Old Feb 27, 2008, 05:09 PM
kylewp is offline
Find More Posts by kylewp
kylewp's Avatar
United States, TX, Tomball
Build Log
Sterling "Classic Dual Cockpit Mahogany Runabout" - First Time Build
Hi Guys,
I found a Sterling "Classic Dual-Cockpit Mahogany Runabout" on eBay. I went ahead and got it because it seems much easier than the Dumas models because of its one-piece deck and mahogany side and bottom skins. So far the build has gone great, and I purchased the package from M.A.C.K. designed for the model. Luckily they still had one. It would be great to hear your feedback and suggestions, and I'd especially like to hear from anyone who has built this model before or has pictures of their completed model. Just keep in mind that I'm 18 and its my first build .
-Kyle
kylewp is offline Find More Posts by kylewp
Old Feb 27, 2008, 06:20 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Hi Kyle,
Wow, I would say you are doing a great job so far! I know a lot of old geezers on here are getting all sentimental right now that an 18 year old is actually building a model instead of buying an RTR!!
Kmot is online now Find More Posts by Kmot
Old Feb 27, 2008, 06:26 PM
kylewp is offline
kylewp's Avatar
How 'bout this for some extra power?
(just kidding )
Old Feb 27, 2008, 11:46 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Sorry but a Cox .049 just ain't gonna be big enough.
green-boat is offline Find More Posts by green-boat
Old Feb 28, 2008, 11:15 AM
charlie eaton is offline
Find More Posts by charlie eaton
charlie eaton's Avatar
N.E.Mass.
Joined Apr 2007
Mostly because it does'nt run very well under water!!
charlie eaton is offline Find More Posts by charlie eaton
Old Feb 28, 2008, 11:22 AM
N.E.Mass.
Joined Apr 2007
Seriously Kyle, The side and bottom die-cut mahogany tends to warp in the box over a period of time. If yours are flat ok,if not, dampen them. Put them on a flat surface,cover with paper towels and a flat plank,add weight and let dry for several days. This will cure the warpage. If you use a cloth towel the dye in the wood will stain it. Welcome to the wounderfull world of scale boats!!
Old Feb 28, 2008, 04:09 PM
kylewp is offline
kylewp's Avatar
Thanks Charlie
Old Feb 28, 2008, 04:21 PM
kylewp is offline
kylewp's Avatar
What should I do to these fittings? I'm pretty sure I can grind/file all the flash off but what can I do to paint/polish them? I'm not sure what they're made of, but the pieces are really bendable, kind of like pewter.
Old Feb 28, 2008, 05:48 PM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
They probably are pewter and have lead in them. You can shine them up but they just get all tarnished as time goes on. I usually clean them up good removing all the flash and form marks and paint then silver or any appropriate color. You can chrome plate them if you want to. There are several kits out now that you can buy and do the chroming yourself. That looks the best if you want to spend the money. (Less than $100 )
norgale is offline Find More Posts by norgale
Old Feb 28, 2008, 07:24 PM
N.E.Mass.
Joined Apr 2007
Another way is to clean them up and use Alclad paint on them. You have to use a black paint base coat then the Alclad. Alclad is high priced but does a good job.
Old Feb 29, 2008, 03:29 PM
kylewp is offline
kylewp's Avatar
Thanks guys. I'll post some more pictures when I make some more progress. Hopefully you'll see some mahogany!
-Kyle
Old Mar 07, 2008, 03:02 AM
jeepers1940 is offline
Find More Posts by jeepers1940
Madison, MS
My partly built kit, an eBay purchase, arrived today. It's completed to about the extent that yours is, Kyle. The former builder got to the step where he attempted to glue the port side mahogany hull skin to the frames. Unfortunately, the thin mahogany strip partially split where it should attach to the frames toward the bow. Fortunately, I have several 4' long strips of mahogany that are plenty wide to replace that damaged strip. Wouldn't you know that that strip appears to be well glued back toward the stern. Perhaps the strip can be salvaged, and the split somewhat glued back so that it's not obvious.
The fittings set appears to be complete, as is the rest of the kit. However, the kit will have to get in line - a rather long line, I'm afraid.
Bill
jeepers1940 is offline Find More Posts by jeepers1940
Old Mar 07, 2008, 04:51 PM
kylewp is offline
kylewp's Avatar
Bill,
I saw that kit on for sale on eBay. It looked like whoever started it did a pretty nice job. You already have one mahogany skin on, if I remember correctly. That means all of the sanding is done! That's what I'm working on right now. By the way, if you contact M.A.C.K. products by phone, they can put a nice package together for you that is specifically designed for the Sterling Runabout. The package comes out to just under $200 and has really high quality parts. It replaces some of the cheap stuff that comes with the model. See my picture to see everything that's included in the package. DONT KEEP BUILDING if you want to use this package. It will come with an instruction sheet that makes several modifications to the assembly process. I don't think your kit is built too far though.
I think this is a great kit because you can still build a great looking mahogany Chris Craft with no planking.
-Kyle
Old Mar 07, 2008, 06:35 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
-Kyle
No planking... but, but, but, that's the fun part.
woodybob is offline Find More Posts by woodybob
Old Mar 07, 2008, 09:46 PM
kylewp is offline
kylewp's Avatar
Hahahaha Not so much for people just starting out. I'm sure I'll get around to a planked hull someday but for now, the mahogany skins look challenging enough!
Build Log First time build eagle927 Scale Boats 92 Apr 14, 2008 01:03 PM
Discussion balsa first time build question turned into Fw-198 build :) salat The Builders Workshop 44 Dec 04, 2007 06:28 AM
Off Site Sterling Classic Dual Cockpit Mahogany Runabout MILLERTIME Boats (FS/W) 0 Oct 14, 2007 08:57 PM
first time build help!!! bob_johnson Electric Power Cars 2 Nov 27, 2004 12:01 PM
First time build impressions/ Slow Stick bubbadice Parkflyers 138 Nov 06, 2003 04:13 PM
