Old Jan 04, 2003, 02:55 PM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
How to make your Hitec wall wart into a slow charger for your flight batts
Someone posted the part # for the rat shack connector used in conjunction with your hitec wall wart charger (used to charge your tx pack) to slow charge your flight packs. Use this method for brand spankin new packs. The hitec wall wart is 55 mah output. Here is the pic of the part # you need to get at the shack.
Roughly a couple of bucks.
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Jan 04, 2003, 03:06 PM
Joined Jun 2001
Once you have the connector, solder two wires to 2 of the three tabs and then on the other side, solder your favorite connector to connect to your pack. I've included a pic. On the connector, the tab that is the center of the plug is the + connection (my yellow wire). If you look really close, the - connection (black wire) is underneath the top (these are seperated by a brown thin insulator. When you a done, plug in everything and if you did it right, the red light on your charger lights up. The very bottom-most tab that goes into the side of the plug is not used. Be very careful of your connection and how your wires are oriented towards your connectors or you may blow a fuse, blow the pack or ruin the charger. Something like this...
---I ---> top/middle is the positive or +, center metal part
--- ---> thin brown insulation
---I ---> tab that is the - or negative, underneath the brown
---I ---> tab that goes into middle of plug (not used)
Pic is tough to see. My first attempt, charger's red light didn't come on. Changed the negative lead/tab to underneath the brown insulator and it worked fine.
Dave...
Old Jan 05, 2003, 01:48 AM
MrFlyer is offline
Find More Posts by MrFlyer
MrFlyer's Avatar
Abbotsford, Canada
Joined Sep 2002
I did the same thing with my Airtronics charger about a month ago. Works great for slow charging your flight packs.
MrFlyer is offline Find More Posts by MrFlyer
Old Jan 05, 2003, 06:35 AM
Joined Jun 2001
Yeah, its great for those of us who are currently "high end charger" challenged. I've got (2) 8 cell 600 AE nicads charging right now because I left them on a battery dumper too long.
When you connect them up to a MRC Superbrain charger, the voltage output reads a little over 5 volts or so. Could be that they
are totally bad and need thrown out.
Dave...
Old Jan 05, 2003, 08:39 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
I did the same thing...
Only I have so many TX/RX wall chargers I just cut the connector off one and soldered my Sermos right to the wires.
I need to get to Radio Shack and find a chepo 15v 50ma one for my 10 cell packs.
I feel better about not always pumping 1amp into my poor 600ae packs.
Question How to make your own 3D models for AFP(D)? Dennis.f Simulators 2 Mar 15, 2006 02:19 PM
Wanted HiTec Wall Wart Charger screamin' eagle Aircraft - General - Radio Equipment (FS/W) 0 Jun 09, 2005 10:29 AM
WTB Futaba or Hitec wall wart charger rcsoar4fun Aircraft - General - Radio Equipment (FS/W) 1 Jan 13, 2005 07:06 PM
WTB - HiTec Wall Wart Charger screamin' eagle Aircraft - General - Radio Equipment (FS/W) 0 Nov 30, 2004 06:00 PM
ParkFlyer Wall Hangers--How to Make Your Own! DavidJ Parkflyers 9 Feb 01, 2003 06:56 AM
