Old Mar 01, 2008, 10:04 AM
Matt Halton is online now
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
Build Log
My Fly Fly BAe Hawk build and scale mod thread.
I got started at last on my Hawk. I bought this kit from Phoenix Racing (RCG handle) Here in the UK, thanks Scott!
I decided it should be covered in tissue and Poly C, so got going on that first.
After rubbing the fuse parts down with a sanding block (cork in my case) with fine glasspaper, the part was cleaned using a sponge and water.
Using natural light,the dents/divots were identified and lightweight filler used to cover them.
After curing, the filler is sanded and blended, then the Silkspan and WBPU (Poly C is better as it has a hardening agent mixed in)
Then the excess Silkspan was removed using a scalpel blade,another thin coat of Poly was then brushed over.
When this has set, I will sand`out any wrinkles, then add another thin coat.
I'm doing this to all of the fuse parts whilst still seperate, to join later.
I'm using Spring Air 602's with the supplied oleos in the kit.
I want to add a lot of detail to this model, so am hoping to achieve the best scale finish I can.
It will be using an RAF display scheme, mostly black.
The power system will be a Schuebeler DS-51 with a Hacker B50 and 6S lipos with a Hacker 77 Opto ESC.
I'll add flaps to the wing too, and proper gear doors and other details.
Anyone want to chime in here with suggestions, please do!
I need to cover the second rear fuse half and then the nose parts,so a way to go yet..
Cheers
Matt.
Matt Halton is online now Find More Posts by Matt Halton
Old Mar 01, 2008, 10:29 AM
Wannabe B-26 pilot!
Joined Nov 2002
Oh, and here is my power system.
Old Mar 04, 2008, 08:17 AM
Mike Parsons is offline
Find More Posts by Mike Parsons
Forgot how to fly
Mike Parsons's Avatar
Atlanta, Georgia
Joined Oct 2002
Signing in In the process of my build now.
Mike Parsons is offline Find More Posts by Mike Parsons
Old Mar 04, 2008, 12:08 PM
Wannabe B-26 pilot!
Joined Nov 2002
Hello Mike.
I have now completed the fuse covering, just leaves the wings/tail parts, not much to show with photos yet, but once all surfaces are covered,I'll install gear etc.
How far are you into your build?
Old Mar 04, 2008, 12:14 PM
Forgot how to fly
Atlanta, Georgia
Joined Oct 2002
I joined the fuse halves and wings so far. I have a few projects ahead of it and waiting on the motor to show up to see if it will be a good fit (1800 kv Ammo inrunner).
I am still debating on glassing or not.
Old Mar 06, 2008, 06:41 AM
Wannabe B-26 pilot!
Joined Nov 2002
Tail parts covered, I'll post pics when I have something interesting to look at..
I haven't attempted a dry fit with my fan unit yet,but if it doesn't fit, some tools I have here say it will!
Get all the boring covering job done first, then on to the fun parts.
Still not decided on radio equipment yet..
Later
Matt
Old Mar 06, 2008, 09:14 AM
Wannabe B-26 pilot!
Joined Nov 2002
Ok, all the boring bits done (sans wing covering)
I trial fitted my Schubi fan,it is longer than the kit fan,I just need to file down a foam circular ridge to get it in, no biggie really.
I'm looking at methods of beefing up the airframe where possible due to the expected surfiet of extra power!
If you look at the indented panel lines, they were difficult to fill with the Silkspan on the first pass, but I found that using a sharp scalpel blade and slitting down, then using a bit more P C fils them in nicely, just a little tedious to do, but it will be worth it.
Post covering the skin surfaces feel incredibly strong and less likely to dent over the bare foam finish.
Here are today's pics:-
Old Mar 06, 2008, 11:07 AM
Scott Cuppello is offline
Find More Posts by Scott Cuppello
Commercial UAV Pilot
United Kingdom, England, Carlisle
Joined Mar 2007
I'm glad you have started this Matt, been looking forward to it.
