This thread is privately moderated by Smokin' Beaver, who may elect to delete unwanted replies.
Old Dec 06, 2012, 06:35 PM
cwolfe is offline
Find More Posts by cwolfe
cwolfe's Avatar
United States, TX, Spring
Joined Aug 2011
I've started the kit# 201 Thomas Morse build.
cwolfe is offline Find More Posts by cwolfe
Old Dec 07, 2012, 03:47 AM
eteet is offline
Find More Posts by eteet
ET
eteet's Avatar
United States, DE, Hockessin
Joined Apr 2006
Sticky?
Hey Mr. Beaver,
How about a sticky for this thread where people can post setups for their models. Motor, prop,battery combos? Rx and servo choices?
That would be a lot easier than picking through all the threads to see what other folks have used.
Whatdoyathink?
Eric
eteet is offline Find More Posts by eteet
Old Dec 07, 2012, 05:57 PM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Hi Eric,
Sounds like a great idea.
What you need to do is start that thread (give it a meaningful title) Then you can get everyone to post their setups on it.
The subscribers will lobby the moderators to make it a sticky if they think it is worth it. ( I have no ability to make sticky's as I'm not a moderator).
Once it is established I'll put a link to it on post # 1 of this thread.
Cheers - Phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Dec 07, 2012, 06:20 PM
cwolfe is offline
cwolfe's Avatar
Joined Aug 2011
what's Sticky?
Old Dec 07, 2012, 09:19 PM
meltor is offline
Find More Posts by meltor
AKA Jagdpanther9
meltor's Avatar
Joined Jun 2012
i would be interested in this as well. just give me directions on how to.........
meltor is offline Find More Posts by meltor
Old Dec 08, 2012, 02:14 AM
eteet is offline
ET
eteet's Avatar
Joined Apr 2006
I did it! Surf on over to the Micro and Indoor Forum and post your setup!
Eric
Originally Posted by Smokin' Beaver View Post
Hi Eric,
Cheers - Phil
Old Dec 15, 2012, 10:17 PM
cwolfe is offline
cwolfe's Avatar
Joined Aug 2011
I started a Guillows kit #201 conversion build log.
http://www.rcgroups.com/forums/showthread.php?t=1789824
Old Dec 16, 2012, 04:48 PM
RedTaco is offline
Find More Posts by RedTaco
RedTaco's Avatar
United States, CA, Castro Valley
Joined Jan 2012
Kit Number: 302
Kit Name: Guillows Cessna 170
Builders name: RedTaco
Hyper-Link to the thread: http://www.rcgroups.com/forums/showt...8#post23531790
Thanks Phil
RedTaco is offline Find More Posts by RedTaco
Old Dec 17, 2012, 04:19 PM
kml.krk is offline
Find More Posts by kml.krk
kml.krk's Avatar
United States, NY, Queens
Kit Number: 1005
Kit Name: Guillow's F6F-3 Hellcat
Builders name: kml.krk
Hyper-Link to the thread: http://www.rcgroups.com/forums/showt...2#post23553240
Thank You!
kml.krk is offline Find More Posts by kml.krk
Old Dec 20, 2012, 12:36 AM
tanner331 is online now
Find More Posts by tanner331
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Hi
I started back up on my piper super cub build.
Here is a link http://www.rcgroups.com/forums/showt...3#post20481656
Here is a picture of one of the wings I just finished covering.
Tanner
tanner331 is online now Find More Posts by tanner331
Old Dec 20, 2012, 10:58 PM
meltor is offline
AKA Jagdpanther9
meltor's Avatar
Joined Jun 2012
kit 505 me109 rc conversion
Kit Number505
Kit Name messerschmitt BF-109
Builders name meltor
Hyper-Link to the thread http://www.rcgroups.com/forums/showt...2#post23582940
this is a rc conversion using the park zone ultra micro p-51 running gear
Old Dec 27, 2012, 07:16 PM
Bob from MD is offline
Find More Posts by Bob from MD
I fly wood.
Bob from MD's Avatar
United States, MD, Columbia
Joined Jun 2009
Kit 304 PC-6 Porter conversion
Just finished a conversion of a Guillowís PC-6 Porter. I built it pretty much to the plans with a few modifications. The stabilizer is scale size. The rudder and elevator have 1/16 gussets at the corners along the hinge line for reinforcement and to mount the control horns. A .8 mm CF rod reinforces the connection between the elevator halves. I replaced the kitís tail wheel with a lighter one. The landing gear is the one supplied in the kit but the other braces are .8 mm CF rod. I taped the 3.7 gram servos to the cabin sides with double sided carpet tape. They are positioned between the wing dowels to make it easier to get at the screw for the servo arms. The push rods are 1 mm CF rod. I left the top of the cabin uncovered till the end after I had all the RC gear placed and adjusted. The firewall is 1/16 ply. First Iím going with the 5 gram motor and 4 x 2.5 prop. Iím hoping it has enough oomph. Later, I may change to a 10 gram motor when we aero tow small sailplanes. Fortunately, the motor mount is the same for both and I used a 3 pin connector to the 6 amp ESC to make the change easier. Iíll change the thrust angle as needed with washers when I do the test flights. I made a copy of the lower right corners of the F2 and F4 formers to make the battery hatch. There is a small balsa shelf with Velcro to hold the 138 mAh 2s battery in place. It is covered with Microlite. The AUW is 83 grams/3 ounces. Iím just waiting for the weather or a suitable indoor venue to do the test flights.
Bob from MD is offline Find More Posts by Bob from MD
Old Dec 28, 2012, 12:01 AM
Registerd Beaver
Joined Jul 2003
Thanks Bob it looks fantastic.
That's the first one we've seen on this new release model.
Do you have a link to the build thread please? This thread is not for the the questions and enquiries that will come as a result.
Cheers - Phil
Old Dec 28, 2012, 08:01 AM
I fly wood.
Joined Jun 2009
Phil,
I started a build log for the Porter. It is the post above to start. I'll be glad to add additional info.
Bob
http://www.rcgroups.com/forums/showthread.php?t=1796744
Old Jan 05, 2013, 05:24 PM
uniondelta is offline
Find More Posts by uniondelta
Umůn Takahashi
Puebla, Pue.
Joined Sep 2008
cessna 150 from Guillow's
Hi friends, i'd like to share something
http://www.rcgroups.com/forums/showthread.php?t=1079339
uniondelta is offline Find More Posts by uniondelta
R/C Guillow's B-24 Flyer103 Power Systems 6 Oct 26, 2007 08:05 AM
Discussion Guillow's Arrow Build and RC Conversion wbatta Parkflyers 0 Sep 23, 2007 07:20 PM
Build Log Guillow's B-17G Electric Build crxmanpat Scale Kit/Scratch Built 20 Mar 03, 2007 04:47 PM
Question To build a Guillow's Messerschmitt BF-109 or not? Wally_Gator The Builders Workshop 4 Jan 31, 2007 01:32 PM
Guillow's build... Scudrunner77 Scratchbuilt Indoor and Micro Models 11 Nov 18, 2005 11:28 AM
