Old Mar 01, 2008, 02:23 PM
ciufuliciboy is offline
Find More Posts by ciufuliciboy
ciufuliciboy's Avatar
Barcelona
Joined Feb 2005
Gyro gain control without transmitter
Can I make a litle control for gyro gain ?
I use the gyro all the time in HH mode and I use 1 channel from reciver for gyro gain control. I need a litle generator for control this channel and use this free channel to control another function.
Also like servo tester but more litle for mount in hely.
Pic servo terster not work because not save pozition when cut power.
Analog solution with 555 is not too precise.
ciufuliciboy is offline Find More Posts by ciufuliciboy
Old Mar 01, 2008, 06:27 PM
mike50 is offline
Find More Posts by mike50
mike50's Avatar
Rochester, MN
Joined Jul 2003
How would you want to set the gain? It would be easy to make something like this from a PIC (with EEPROM memory), but you would have to say how you would want to set it.
mike50 is offline Find More Posts by mike50
Old Mar 01, 2008, 09:24 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
Sounds like overkill.
http://www.uoguelph.ca/~antoon/gadgets/servo3.htm
http://www.tuug.fi/~isaarine/electronics/servo-test/
Toshi
TMorita is offline Find More Posts by TMorita
Old Mar 01, 2008, 10:03 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
What do you mean "555 is not too precise"? A 555 will be as precise as anything you set with a pot. If you meant stability, the 555 will be very stable when built with temperature stable resistors and caps.
jeffs555 is offline Find More Posts by jeffs555
Old Mar 01, 2008, 10:08 PM
mike50 is offline
mike50's Avatar
Rochester, MN
Joined Jul 2003
Overkill? The solutions you linked to are far more complex than a PIC solution. A PIC "servo tester" circuit can be done with fewer parts and more cheaply.
Old Mar 01, 2008, 11:01 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
Cost for any of the solutions would be so low as to be negligible. The analog solutions would take a few more resistors and caps, but even if he were an expert programmer and all set up to program PIC's I bet it would take longer to write the code and debug it than it would take to wire in the extra r's and c's. If he were an expert programmer and all set up to program PIC's, then he wouldn't have even needed to post the question.
Old Mar 02, 2008, 03:07 AM
Barcelona
Joined Feb 2005
Manualy, with up/down button or with semireglabil rezistor.
I am electronic tehnician but not programmer.
Old Mar 02, 2008, 08:07 AM
mike50 is offline
mike50's Avatar
Rochester, MN
Joined Jul 2003
If you are looking for the lightest solution, you could make it so that it could be set from the transmitter. It could be made so that it could be plugged into the receiver, and to pass through whatever signal it got from the transmitter. It would remember the last signal it got, so that if it gets no signal it would use the last remembered value...and this could be remembered across turning the power off.
So after setting up the gain from the transmitter, then the circuit would maintain that value even when not plugged into the receiver.
This could be made easily with a PIC (such as 12F683) which has EEPROM to store the value across power off.
Old Mar 02, 2008, 11:10 AM
Barcelona
Joined Feb 2005
Very good solutioun but I am not programmer
Old Mar 03, 2008, 09:15 AM
mike50 is offline
mike50's Avatar
Rochester, MN
Joined Jul 2003
I am starting work on a different project that will be using a PIC 12F683 and I am pretty sure that the hardware setup for that project would work for yours. Since I am designing and building this circuit anyway, I could build you one just for the cost of the components (about $5 US) and shipping. It would just require a different program...which is easy for me. I would do that for fun.
Have you actually tried using a servo tester to control the gain? Does that work?
It is possible that some gyros need the gain signal to come at the same frame rate as the signal being controlled. With an external device like a servo tester the signals will come at independent rates, which might confuse the gyro.
Old Mar 04, 2008, 03:22 PM
TMorita is offline
Joined May 2002
As far as I know, in order to use a PIC, you need a PIC programmer.
So if you include the cost of the PIC programmer, then a solution using a PIC is probably more expensive.
Toshi
Old Mar 04, 2008, 04:38 PM
Barcelona
Joined Feb 2005
Toshi
The same need solder , flux . cable , connectors .......... etc.
Very constructive your help.........
Old Mar 05, 2008, 04:36 AM
spinup is offline
Find More Posts by spinup
hover happy
spinup's Avatar
over under
Joined Aug 2007
Yes!
I did exactly this a few months ago. See this post for a picture of the finished controller. Cost about $5, weighs 5 grams.
I used this 555-based circuit. I am no electronics technician, but I can read a diagram and use a soldering iron. A PIC would take much longer, and will not be any more "precise". But if you really need up/down buttons, I guess a PIC is your best bet.
My controller is currently attached to a Logictech 2100t, which works beautifully because that gyro has a row of indicator LEDs. As I turn the pot, the LEDs update in real time to show the mode and percentage of gain. I am ~very~ glad the 2100t has this readout - it made it practical to use a tiny pot!
FWIW I also found this prefab driver,. But I was determined to do it myself. The result was both cheaper and lighter.
I still have a Jameco invoice in my parts bin. Lemme know if you want the component numbers.
I doubt this would be a problem with any RC gyro you are likely to find. Anyway, I can confirm empirically that my ~50hz gain controller works with a Logictech 2100t that is sending a 270hz signal to the servo.
-Jeff
spinup is offline Find More Posts by spinup
Old Mar 05, 2008, 11:20 AM
Barcelona
Joined Feb 2005
I will try to use 555 chip.
Thanks spinup for your help. My gyro is the same 2100T.
Old Mar 08, 2008, 04:18 AM
Barcelona
Joined Feb 2005
I tested 555 schematics and gain led from gyro ( 2100T ) it is stable in one point but with litle up/down fluctuation .
Discussion Spektrum DX7 help with 6100Rx to control gyro gain Pyrock Radios 3 Jan 07, 2007 09:10 PM
HB Gyro gain potentiomemter value? realdeal Micro Helis 4 Dec 22, 2003 08:27 PM
Hummingbird Gyro and the Gain Adjustment Fooksy Micro Helis 2 Apr 22, 2003 12:35 PM
Is my gyro gain set wrong? mumblety-peg Electric Heli Talk 2 Mar 16, 2003 04:53 PM
Hornet gyro and speed control? wsilvio Micro Helis 6 Oct 22, 2002 08:32 PM