Scott Cuppello is offline Find More Posts by Scott Cuppello
Old Mar 07, 2008, 02:45 AM
Wannabe B-26 pilot!
Joined Nov 2002
Glad you're watching Scott! It will take a while due to the skin finishing process more than anything,also looking at at adding flaps.Probably don't need them, but it aint scale without them!
I'm wondering what the RAF are dreaming up for their new scheme for the slo 2008 display machine..I'll see what I can find.
Of course, the cockpit interior won't be overlooked either...I have my work cut out it seems.
Gear doors would be nice too, we'll see.
Am doing a few hours more on it today
Old Mar 07, 2008, 12:45 PM
Wannabe B-26 pilot!
Joined Nov 2002
Just the wing left to cover now-I have sanded/filled sanded, coated...just goes on.
Anyway, here's where I'm at,one more sanding and I can join the sides after fitting the servo leads and modifying the motor mount.
I'll get there sooner or later!!
I have to work on my dining table, no room anywhere else
Old Mar 08, 2008, 03:43 AM
Wannabe B-26 pilot!
Joined Nov 2002
Here's a nice video regarding the BAe Hawk development,interesting stuff!
http://www.youtube.com/watch?v=kpCkOG87Hmk
Old Mar 08, 2008, 08:16 AM
flybyday is offline
Find More Posts by flybyday
Joined Aug 2004
Hi Matt. I have a friend whose nephew has been chosen as this years hawk solo demo pilot - I am sure he may be able to find the chosen color scheme ?
flybyday is offline Find More Posts by flybyday
Old Mar 08, 2008, 10:19 AM
Wannabe B-26 pilot!
Joined Nov 2002
Yes please! That would be great if he could,I've looked around on the net to no avail,but if he can help that would be great!
I'm thinking of using these cels (Enerland)
http://www.hobbycity.com/hobbycity/s...idProduct=5723
A123's would be nice, but I'd need to buy lots of cellls as they are nominally 2300 mah per cell, meaning I would have to buy 12 cells ( for a 6s 5600 pack) and the voltage is poorer, so really no choice but lipo's!
Old Mar 08, 2008, 10:53 AM
Wannabe B-26 pilot!
Joined Nov 2002
Pilot reference
I had these on my HD,RAF pilot garb, should help a lot when I carve my pilot.
Also a useful panel too.
I hope to get some more time building this tomorrow.
Old Mar 10, 2008, 04:08 PM
Wannabe B-26 pilot!
Joined Nov 2002
Schubi fan install
Had to cut some foam away with a razor saw (about 1/2") from the fuse lower hatch area to allow my longer shrouded fan to fit, kept the cut offs and glued them to the hatch.
In order to get the afterbody fairing of the fan in, I had to cut some foam away ahead of the warm air exit under the fuse.
Bit of a pain, but the only way to get the DS-51 in..
Skyhobbies, or anyone, can you tell me where you installed your ESC.
I can't close the fuse up until I have this info, so any help is appreciated.
Here's my fan fit.
My plan is to refit the cut foam parts back one happy that everything works ok, the cover with silkspan before painting. If I ever need to access the fan again, I'll simply cut the reglued parts out.
Discussion Cox P-40 micro warbird build and mod thread czechyour6 Electric Warbirds 84 Sep 02, 2010 10:46 PM
Discussion EJF/Sapac Red Arrows Hawk build and mod thread Ed Waldrep Foamy EDFs 139 Oct 26, 2009 10:45 PM
Discussion is there a build thread somewhere on the fly fly bae hawk ? aviador Foamy EDFs 1 Feb 04, 2008 09:42 PM
Rave CNC Foam BAE Hawk build barmybovine The Builders Workshop 28 Dec 03, 2005 10:21 AM
Ultra fly Bae Hawk didnt fly :( jetspud Electric Ducted Fan Jet Talk 5 Sep 24, 2004 08:00 PM
