| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 |
Life begins at transition
Dude, that's two in how many weeks?!?
Surely a bit of epoxy will have it back up? |
#47 | |
Shouldnt you be building the -47 instead of harassing me... LOLit was an act of god i tells ya. Easy to put back together, just gota get the time
#48 |
Waiting for glue to dry on the second skin panel. I'm waiting on parts to come in, so it'll be a while before doing any real work.
As for time - shouldn't you be glueing instead of typing? :P |
#49 | |
Next time I'll ARTF...
#50 |
It's a trap!
Hrmm a new blabber thread. In the spirit of further off-topic discussion, I present the following conundrum.
I have an Xbox 360 but no HDTV, so I use a VGA cable (D-Sub) and plug it into my 20" LCD monitor. The monitor has both DVI and D-Sub ports. My PC is normally plugged into it via DVI. In order to play the 360 I turn off the monitor, unplug the PC's DVI cable, plug in the 360's VGA cable, then turn it back on. After I'm finished playing I turn it off again and swap the cables back. In the past I had no problems with this, often I would swap back and forth between them repeatedly, but now all of a sudden when I plug the PC back in and turn the monitor on again it comes up with "no input detected". I can swap back to the 360 and it will show up fine, but I have to reboot the PC in order for it to display a signal from the DVI port again. This is a serious PITA. Anyone got any ideas on what might be causing this? |
#51 |
my first question is if one is dsub and the other is DIV, why are you unplugging them and not just switching between them??
sounds like a PITA right there! |
#52 |
GG,
You don't have a Dell do you? Mine will automatically de-select multi-monitor outputs if I remove the vga cable. I can reset it using Fn-F8 though. If all else fails, a 50" 1080p plasma may be in your future
#53 |
Learning to fly helis
You should be able to leave both plugged in and at least switch between inputs in the monitor menus?
Troy |
#54 |
The Glider Version
mmmm , New Blabber thread.
Dont you guys just feel terrible for slowing down the RC Groups forums.? I should not mention here - but, I am re-working some older planes..... funny how they seem to need freshening up every so often. Glenn. |
#55 |
It's a trap!
Hrmm...didn't realise it even had input select. Was hidden away in one of the menus. I guess I can try that, I just would have liked to know why it wasn't auto-switching back to DVI (in the past if you had them both plugged in it would always default to DVI if there was a signal).
#56 |
While we have IT support is a DVD drive that chatters away and fails to read a disc just have a dusty lense, will a quick shot of compressed air fix it?
#57 |
I have a DVD micro system (stereo) that had a problem where it would make a funny chattering noise and wouldn't read. Upon disassembly, I found one of the pinions in the drive for the read head had fallen off the shaft (factory missed cir clip). Fixed it, happened again so I made a clip from some scrap ally.
I am assuming yours is a DVD drive in a PC though, which I would guess has a stepper motor and screw setup, so the above is probably irrelevant. ![]() If all else fails, compressed air shouldn't hurt (depending on the pressure. Troy |
#58 |
Nothing to lose with a shot or air I guess. Any misssing pinions or circlips its probably 40 bucks for a new drive.
#59 |
You got it!
#60 | |
Heli Blades of Glory
Because my 22" LCD sometimes instead of going into powersaving mode just says input not detected but i move the mouse and there ya have it pc is back. |
| Thread Tools | |
| Rave This is a thread to blabber In. | Parkflyer81 | Australia | 9204 | Feb 29, 2008 10:55 AM |
| Use my altimeter in 2 new setups this weekend | Doc Data | Electric Sailplanes | 28 | Jul 11, 2004 03:11 PM |
| Razor for sale in this thread | rpvpilot | 3D Flying | 0 | Jan 31, 2004 02:15 AM |
