Espritmodel.com Heli Air
Old Jan 03, 2003, 07:53 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Any interest out there....
After drawing up plans for an 80" B-29 (see "B-29 plans" thread), I got some interest from fellow E-zoners about similar planes.
Currently I'm drawing a set of plans for a DC-4 that's about the same size. It will be a little more involved than the B-29 in that the nose and tail will need to be carved and shaped from foam rather than just having a straight cuts. I have also drawn formers and a building crutch for it so you could build up the fuselage with formers and plank it. Other than that, it will have the same 4xSP400 on 8 cells power system. The DC-4 is on 3 sheets and is basicaly done. About a weeks more work and they should be ready to ship.
The next drawing project was inspired by the last page of MAN this month: a Tu-95 Bear. This one should be more similar to the B-29 in that the fuse will consist of a main tube and a tail cone. The nose will require some carving, but the engine nacells are basically tubes. I'm just starting these drawings, and was wondering if there is any interest out there in these plans?
Disclaimer: Right now I have more time to draw than the build. I will make these plans available with the understanding that they have not been built and flown. Since both designs are based on a proven design, it's more question of how well rather than if.
-Jim
Jim Young is offline Find More Posts by Jim Young
Old Jan 03, 2003, 09:06 AM
HEAD NEAT GEEK
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
Hi Jim
I have a Bear partially drawn too.... for speed 400's. Have not worked on it for a couple of years now. Bought a plastic model for some shapes other than the round parts you mentioned.
I hate all those versions with the large "chins".
some day I'll get back to it.
Tom
Tom Hunt is offline Find More Posts by Tom Hunt
Old Jan 06, 2003, 09:56 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Tu-95 Bear Plans
Here are the "Bear" plans so far. Sorry about the resolution, but they should be good enough to get an idea.
Old Jan 06, 2003, 10:01 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Bear Plans
The Bear right now has an 80" wing span, 74" length and about 760 squares. The B-29 only has 560 squares, so it may make sense to reduce the size a little. However, if I do that the wing tips get kind of small. Any thoughts out there?
Any one interested in being a beta builder?
-Jim
Old Jan 06, 2003, 10:06 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
DC-4 Plans
Here are plans for the DC-4....
Again, the wing span is 80" and it has 750 squares. The fuse can be built as a foam core sheeted with balsa or built up with formers and sheeted with balsa. There are two more plan sheets for the wings and the fuse sections/formers. I did these plans at the request of a guy from Ohio.
Old Jan 06, 2003, 01:48 PM
Brookville, Ohio
Joined May 2000
Jim,
I would be very interested in plans for the Tu-95, esp. after following the thread on your B-29. Paul
marshall is offline Find More Posts by marshall
Old Jan 06, 2003, 03:51 PM
Rudderman98's Avatar
United States, WA, Sumner
Joined Oct 2000
Lookin good Jim!
Perry
Rudderman98 is offline Find More Posts by Rudderman98
generic ozcover,,,any interest out there ishu4u Electric Plane Talk 3 Mar 29, 2003 10:22 PM
Any Artist out there? How about a TM cockpit? Daveairway Parkflyers 8 Feb 09, 2002 05:22 PM
Any Golfers out there? Clive Henry Jones Humor 0 Nov 15, 2001 04:29 AM
YAK-55 Any plans out there?? KOMET 44 Sport Planes 0 Jun 08, 2001 11:14 PM
Any folks out there flying the Sig Rascal? atsiang Electric Plane Talk 9 Apr 27, 2001 12:51 AM
