This thread is privately moderated by Smokin' Beaver, who may elect to delete unwanted replies.
Old Nov 13, 2012, 05:36 PM
rob737 is offline
Find More Posts by rob737
United States, CT, Guilford
Joined Nov 2008
hi fellows, i have this one on the way from megahobby. i've built more guillows kits than i can remember, but most were many years ago and were flown control line with cox 049 motors. this will be my first r/c conversion. there is a lot of great information on these threads (and very beautiful models!). the main thing i've learned is to keep the models light. i think i can build this with components on hand. i searched, no threads on this one yet?
regards.....rob
rob737 is offline Find More Posts by rob737
Old Nov 13, 2012, 11:41 PM
gupi is offline
Find More Posts by gupi
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Hi Rob,
I think is actually a new one - Guillow just released it not so long ago. So you might be one of the first people doing a conversion.
Yours, gupi
gupi is offline Find More Posts by gupi
Old Nov 14, 2012, 08:40 AM
rob737 is offline
Joined Nov 2008
hi gupi,
thanks for the reply! i too think it's a newer kit since it's laser cut. i've built one of those before (the se-5) and wouldn't it be nice if they used this method on all of their models! along with the beaver this one was also released:
http://www.guillow.com/pc-6porter.aspx
and of course the beaver:
http://www.guillow.com/DHC-2Beaver.aspx
i'm just about to put an order in for some components. the plan is for a power up 250 slow fly from headsuprc, a 10amp esc, and 2s batteries in the 450mah range. am i on track as far as keeping this model light enough?
i have the fairchild 24 kit and also the sopwith camel which i may work on later this winter...hoping all goes well with the beaver first!
rob
Old Nov 14, 2012, 01:37 PM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Sounds definitely right - i use motors in the same range. I usually use 2s batteries with 600mAh. I think at this size you should aim for 200 to 250 grams ready to fly.
Old Nov 14, 2012, 09:39 PM
rob737 is offline
Joined Nov 2008
thank you, sir! i've got parts on the way for the beaver and the fairchild. i've got to clear my bench in the mean time. i'm just about finished with the beautiful new art-tech fokker triplane. mostly just some more carving left on that one so i can get my batteries to fit then i'll switch things over to balsa construction. can't wait to get started!
rob
Old Nov 18, 2012, 02:09 PM
ocminimoto is offline
Find More Posts by ocminimoto
ocminimoto's Avatar
Canada, BC, Nanoose Bay
Joined Jan 2007
Ahen... Beaver
Flys from land, haven't maidened it off water yet. Having trouble lining up a camera person and a retrieval vessel so I have yet to maiden it off water although the floats work great.
Has 6 linear servos: rudder, elevator, alerons, and flaps.
If you build one, you might want to add a hint of dihedral and twist the wing tips up. The narrow hershy bar wing tends to like to stall and as always it's FAST.
I used a carbon fiber rod instead of a balsa stringer for the top wing (for lack of a better name) spar. Can pick the whole model up by the wing tip.
Lets see some videos of these things working from water.
ocminimoto is offline Find More Posts by ocminimoto
Old Nov 19, 2012, 12:57 AM
meltor is offline
Find More Posts by meltor
AKA Jagdpanther9
meltor's Avatar
Joined Jun 2012
Originally Posted by Smokin' Beaver View Post
Kit Number 501
Kit Name curtiss p-40 warhawk
Builders name meltor
Hyper-Link to the thread http://www.rcgroups.com/forums/showt...5#post23309006
this is my latest guillows build.i liked the p-40 as it has alot of room up front for the battery,servos,and hardware.there is no problem with this plane being tail heavy.
meltor is offline Find More Posts by meltor
Old Nov 19, 2012, 05:02 AM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Nice pics boys, can you please attach a link to your build thread?
Cheers - phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Nov 19, 2012, 02:28 PM
rob737 is offline
Joined Nov 2008
ocminimoto.....your model looks great! i noticed in the plans in my kit that there is a provision to add 4 degrees of dihedral for the flying version of this model. is that about what you added to yours? i'm just about ready to start the build, but may loose my work table to thanksgiving set up . should be able to start building it just before the weekend.
rob
Old Nov 24, 2012, 06:04 PM
ocminimoto's Avatar
Joined Jan 2007
Rob, nope mine's a real Hershey bar wing. 0 degrees dihedral because of the carbon rod I used for the topmost wing spar. It doesn't like to bend at all. Needed to add as much wing tip twisting as I could get with a steam kettle. If I was to do it again I might add a hint.
I don't know if the flying dihedral recommendation is for rubber or electric power. I'm leaning towards rubber free flight.
Thanks!!!
Phil, I'll see what I can do. Cheers!
Old Nov 25, 2012, 12:21 AM
Registerd Beaver
Joined Jul 2003
Thanks guys, I'm going to start a thread cleanup soon to remove all chatter & non-gallery posts.
Cheers - Phil
Old Dec 01, 2012, 04:01 PM
ocminimoto's Avatar
Joined Jan 2007
Beaver build thread.....
http://www.rcgroups.com/forums/showt...4#post23414260
Old Dec 01, 2012, 07:47 PM
meltor is offline
AKA Jagdpanther9
meltor's Avatar
Joined Jun 2012
Kit Number 602
Kit Name piper super cub 95
Hyper-Link to the thread http://www.rcgroups.com/forums/showt...0#post22956975
super cub 95 build linkie
Old Dec 04, 2012, 05:24 PM
glewis is online now
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Hey Phil.
Had an update to post and there seems to be something wrong with the links on the front page to my models. If I click on the T-28 link it takes me to a Cessna 172 build and the Skyraider link takes me to the T-28 thread.
Skyraider thread ,http://www.rcgroups.com/forums/showt...t=guillow+t+28
T-28 thread, http://www.rcgroups.com/forums/showt...t=guillow+t+28
Glenn
glewis is online now Find More Posts by glewis
Old Dec 04, 2012, 08:00 PM
rob737 is offline
Joined Nov 2008
the links seem to be working just fine, sir. very nice builds!
rob
R/C Guillow's B-24 Flyer103 Power Systems 6 Oct 26, 2007 08:05 AM
Discussion Guillow's Arrow Build and RC Conversion wbatta Parkflyers 0 Sep 23, 2007 07:20 PM
Build Log Guillow's B-17G Electric Build crxmanpat Scale Kit/Scratch Built 20 Mar 03, 2007 04:47 PM
Question To build a Guillow's Messerschmitt BF-109 or not? Wally_Gator The Builders Workshop 4 Jan 31, 2007 01:32 PM
Guillow's build... Scudrunner77 Scratchbuilt Indoor and Micro Models 11 Nov 18, 2005 11:28 AM
