best bang for the buck" but otherwise I am completely open to suggestions.
Also if someone thinks this plane is not a good plane for this conversion, and have a better plane in mind that is approx the same style and in the .40 - .46 size bracket, then please let me know.
This was my first idea for this plane, but I am not sure how it would perform on a 4.5 - 5lb plane:
Scorpion 3026-10
10x8 Graupner CAM Prop
ZIPPY 5000mAh 5S1P 20-30C Lipoly Pack
Lightflight Suppo 80 Amp HV ESC and a Medusa 6v external BEC
What do you guys think?
Ed
methos is offline Find More Posts by methos
Old Mar 06, 2008, 11:46 AM
methos is offline
methos's Avatar
Canada
Joined Jun 2006
Or how about this setup?
Scorpion 4020-12 (equivalent to an AXI 4120/14)
APC 11 x 10E
ZIPPY-H 5000 or 4000mAh 6S1P 20-30C Lipoly Pack
I'm not sure on the numbers, but by my (possibly wrong) calculations I should get close to my 100mph.
Anyone think this power system may be overkill?
Ed
Old Mar 06, 2008, 05:12 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
If the specs are right and Motocalc computes them correctly you get 100mph from your nearly 1000W.
Motor: Scorpion 4020-12; 542rpm/V; 1.92A no-load; 0.02 Ohms.
Battery: FlightPower 3700 (20C); 6 series x 2 parallel cells; 3700mAh @ 3.7V; 0.0037 Ohms/cell.
Speed Control: Castle Creations Phoenix 80; 0.001 Ohms; High rate.
Drive System: 11x10 (Pconst=1.16; Tconst=1) direct drive.
Airframe: Anything you want.
Motor Amps = 45.6
Motor Volts = 21.6
Input (W) = 986.9
Loss (W) = 93.3
MGbOut (W) = 893.7
MotGb Ef(%) = 90.6
Shaft Ef(%) = 88.3
Prop RPM = 11091
Thrust (oz) = 100.8
PSpd (mph) = 105.0
Time (m:s) = 9:44
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 06, 2008, 05:25 PM
methos is offline
methos's Avatar
Canada
Joined Jun 2006
Thanks Dr Kiwi, it's much appreciated.
Is this a power system you would suggest? In other words do you think it's the right choice?
Thanks again.
Ed
Old Mar 08, 2008, 08:59 PM
Yukonho is offline
Find More Posts by Yukonho
I see the future.
Yukonho's Avatar
Halfmoon Bay, BC, Canada
Joined Feb 2002
I found a cool comparison chart at innov8ive designs
http://www.innov8tivedesigns.com/Sco...ison%20Web.htm
Lists many options
There are a couple other motors listed on my thread here http://www.rcgroups.com/forums/showthread.php?t=830480
I am doing a similar conversion, but don't need or want 100MPH. Honestly I think you will be hard pressed to push the SS to 100 with that fat wing it has, but I look forward to the video.
Colin
Yukonho is offline Find More Posts by Yukonho
Old Mar 09, 2008, 07:44 AM
methos is offline
methos's Avatar
Canada
Joined Jun 2006
See that's the thing is, It doesn't have to be the SS... I have not bought the plane yet.
Maybe what I want is not realistic... I dunno. I want a traditional plane that actually looks like a plane like the SS or the the Pulse XT that will make a good sport aerobatic plane and at the same time will outperform most .40 - .46 glow planes in top speed.
I really don't know how fast a strong .46 will pull a SS or a Pulse, but I was lead to believe that it was aprox. 100mph.
Anyway, this is going to be put off for a little while now as I just bought my first slimer
Ed
Old Mar 09, 2008, 08:12 AM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
A really strong 2-stroke .46 using a "typical" 10x6 prop might have a pitch speed of 80 mph.
Actual level flight speed would be less than that with a typical "sport" plane.
Ken Myers is offline Find More Posts by Ken Myers
Sold Super Sportster 40 MKII w/ 7CAP Primodus Aircraft - Fuel - Airplanes (FS/W) 8 Sep 16, 2005 09:38 AM
Question .40 to pull a Great Planes Super Sportster 40 MKII ?? FlattyFlier Engines 13 May 31, 2005 07:44 PM
power system for a Guillow P-40 16.5" conversion? jessh1969 Power Systems 1 Mar 11, 2005 02:34 PM
Cool power system for a Kyosho Tigermoth .40 electric-flyer Power Systems 1 Nov 07, 2003 04:45 PM
