This thread is privately moderated by TMASTER, who may elect to delete unwanted replies.
Old Feb 26, 2008, 07:16 PM
TMASTER is offline
Find More Posts by TMASTER
Trader Rating: 47
Mr Solution
TMASTER's Avatar
TX
Joined Aug 2004
Trader Rating: 47
Sold
T-REX 450 Rotor assembly, tail, shafts, parts, etc
T-REX 450 Rotor assembly. Has Micro heli swash modified lower to use aligns balls. Good mainshaft, flybar and 6.11g paddles. Has gray headblock and plastic flybar cage. Comes with a set of balanced CG and weight; 325 Pro's. No tracking needed, I have marked the blades for what grip each goes on. It has been maintained and has low use, 30 flights or so.
$85 shipped! (new would cost $150+) !! SOLD pending P !!
There is no loctite on the assembly, so you may want to dismantle and loctite the screws.
Rotor assembly 1 Rotor assembly 2
(4) T-REX 450 Mainshafts, and (2) collars
$8.00 shipped !! SOLD pending P !!
1 new flybar paddle 6.11g
1 used good 325 pro blade
1 set of crappy new yellow pastic blades
2 used yellow tail blades
XL hub and 2 XL grips and used hub
450 size gold heatsink for aligns motors
$3.00 shipped !! SOLD pending P !!
HS1199 tail assembly and HS1077 tail case - like 3 flights on the HS1199
custom vertical & horizontal G10 Fins
white set of used tail blades
2 sets of servo mounts for boom
2 sets of used boom supports
1 new flybar rod 220
Pack of new ball links, few missing
$25 shipped !! SOLD !!
TMASTER is offline Find More Posts by TMASTER
Old Feb 26, 2008, 08:03 PM
Drew816 is offline
Find More Posts by Drew816
Trader Rating: 38
Smoke, Fire, ahh SMIRE!!
Drew816's Avatar
Columbus, Ohio
Joined Dec 2007
Trader Rating: 38
PM Sent..
Drew816 is offline Find More Posts by Drew816
Old Feb 28, 2008, 09:06 AM
laughingstill is offline
Find More Posts by laughingstill
Trader Rating: 114
laughingstill's Avatar
Gainesville, Florida
Joined Sep 2006
Trader Rating: 114
pm sent on tail and parts. I will take it.
laughingstill is offline Find More Posts by laughingstill
Help! T-Rex 450 build issue: tail drive gear too low? avalys Mini Helis 14 Apr 21, 2009 11:31 PM
Sold T-Rex 450 XL/SE Tail Drive Belt jrbackus Aircraft - Electric - Helis (FS/W) 0 Jan 22, 2008 04:23 PM
Found T-Rex 450 SE aluminum tail drive bearing blocks toolguy420 Aircraft - Electric - Helis (FS/W) 1 Sep 28, 2007 11:18 AM
Discussion T-REX 450 Carbon fiber tail rotor blades? JAMESAK51 Mini Helis 5 Aug 17, 2007 04:34 PM
Wanted T-rex 450/XL plastic tail assembly... papasmurf Aircraft - Electric - Helis (FS/W) 1 Feb 23, 2007 11:46 PM
