Old Mar 01, 2008, 01:44 PM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Thrust Vs Weight??
Hey there
Im new in electrics, Im now plannig to build a EDF BD5 but I was wondering how to select and EDF what is a good relation Thrust Vs Weight??
thanks for your advices
Edwin
Edwinzea is offline Find More Posts by Edwinzea
Old Mar 01, 2008, 06:42 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
EDF? go for at least 150W/lb unless the model is quite slow. Probably at least 30% thrust to weight needed.
Probably more info in the forum devoted to EDF.
Old Mar 01, 2008, 09:11 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
@Edwin
Meet the natives:
www.modelbouwforum.nl
Hey, another 'uomo'
Vriendelijke groeten Ron van Sommeren
int. electric fly-in, Nijmegen, the Netherlands
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Mar 02, 2008, 06:28 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
thanks Ron But my dutch is not so good,
good fligths
EZ
Old Mar 02, 2008, 11:33 AM
Wulf_Flieger is offline
Find More Posts by Wulf_Flieger
ProBro Wulf
Wulf_Flieger's Avatar
Joined Oct 2006
Edwin, General rule of thumb for 3d is 150watts/Lb of plane for good 3d, 200 watts/pound for great 3d power. Depends on your flying style.
Wulf_Flieger is offline Find More Posts by Wulf_Flieger
Old Mar 02, 2008, 12:03 PM
Hasina75 is offline
Find More Posts by Hasina75
Marseille, France
Joined Apr 2002
Edwinzea> As a rule of thumb, you need at least 1lb of thrust to fly a 3lb model. A model aircraft can not be flown or it just barely stays in the air if the thrust to weight ratio is less than 1/3= 0.33. Some cheap r/c flying toys you purchase at your local toy store have a ratio of 0.25. That's why many customers are not happy with them. They just bring them back to the store and ask for a refund!!!. These are the thrust to weight ratio guidelines:
1lb/3lbs = 0.33 basic flying
1.5lb/3lbs = 0.5 advanced flying
1.71lb/3lbs = 0.57 aggressive flying
There is also a relationship between watts/lb and thrust to weight ratio. If you are curious about it, just look for my thread in which I talk about it. I can not post it twice.
Hasina75 is offline Find More Posts by Hasina75
Old Apr 01, 2008, 06:34 PM
EDF30 is offline
Find More Posts by EDF30
EDF30's Avatar
Mercer Co. PA
Joined Mar 2008
That's the bottom line. I've found the watts/pound guidlines assume a reasonably light wingloading of 15oz/sq-ft or less. I have EDFs that need 200W/lb to even fly decently.
I'm ready to fly my 4oz EDF30 Vampire now, and am hopefully just above the minimum specs for decent flight. Well see:
1. The Cox 109 wing platform seems to fly well at low power levels with their planes at 5.5oz. I'm at a good bit less, being 4oz AUW.
2. I have 30W total, or 120W/pound.
3. Thrust to weight ratio with 1.5oz thrust is about 37%.
I'm keeping my fingers crossed.
Bill
EDF30 is offline Find More Posts by EDF30
Old Nov 08, 2009, 12:07 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Originally Posted by Hasina75 View Post
Edwinzea>
Please post it, I am interested.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Nov 15, 2009, 01:41 AM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
I am interested, too! :-)
flyandi is offline Find More Posts by flyandi
Old Nov 15, 2009, 05:34 PM
marc1 is offline
Find More Posts by marc1
I will be an angry old man!
marc1's Avatar
Canada, MB, Division No. 9
Joined Apr 2007
Originally Posted by Edwinzea View Post
Hey there
Edwin
Assuming you use quality components, 160-180W/lb is a good setup for an EDF. If you use an inexpensive motor and fan unit, then you may require more than that to get good performance (220-250W/lb).
The most expensive EDF units will be about 75-80% efficient, the cheapest about 50-60% efficient.
marc1 is offline Find More Posts by marc1
Old Nov 16, 2009, 07:32 PM
asm_ is offline
Find More Posts by asm_
California
Joined Apr 2006
I'm glad marc pointed out. It's not as simple as x number of watt per x number of lb. A poorly designed power system could wast more then half of the electric energy by converting it into heat. It's all about efficiency.
asm_ is offline Find More Posts by asm_
Old Nov 17, 2009, 05:21 PM
flapdown is offline
Find More Posts by flapdown
Joined Aug 2009
for high performance EDF jets, 300+ watts/lb... Or
something like 1.5 T/W ratio is very normal.
flapdown is offline Find More Posts by flapdown
Old Nov 18, 2009, 08:53 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
= any EDF!
And EDFs are at best 30% efficient at model flying speeds.
Old Nov 20, 2009, 08:11 PM
Joined Aug 2009
Originally Posted by vintage1 View Post
= any EDF!
Would this change for the better as the KV goes higher?
Old Nov 20, 2009, 08:57 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I think the problem is that we have miniscule impellers spinning at ridiculously fast rpm (we must do that to get any decent thrust at all).... a tiny impeller generating 100-200mph "pitch speed" is not moving a lot of air (it is just making a hole in it) so, for our modest flight speeds, the system is simply wasting energy making noise and heat. A relatively far larger prop is always going to move air more efficiently than an EDF.
Higher Kv might be fractionally better.....31% efficient???
Dr Kiwi is offline Find More Posts by Dr Kiwi
Discussion Thrust vs Weight??????? (In picking power) arcticflyer Scratchbuilt Indoor and Micro Models 2 Oct 31, 2006 10:12 PM
Discussion Thrust vs. Weight freedomflyer Power Systems 2 Jan 01, 2006 06:30 PM
Thrust vs weight and prop sizing BlueSkyBlack___? Electric Plane Talk 2 Sep 06, 2005 08:00 PM
whats the best thrust vs weight in small fans Mike Caspari Electric Ducted Fan Jet Talk 22 Feb 03, 2003 05:00 PM
