Go Back   RC Groups > Vendors > Hobby Lobby
Old Oct 06, 2009, 06:41 PM   #556
SAM Elc Grand Champ 04&07
Jay Burkart's Avatar
The procedure to open the case and change the battery is on the HL website FAQ,
just do a search on FCO2 and look for the battery section.
And the battery is available from HL as a part. AA1140 $9.90.
Jay
Jay Burkart is offline Find More Posts by Jay Burkart   Reply With Quote
Old Oct 07, 2009, 07:38 AM   #557
Klutzsquatch
Crapo Battery
Jay
Thanx Jay,
I'll check it out.
Mark
mgroves is offline Find More Posts by mgroves   Reply With Quote
Old Oct 07, 2009, 09:09 AM   #558
KCV6's Avatar
Mark,
The case just pops appart at the small nail indent at one corner, just don't do what I did putting it back together and crushing part of the micro ribbon cable.
Cheers... Mark
KCV6 is offline Find More Posts by KCV6   Reply With Quote
Old Oct 11, 2009, 08:09 PM   #559
KCV6's Avatar
Richie,
I managed to get hold of one of the cables from Farnell. I cut one end to length and then using a sharp blade carefully trimmed the covering off the conductors on the opposite side to the "made up" connector end. So far it is working well. It does suffer from the occasional FCO2 glitch of miss sync'd video/sound, but it did this sometimes anyway.
Cheers... Mark
Old Oct 11, 2009, 09:57 PM   #560
flying high
ElectricRichie's Avatar
Originally Posted by KCV6
Richie,
Cheers... Mark
Mark, mine arrived on friday and i haven't had time to fit it yet, I will let you know how it goes. typically though FCO2 has released a version in Europe that more or less does what I wanted, (a bare bones video only camera), and of course the connecting cable is differnent.
regards richie
ElectricRichie is offline Find More Posts by ElectricRichie   Reply With Quote
Old Nov 06, 2009, 06:36 AM   #561
Originally Posted by forrestfrank View Post
It displays WC when connected to the computer. It doesnt matter if it is in the on or off position, either way when I plug it into the computer it brings up WC in the display. When it is not connected to the computer it does nothing when switched to the on position. I have tried leaving it connected to the computer (3+ hrs.) to see if it needed to be charged but this has done nothing to change the situation.
I have exactly the same issue, i also opened it up and checked the battery with a voltmeter and the battery seems to be ok . Please help !
Dreamliner is offline Find More Posts by Dreamliner   Reply With Quote
Old Nov 06, 2009, 11:21 PM   #562
Now going 3D - Cheers, Dave.
SeaComms's Avatar
Mine doesnt display anything! Checked the battery and its fully charged, plugged into the computer it recognises it but if I try to software update it says its updating then freezes.
SeaComms is offline Find More Posts by SeaComms   Reply With Quote
Old Nov 07, 2009, 01:39 PM   #563
Wood is good.
TDisaster's Avatar
Send a message via AIM to TDisaster
That's because it's in Web Cam mode. What you need to do is go through the menu when it's on and select PC (or just turn it off when you get to PC). Then all should be fine.
Mine never worked right, until I swapped out the lipos. I put a 1s 350mah and it works great!
Wanderer Launches (0 min 52 sec)
TDisaster is offline Find More Posts by TDisaster   Reply With Quote
Old Nov 07, 2009, 10:59 PM   #564
My FCO2 stopped working on its last flight recently. I think it failed somewhere between the airplane hitting a light pole and ejecting the FCO2 into a wall, or possibly when it hit the ground. Sad - it was a fun toy.
By the way, the plane broke first - I have no idea what happened. It passed all the ground checks, but about 5 feet off the ground it stopped responding to all inputs. Except the STOP command given by the light pole (which is not even scratched).
martimer is offline Find More Posts by martimer   Reply With Quote
Old Nov 08, 2009, 04:19 PM   #565
sparkie624's Avatar
Mine failed recently, but seemed to be very hardy over all. You will see in the video that the plane (after being distracted nosed straight in like a lawn dart, under full power). Camera survived and even videoed the post flight. Right now, I think it is a battery failure more than a camera failure.
See the video.
Sparkie
Avistar Crash at RVRC Field (1 min 19 sec)
sparkie624 is offline Find More Posts by sparkie624   Reply With Quote
Old Nov 12, 2009, 01:13 AM   #566
KCV6's Avatar
broken micro ribbon cables
For those who are having problems with the FCO2 where it seems to power up but doesn't go into the record modes etc. Check the micro ribbon cable. After a while the tracks eventually fracture. Good news is you can get these cables as spare parts if the vendor you are dealing with is willing to order them from ACME. Bad news is it takes a while. I still like my FCO2 because of the pivoting head but I did get one of the Turnigy units from HK and have to say it works everytime without fail (providing you bin the slow microSD supplied and use the FCO rapid rush card instead) and definately handles low light better.
Mark
Old Nov 12, 2009, 08:35 AM   #567
Formerly a R/C Newbie
rcnewb's Avatar
The biggest complaint I have with my FCO2 are the random video cut-outs that occur anywhere from 30 seconds to 5 minutes of in-flight video recording (this is after fully charging the camera from the USB port). It's enough of an issue where I may just replace the camera with one of the models from HC.
rcnewb is online now Find More Posts by rcnewb   Reply With Quote
Old Yesterday, 12:40 PM   #568
SNOW ALREADY? where's fall
mt_flyer's Avatar
hey guys,
I just got my new FlyCamOne2.. I have some questions/issues
Firmware update.. does mine need it.. has an "A4" on sticker back of lens...
I connected it to my ch5... it will not remote shutter... works ok as stand alone (manual control)
Any ideas
mt_flyer is offline Find More Posts by mt_flyer   Reply With Quote
Old Yesterday, 04:37 PM   #569
That is the latest firmware.
I advise NOT doing a firmware upgrade.
Also to make it a remote shutter you have to use the FlyCamOne2) Receiver Control Cable Control your FlyCamOne2 from your transmitterProduct# AA2013Price: $15.90
You cannot connect it directly to the receiver.
Jay
Old Yesterday, 09:59 PM   #570
mt_flyer's Avatar
Jay
thanks for the reply...
I have the cable.. set end points to 150% on ch 5.... still will not remote operate
mine was part # FC2013 came with the camera in the kit
Bored? Want to fight?
Join the RCGroups clan!
