Old Mar 04, 2008, 07:15 AM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Contest
Kit/Plan Fun Build - Guillow's DH4
Thought I'd join in the fun with this one.
It's a 27" span 1964 Guillow's DeHavilland 4 Biplane.
Kit #205 - no longer produced. This one came off E-bay.
I love the look of this plane - it looks like a big old Mack truck with wings
I saw a restored one in a magazine recently done in bergundy red & white - What a stunner!
I started it yesterday and have the fuselage mostly framed.
As for what's going in it? I have no idea yet.
Along these lines probably.
Brushless outrunner
7.4V 800ma/hr lipo
5 gram servo's
Corona 4ch synth Rx
6" prop (scale is a 6" 4 blade)
Flight characteristics Im after is a stable, docile flyer that's all.
This should keep me busy for a week or two
Phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Mar 04, 2008, 07:26 AM
Ascolta is offline
Find More Posts by Ascolta
Joined Sep 2005
I have this kit in my stash & often thought of building it-glad to see you are doing more than thinking about it! Should be a winner Phil-thanks for sharing.
Dale
Ascolta is offline Find More Posts by Ascolta
Old Mar 04, 2008, 11:52 AM
TIREMAN302 is offline
Find More Posts by TIREMAN302
TIREMAN302's Avatar
LAKE WORTH, FL
Joined Feb 2008
Good afternoon Phil,
You just brought me down memory lane, that was my first Guillow's kit.
Built it in '78 as a FF.
Best of luck with her,
Joe
TIREMAN302 is offline Find More Posts by TIREMAN302
Old Mar 04, 2008, 02:57 PM
Rekitter is offline
Find More Posts by Rekitter
Rekitter's Avatar
Oakland, CA
Joined Nov 2002
Hey Phil:
Another unique and interesting guillow's conversion. Should be a piece of cake after the B-17 and PBY... though the small size and need to keep it light should add an element of challege! I have the Rumpler C-5 of similar size stashed away and am looking forward to seeing how you do this conversion. Looks like you are off to a fast start and I am sure that you will have another nice bird soon!
Alex
Rekitter is offline Find More Posts by Rekitter
Old Mar 04, 2008, 03:15 PM
MPP is offline
MPP
Find More Posts by MPP
MPP
In Unusual Attitude Recovery
MPP's Avatar
Danbury CT (DXR)
Joined Oct 2005
Phil,
Subscribed, Great find.
Hey this one screams Vario prop http://www.e-flightline.com Just cut the prop nut flush.
Have fun,
M
MPP is offline Find More Posts by MPP
Old Mar 04, 2008, 03:31 PM
Steve85 is online now
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Hey Phil,
Nice catch! I built the Rumpler for FF from the same series as a teenager back in the '70s. Wish I could find one of those kits today! Keep on posting...
Steve
Steve85 is online now Find More Posts by Steve85
Old Mar 04, 2008, 03:42 PM
jofrost is offline
Find More Posts by jofrost
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
Phil ,
Welcome to the FunBuild You've been added to our list
-John
jofrost is offline Find More Posts by jofrost
Old Mar 04, 2008, 08:25 PM
mrfrogdude is offline
Find More Posts by mrfrogdude
Joined Feb 2008
Very neat plane! I will keep checking your thread out, sounds like it will be very nice!
Mark
mrfrogdude is offline Find More Posts by mrfrogdude
Old Mar 04, 2008, 09:12 PM
Registerd Beaver
Joined Jul 2003
Thanks for the interest & well wishes chaps.
This one is quite a fun little build.
I've hacked off a lot of 'spare' timber so far & I could take off a lot more.
However I'm not a big fan of nano-lite models, they have to be able to ground loop & not break. That's about the only stipulation for me.
I'll look into the varioprop Mark, but at this point I'll stay lightweight and mod later. So will probably get a GWS 6x3 to start with.
I rummaged around last night & found some unused B/L motors.
I'll have to run them on 7.4 volts to see the current draw & decide from there.
