Old Mar 02, 2008, 01:13 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Build Log
My AP "Solution"
After working with the construction methods of the Beast I have decided to experiment a bit more. I had numerous requests for a "side mount" on the Beast but the design was pretty much fixed on front mount. That said, I have come up with a possible answer. Since there are two "Beast" threads already and this looks way different. I will call this new ship the "Solution" This bird will be a bit heavier than the Beast but not that much. I see a 2.5-3 oz overall gain. I have been shooting pics through the build, I will get to them later. Here is where I am right now....
Other changes....
1. Camera mounting galore!
2. All components ESC, RX, ect... are inside
3. Pusher configuration
4. 2" wide beaded foam for fuse
5. Close to 1000 sq in on the wing
6. Ugly battery mount is gone....
7. Reduce tip dihedral to 10 deg included
Bang or bust here we go
Edit: Maiden went very well, here is the video
Videos!!!
http://www.mvqf.com/power/Beast/Solution%20Maiden.wmv
http://www.mvqf.com/power/Beast/Do%2...20thing....wmv
http://www.mvqf.com/power/Beast/Gravel%20pit_0002.wmv
http://www.mvqf.com/power/Beast/Mankato.wmv
http://www.mvqf.com/power/Beast/Things%20we%20do.wmv
http://www.mvqf.com/power/Beast/Than...r%20Cruise.wmv
The plans are free, if you have success with the build and feel they are worth it. a $5.00 Donation will be greatly appreciated. Thanks!
PayPal DONATION
In flight pics:
http://www.rcgroups.com/forums/showp...&postcount=100
PLANS: http://www.rcgroups.com/forums/showp...&postcount=107
Wing locator info/install
http://www.rcgroups.com/forums/showp...&postcount=165
DXF/DWG FILES: http://www.rcgroups.com/forums/showp...&postcount=411
WINGTIP SPAR MOD http://www.rcgroups.com/forums/showp...&postcount=600
power is offline Find More Posts by power
Old Mar 02, 2008, 01:27 PM
JimKallinen is offline
Find More Posts by JimKallinen
JimKallinen's Avatar
New Ulm,MN,USA
Joined Nov 2007
Now you really have my attention, A pusher sure does make more sense.
Are you going to change your wing profile with the pusher design ? Like
say add some chord and length ?
Have a feeling you will find far less vibration when filming this way.
Looking forward to seeing a first flight video.
Jim
JimKallinen is offline Find More Posts by JimKallinen
Old Mar 02, 2008, 01:29 PM
paulrene is offline
Find More Posts by paulrene
Happy landings
Trondheim, Norway
Joined Jul 2007
Damn! Now I'll have to do another build!
paulrene is offline Find More Posts by paulrene
Old Mar 02, 2008, 01:39 PM
California Condor is offline
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
You got my attention also.
California Condor is offline Find More Posts by California Condor
Old Mar 02, 2008, 02:55 PM
AC5FF is offline
Find More Posts by AC5FF
Where'd The Wise Men Go?!?
AC5FF's Avatar
United States, NE, Bellevue
Joined Sep 2007
WoW
Can only say I wish I had your imagination!!!!
I'm curious: Jim mentions adding some cord/length to the wing? Also says about finding less vibration like this.. Is that due to the pusher configuration or is that due to a longer/deeper wing?? Just trying to get a handle on the physics.
Ya know; this keeps going we're going to see a Bi-Beast soon!!!
AC5FF is offline Find More Posts by AC5FF
Old Mar 02, 2008, 03:05 PM
kd7ost is offline
Find More Posts by kd7ost
Professor of Wood
kd7ost's Avatar
Nampa. Idaho
Joined Nov 2004
Nice clean work Mike. You're a good builder.
Dan
kd7ost is offline Find More Posts by kd7ost
Old Mar 02, 2008, 03:16 PM
DiveBombDave is offline
Find More Posts by DiveBombDave
Pull out early!
DiveBombDave's Avatar
Lexington, KY
Joined Jan 2005
Great job on all the iterations of this design, Mike. Simple, effective, light.
Dave
DiveBombDave is offline Find More Posts by DiveBombDave
Old Mar 02, 2008, 03:20 PM
Vintauri is offline
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Dan
You can say that. His cuts are so precise it's amazing how clean he can make these foam planes. I like having a buffer of someone elses planes between his and mine Gives mine a chance to look decent.
So what did your wife say about sticking the D70 up there?
Steve
Vintauri is offline Find More Posts by Vintauri
Old Mar 02, 2008, 04:50 PM
power is offline
power's Avatar
Joined Apr 2003
Thanks guys,
AC5FF,
I really don't see a big advantage as far as vibration goes for being a "Pusher" I do however have a bit more volume in the body to help the dampening. I have yet to have any vibration troubles (knock on wood) with the Beast. The wing cord will remain the same. The foil will be a smidge thicker. I am gaining the squares by wing span. The center section will be 40" and the tips will be what ever it takes to get what I need
Steve,
Hee hee, she was sleeping on the couch. If she saw me putting the D70 in position on the plane, I would have got the "look" maybe more she knows what happens when I start eyeing things up on my planes
Old Mar 02, 2008, 05:14 PM
skymind is offline
Find More Posts by skymind
Colorado
Joined Jan 2005
Great ideas Mike. I'm glad you have backup cameras so if you do chose to fly with the DSLR and destroy it, I can see it.
skymind is offline Find More Posts by skymind
Old Mar 02, 2008, 08:02 PM
Pull out early!
Lexington, KY
Joined Jan 2005
I like to scribble crude airframe drawings on a napkin and then set *her* D200 on a kitchen scale and then start on the calculator....
It works still, even after dozens of times.
Dave
Old Mar 02, 2008, 08:10 PM
Real Ira is offline
Find More Posts by Real Ira
Not THAT Ira
Real Ira's Avatar
Coupeville, Wa
Joined Jan 2006
Hey Power,
Very cool design.
Looks like a nice slow camera platform and it's hard to beat that foam sandwich for strength to weight.
Ira
Real Ira is offline Find More Posts by Real Ira
Old Mar 03, 2008, 04:36 AM
Badllarma is offline
Find More Posts by Badllarma
Die noctique
Joined May 2007
Love idea of multi camera mounts
Badllarma is offline Find More Posts by Badllarma
Old Mar 03, 2008, 06:31 AM
jsirkia is offline
Find More Posts by jsirkia
Electronic juggler
Joined Jan 2004
This makes me really glad I've been in a hurry with other projects, otherwise I would have started making a Beast already. This looks even nicer... Actually the face looks almost jolly, the curve under the wing mount reminds me of japanese cartoon characters' eyes.
Are you going to publish plans for this as well or offer a short kit or some such?
-Jussi
jsirkia is offline Find More Posts by jsirkia
Old Mar 03, 2008, 07:58 AM
quailbird is offline
Find More Posts by quailbird
quailbird's Avatar
Rich Hill Missouri 64779
Joined Nov 2003
Oooooooooooooooo! I like it! You are a great builder. Can't wait to see it fly!
quailbird is offline Find More Posts by quailbird
My AP msn Group ian hall Aerial Photography 2 Mar 25, 2004 06:34 PM
"Camstar" - my AP platform pro_sniper Aerial Photography 17 Jan 22, 2004 03:39 PM
my AP Slow Stick shots hemna Aerial Photography 29 Jan 13, 2004 06:36 PM
My AP SS - AUW, Aiptek mount + PIC controller Texy Aerial Photography 13 Jul 14, 2003 12:12 PM
I promised my VT Solution ....... Captain Carlton Foamies (Kits) 3 Aug 01, 2002 12:52 PM
