Old Apr 13, 2008, 03:45 PM
21xct45 is offline
Find More Posts by 21xct45
Southern Utah
Joined Mar 2008
Oooops...coulda fixed my nose cowel over motor before I took the picture....
21xct45 is offline Find More Posts by 21xct45
Old Apr 13, 2008, 05:19 PM
Heliman420 is offline
Find More Posts by Heliman420
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
i got the cessna setup now, ran into a few difficulties but nothing unexpected,
the landing gear was bent the wrong way,it took a bit of bending and twisting to correct it,
the little aluminum collar just below the main servo push rod collar, the set screws were stripped on both sides , luckily i had another collar of an old fp heli witch was a perfect fit, the wheel fairings had to have a bit of material removed for the wheels to spin smooth,
installing the stabilizer was tricky, in the instructions it said to insert from the side, but that was impossible to do due to the size of the stab and the exixting slot,
i had to cut away a 3 inch portion of the rear of the fuse to install the stab and then reglued it. i also removed all the fruity skyartec stickers.
heres how it sits now, awaiting its maiden,
Heliman420 is offline Find More Posts by Heliman420
Old Apr 13, 2008, 06:21 PM
21xct45 is offline
Southern Utah
Joined Mar 2008
Your plane looks great! I thought mine would be red but it is blue (thats O.K)....I think you said yours is the motor with a gearbox (?) anyway I wonder if in order to get a red plane you need to get the one with a gearbox? Hmmm? No "maiden" yet as I have been out of the hobby for a few years and am practicing on a few other beat up planes for now.....this thing is so pretty I hate to crash it ........ Had to "dremmel" the landing gear wires so they didn's stick out past the wheels so far but seems O.K ........later.....
PS How bout a better picture of the way you set up your front wheel including the way it's connected to the servo?..........
Old Apr 13, 2008, 06:57 PM
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
yep i have the gearbox version,, as for the pics..unfortunately those were taken with a cell phone cam, i killed my digi cam a few months ago and havent got a new one since, i can try... but the quality will be really bad(for close up shots)
Old Apr 13, 2008, 07:37 PM
Lobo is offline
Find More Posts by Lobo
Vicksburg, MS
Joined Aug 2003
Hey guys....looking good! Anxious for y'all to fly them.
21xct45, I used the free FMS sim (google for it, if you haven't heard of it) to practice, since this was my first airleron plane. It really helped my confidence a lot. I would have never tried a roll without it! On the front gear setup, you could always glue (or better yet use JBWeld) a servo arm to the top of the gear shaft and still use it as steerable. I've never had a steerable plane before, and I find when my battery is getting low, I just stay on the ground and enjoy the heck outta driving it around the parking lot! Your wheels look good. I just measured the ones that came with my Cessna, and they are 1 1/2" diameter. The ones you have on your plane look a little bigger. Seems the front one is about as large as you can put on the nose gear of this plane without rebending or using different nose gear wire.
heliman420, those are different instructions than the plane we got for installing the tail section. Ha! I was able to just cut one slit near the rear of the fuselage and slide the horz stab into place, and then glue it. I'm sure what you did will work just as well. And, yes, the nose gear is the main problem with this plane. They could have made it a little better quality. I ended up stripping all the set screws in the collars trying to get them tight enough to not slip, and therefore just used JBweld to make it all one piece. It don't slip now!
Still, all in all, for the little inconveniences with a little less than perfect quality of this model, for the money, it's a real deal, and a real blast to fly!
I'm anxious to hear the flight reports!!
Lobo
Lobo is offline Find More Posts by Lobo
Old Apr 13, 2008, 09:32 PM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Does your have a brush less motor and a gear box and what size battery does it take?
raz is offline Find More Posts by raz
Old Apr 13, 2008, 10:10 PM
21xct45 is offline
Southern Utah
Joined Mar 2008
Sorry if off subject....That pic of "Arnold' makes me laugh everytime you post....
Old Apr 13, 2008, 11:01 PM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Me too..
Old Apr 13, 2008, 11:08 PM
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
no i have the brushed version, with the 1100 mah 3s lipo. seems to make a decent amount of thrust at full throttle
Old Apr 14, 2008, 05:51 AM
21xct45 is offline
Southern Utah
Joined Mar 2008
Me too..
O.K I'm laughing again..........but anyway, It's been so darn windy here lately I'm try'ing to get out very early and fly my beat up planes ....so I wanted to know if anyone had this same problem with their Cessna? The push on plugs from esc to battery (mainly the pos) did not stay connected well at all. I soldered on some "Deans" ......
Old Apr 14, 2008, 05:56 AM
21xct45 is offline
Southern Utah
Joined Mar 2008
Hey sorry....I forgot, Didn't I read somewhere where you can get rid of the "goofy" music from the esc when you plug in the batt?
Old Apr 14, 2008, 09:17 AM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Thanks, I didn't know there was a brushed version. I'm thinking of getting one of these but I want the bl model IF it will run on a 3s lipo.
Old Apr 14, 2008, 10:37 AM
Lobo is offline
Vicksburg, MS
Joined Aug 2003
Man I hope so!!!! If you find out how, PLEASE let me know! It sounds like a Circus came to town when you plug 'er up!
Lobo
Old Apr 14, 2008, 10:39 AM
Lobo is offline
Vicksburg, MS
Joined Aug 2003
I never tried using them, just put my standard plug on right away. If you soldered on a Deans plug, you solved it!
Lobo
Old Apr 14, 2008, 10:42 AM
Lobo is offline
Vicksburg, MS
Joined Aug 2003
Looks like either version will run on 3s lipo......so, go for it, you'll like it! The brushless (no gearbox) one from Hobbycity comes with a 1100mAh 3s Lipo (no charger).
Lobo
Discussion Hobby Lobby ST Models Cessna 182 Aeleron ARF. (Mini Review) ShokWaveRider Beginner Training Area (Aircraft-Electric) 32 Yesterday 07:26 AM
Article Parkflyers.com's Cessna 182 27mHz RTF Park Flyer Review tailskid2 Electric Plane Talk 24 Dec 20, 2014 05:47 AM
Article Horizon Hobby's E-Flite Brand Cessna 182 ARF Review RichN Electric Plane Talk 32 Jul 14, 2008 09:13 PM
Discussion Incredibly biased Fly RC review of E-flite Cessna 182 Prep I Parkflyers 37 Mar 04, 2007 12:33 AM
