Old Jan 03, 2003, 08:02 PM
Kevin Sharbonda
Kevin Sharbonda
Guest
n/a Posts
[RCSE] Off topic...Spar treatment for Sovereign from laser arts!
Building a Sovereign for one design and need a quick and simple
method for beefing up the spar to take a full yank up on the line,
anyone got a good carbon treatment without much deviation from the
kit components? Thanks in advance....kev
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
Old Jan 03, 2003, 09:12 PM
Stuart Hall
Stuart Hall
Guest
n/a Posts
RE: [RCSE] Off topic...Spar treatment for Sovereign from laser arts!
Hi Kevin,
I too will be building a Sovereign from laser arts later this winter (gotta
get the bank...er wife to write the check first). At first I thought the
intent of one design was use the glider as it came out of the box to
eliminate any launching advantages from one plane over another.
On second thought, I just found
http://www.soarmd.org/BassNews/sovOneDesign.html and they allow any
structural changes as you describe so my initial thought was incorrect. I
haven't seen the wing yet, but can you apply the carbon and kevlar method
shown in the Majestic pages of the laser arts website?
http://members.aol.com/laserarts2/carbonwing.html I think they recommend it
for their 100" Scepter as well.
Stuart
> -----Original Message-----
> From: Kevin Sharbonda <kevins242@aol.com> [mailto:kevins242@aol.com]
> Sent: Friday, January 03, 2003 5:49 PM
> To: soaring@airage.com
> Subject: [RCSE] Off topic...Spar treatment for Sovereign from laser
> arts!
> turned off.
Old Jan 03, 2003, 10:02 PM
Andrew E. Mileski
Andrew E. Mileski
Guest
n/a Posts
Re: [RCSE] Off topic...Spar treatment for Sovereign from laser arts!
Simply put, epoxy CF to spars and wrap sparbox with Kevlar thread
or Spectra (like "Spider Wire" fishing line). I think the supplied
thread is Dacron.
If allowed, you might also want to make the v-tail 45 degrees, and
extend the tips for better low-speed handling. Adding some washout
to reduce tip stalling probably wouldn't hurt either.
Andrew E. Mileski
Ottawa, Canada
Winch plans from Laser Arts balsaaddict Thermal 2 Dec 11, 2005 01:31 PM
