Old Jun 20, 2001, 07:26 PM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
must have gotten a bad one...
Flight # 31 for my ZAGI X, 0630 today, air temp about 65 F, no wind, overcast sky threatening to rain any moment.
The usual loops, practicing axial rolls, level off, make a left turn, loose visual orientation, splat! Not a particularly hard hit, not a whole lot of speed, maybe 30 feet high.
Oh well, no problem, it's a ZAGI, right?
Get over to the ZAGI X, canopy broken in two parts, battery tray totally destroyed. I mean totally. It's in four large pieces, some smaller parts are gone. Motor ripped off its mount, the wire tie cut right through the tray.
The worst of it? You guessed it right. The battery damaged the 555 rx
So these ZAGI's aint indestructable after all....
Called the ZAGI factory. They just happen to sell a canopy/battery tray kit, complete with new prop, velcro, etc. for $12 plus $4 S&H. Maybe by Saturday.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Jun 20, 2001, 07:36 PM
dave_lilley is offline
Find More Posts by dave_lilley
Texas
Joined Aug 1999
Did you have the receiver offset to one side?
dave_lilley is offline Find More Posts by dave_lilley
Old Jun 20, 2001, 07:52 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Or better yet, behind the battery pack.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jun 20, 2001, 08:06 PM
5teve is offline
Find More Posts by 5teve
San Ramon, CA
Joined May 2001
Larry,
I had the same thing happen to me when I first flew my 400X. I crashed from about 30 or so feet, and my canopy, battery tray, and receiver were pretty destroyed. I was actually able to glue my battery tray back together, but it wasn't pretty. My receiver, however, was managled like yours so I had to replace it.
I now have my receiver mounted off to the side of the battery, away from harms way Check out http://www.clubzagi.com , and read their tips page.
I like you was upset that my Zagi got "hurt", because I've heard that they are so strong.. The wing itself is actually really durable, but not the electronics of course! Also, the battery tray seems to be the first thing to break when the nose hits.
-steve
5teve is offline Find More Posts by 5teve
Old Jun 20, 2001, 08:39 PM
realdeal is offline
Find More Posts by realdeal
Festina Lente
realdeal's Avatar
USA, KY, Lexington
Joined Nov 1999
Was the receiver physically damaged or is it just not working now? If it is just not working you probably broke the crystal. You can buy them for $10-15.
Keith
realdeal is offline Find More Posts by realdeal
Old Jun 20, 2001, 09:18 PM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
Yes, Larry, the crystals are very fragile and can easily be damaged.
They sure are cheaper than a new RX.
But, we know who will win a fight between a 1 ounce RX and an 8 ounce battery.
Shawn
Eflightpower.com
sf_247 is offline Find More Posts by sf_247
Old Jun 21, 2001, 12:22 AM
5teve is offline
San Ramon, CA
Joined May 2001
My crystal and receiver were damaged. My receiver was complete cracked and looked like someone stepped on it. I opened it up, and it appeared that one of the pots inside was cracked too. I figured it was toast.. At least I learned from it.
-steve
Old Jun 21, 2001, 10:52 AM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
My Zagi damage list
2 recievers (I'm alittle slow, third reciever is off to the side).
1 set of HS55 gears (way to small).
1 set of HS81 gears (way to big of a crash).
4 sets of battery trays and canopys.
Now I got a turbo 450 setup and can see #5 batt tray just around the corner.(Hoppy, you and Buzzman get together and design us a new batt tray, OK?)
Oh ya, almost forgot, 1 zagi 1700 batt (50 feet + inverted loop + 1 battery [now flying by itself] + 1 rock = SMOKE)
And I'm having a blast doing it.
William A
William A is offline Find More Posts by William A
Old Jun 21, 2001, 11:05 AM
Jacques Flambeau is offline
Find More Posts by Jacques Flambeau
Restful User
Jacques Flambeau's Avatar
Backwoods Alabama
Joined May 2000
I think of Zagis as not so much "indestructable" as "less-destructable".
They _can_ take a lickin' and keep on tickin', but sometimes go *sproiing*...
--Bill
Jacques Flambeau is offline Find More Posts by Jacques Flambeau
Old Jun 21, 2001, 11:18 AM
Joined Sep 2000
I have managed to glue/tape the tray/canopy together.
I have replaced the 555 with a 'superslim'. This one is mounted off to the side.
When I connect the battery to the ESC and the 555 rx, the servo's jitter for about 1/2 second. Then nothing.
At any rate, I flew it this morning
Old Jun 21, 2001, 02:22 PM
nybpete is offline
Find More Posts by nybpete
nybpete's Avatar
Joined Jun 2001
What does moving the rx to one side do to stability in such a light weight plane?
nybpete is offline Find More Posts by nybpete
Old Jun 21, 2001, 02:51 PM
Quartz is offline
Find More Posts by Quartz
Ottawa, On, Canada
Joined May 2001
nybpete:
Well, most people hollow out some of the foam in the wing to put the rx to one side. You loose some weight from the foam, and add some weight from the rx. They won't quite balance, but I'm sure it's not that much of a problem. It would easily be accountable for with a little opposite-trim. Alternatively you could tape a penny to the opposite wing tip, and that would probably make up for it.
Myself, I bought my Zagi second hand, and the previous owner had hollowed out some foam underneath the battery tray in the nose, so I stuck my rx there. I've had no problems so far, and some pretty harsh impacts.
Larry:
You may be able to send your rx in for repair. Hitec may charge you for it, but I'm sure they won't charge you more than a new rx. It's been my impression, from what other people have told me, that Hitec is pretty awesome as far as customer service goes.
Quartz is offline Find More Posts by Quartz
Old Jun 21, 2001, 10:22 PM
DaJudge is offline
Find More Posts by DaJudge
Fish & Fly
DaJudge's Avatar
Tyler, TX USA
Joined Jul 2000
Most things about the 400X (vs the plain 400) are improvements.
The very big exceptions are the Rx placement and that stupid ridge that takes up the front 1 and 1/2" of the battery tray (takes away the ability for a wide range of CG adjustment).
I suggest to all 400X builders to put the Rx in the foam around the CG and to cut out that ridge, flip it over and glue/tape it in upside down so the whole thing is flat.
DaJudge is offline Find More Posts by DaJudge
Old Jun 22, 2001, 12:08 AM
MrBungle is offline
Find More Posts by MrBungle
rebmeM roineS
MrBungle's Avatar
Rockingham, Perth - Western Australia
Joined Apr 2001
Do you have another crystal set you can plug in and try?
MrBungle is offline Find More Posts by MrBungle
Build Log Jart - Must have one Adrian B. Slope 261 Sep 13, 2007 10:55 AM
Discussion Somebody must have reworked one of these ? LKC Foamy EDFs 6 Dec 01, 2006 06:03 PM
Must have at least one....ZAGI SKYPILEIT Foamies (Kits) 0 Dec 17, 2002 01:55 AM
Scooter-E: Have you flown one? Leonard Foamies (Kits) 3 Jan 01, 2002 07:07 PM
Must have been the Zagi candy slowflyer Foamies (Kits) 6 May 15, 2001 03:25 PM