I have some old sp350 & G'boxes lying around but one of those takes up the entire front end & pushes the battery well back so that is out of the equation now. Add to that the weight of mounting stick & bracketting it would be a lot of work for the return.
A small outrunner will fix easily onto the firewall and if I need nose weight, I'll upsize the lipo.
Gut feeling tells me such a long nose will give me lots of room to experiment with.
I found a pic of the DH4 I was on about, the colour is off a bit but it shows the idea.
It's actually maroon/bergundy with silver wings.
Anyhow, I hope to get a bit more done tonight.
phil
Old Mar 04, 2008, 09:18 PM
shrub wacker is offline
Find More Posts by shrub wacker
Got Epoxy
shrub wacker's Avatar
Salisbury Ma
Joined Dec 2004
Nice one Phil, subscribed as well.
Glenn
shrub wacker is offline Find More Posts by shrub wacker
Old Mar 05, 2008, 08:57 AM
Registerd Beaver
Joined Jul 2003
A few more pics.
Motor is a a re-wound BP2408-21.
It was originally re-wound to swing a 5x3 on 3S.
Now i'll try a 6x3 or 6x4 on 2S. I expect to have to re-wind it again to suit but that only takes me an hour nowadays (done many of 'em before)
Ideally about 8 amps WOTshould give me a good flight time/power ratio
Battery will sit on a plate above the motor, ESC sits directly behind motor - all very handy indeed.
Rudder/elevator servos will go in later, I'll use them to assist CG balance.
Trying to use up what I have around the shop on this one.
Off to bed now...zzzzz
Old Mar 05, 2008, 10:21 AM
Joined Feb 2008
Very nice! These conversions are really fun to do, I will have to do some more of them soon.
Mark
Old Mar 05, 2008, 08:08 PM
uavdb is offline
Find More Posts by uavdb
What????
SoCal "The High Desert"
Joined Nov 2003
I still have the plans from the one I built about 10 years ago, and have considered scratching a new one, but with a box frame fuse and upper formers.
uavdb is offline Find More Posts by uavdb
Old Mar 06, 2008, 08:38 PM
Registerd Beaver
Joined Jul 2003
Got a little more done last night.
Pics to come later.
Did the hatch for the battery. Thought I'd need some grease & shoe horn but got it sorted in the end.
I calc'd the wing area to be 189 square inches on this plane! (27" span x 3.5" chord x 2 wings)
That is amazing when you think that the Guillow's Liberator is 190 sq in !!
So if this weighs an even 10 oz's in the air, the wing loading is around 7.6 oz/ft2
That should be quite a floater I'd expect.
With WOT 8 amps@7.0V = 56 Watts
That would equate to around 90W per lb if my maths are right.
Slightly off-scale but who cares.
It will be interesting to see if the gyrosopic effect of the bell motor offsets the P factor (left hand drift at take-off) of the prop.
With this much power it may be very tricky.
Old Mar 09, 2008, 06:22 PM
170flyer is offline
Find More Posts by 170flyer
United States, NC, Denver
Joined Jul 2007
any more pic's!!
170flyer is offline Find More Posts by 170flyer
Discussion Kit/Plan Fun Build Contest, Berkeley Aeronca Sedan E-Challenged Scale Kit/Scratch Built 104 Nov 25, 2015 12:33 PM
Build Log Kit/plan fun build contest: Luscombe Silvaire GeoffinIN Scale Kit/Scratch Built 160 Oct 10, 2011 07:13 AM
Discussion Kit/Plan Fun Build Contest Easybuilt Handley Page Hampden D-Rock Scale Kit/Scratch Built 47 Mar 20, 2011 07:33 PM
Build Log Guillows R/C conversion or Pimp My P-38 or Kit/Plan Fun Build Contest, 62pilot Scale Kit/Scratch Built 38 Mar 28, 2009 01:46 PM
Build Log Kit/Plan Fun Build Contest - Easybuilt Westland Lysander jofrost Scale Kit/Scratch Built 173 Jun 04, 2008 06:32 AM
